查看: 824|回复: 4
[提问] 求改一代码
发表于 2021-1-20 09:07:33 | 显示全部楼层 |阅读模式
3明经币
原贴在那忘了,就在明经里的
不要选择直接换行 与 空格 2种,谢谢了
;;;*****文字合并 程序开始*****
(defun c:hbh (/ lst)
  (setq oldaun (getvar "aunits"))
  (setvar "aunits" 3)
  (setvar "osmode" 15359)
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (princ "\n★功能:文字合并。\n \n")
  (setq ss (ssget '((0 . "MTEXT,TEXT"))))
  (setvar "osmode" 0)
  (initget "E S A")
  (if (not (setq kword
                  (getkword
                    "\n在合并文字之间加:[换行(E)/空格(S)/直接合并(A)]<E>"
    (setq kword "E")
  (setvar "osmode" 0)
  (setq lst '())
  (while (> (sslength ss) 0)
    (setq entnam (ssname ss 0)
          entdat (entget entnam)
    (setq pt  (cdr (assoc 10 entdat))        ;读取文字的插入点坐标
          txt (cdr (assoc 1 entdat))        ;读取文字内容
          zg  (cdr (assoc 40 entdat))        ;读取文字的字高
          lst (cons (list pt txt zg) lst) ;将点坐标、内容、字高组成表
          ss  (ssdel entnam ss)                ;选择集中删除当前的文字对象
    (entdel entnam)                        ;删除文字对象
  (setq
    lst
     (vl-sort lst
(function
                (lambda        (e1 e2)
                  (if (equal (cadr (car e1)) (cadr (car e2)) 1e-4)
                    (> (car (car e1)) (car (car e2)))
                    (< (cadr (car e1)) (cadr (car e2)))
  (setq str "")
  (cond        ((= kword "S")
         (foreach e lst
           (setq str (strcat (cadr e) " " str))
        ((= kword "E")
         (foreach e lst
           (setq str (strcat (cadr e) "\n" str))
        ((= kword "A")
         (foreach e lst
           (setq str (strcat (cadr e) str))
  (command "MTEXT" pt "H" zg "W" 0 str "")
  (princ "\n★提示:文字合并完成.\n")
  (setvar "aunits" oldaun)
  (command "undo" "e")
;;;*****文字合并 程序结束****
最佳答案
查看完整内容
;這樣嗎 ;;;*****文字合并换行 程序开始***** (defun c:hbh (/ lst) (setq oldaun (getvar "aunits")) (setvar "aunits" 3) (setvar "osmode" 15359) ...
发表于 2021-1-20 09:07:34 | 显示全部楼层
wgij007 发表于 2021-1-21 11:39
可能我表达不清楚,我想说的是不选择空格与换行,直接执行空格或换行两种代码.
;這樣嗎
  (setvar "aunits" 3)
  (setvar "osmode" 0)
  (setq lst '())
          ss  (ssdel entnam ss)                ;选择集中删除当前的文字对像
    (entdel entnam)                        ;删除文字对像
  (setq
    lst
     (vl-sort lst
(function
                (lambda        (e1 e2)
  (setq str "")
  (foreach e lst
;;;*****文字合并换行 程序结束****
;;;*****文字合并空格 程序开始*****
(defun c:hb (/ lst)
  (setvar "aunits" 3)
  (setvar "osmode" 0)
  (setq lst '())
  (setq
    lst
     (vl-sort lst
(function
                (lambda        (e1 e2)
  (setq str "")
  (foreach e lst
;;;*****文字合并空格 程序结束****
发表于 2021-1-20 10:48:56 | 显示全部楼层
(princ "\n★功能:文字合并。\n \n");這行可以拿掉
  (setq ss (ssget "X" '((0 . "MTEXT,TEXT")))) ;在這行加"X"就會自動把所有的文字合并了
 楼主| 发表于 2021-1-21 11:39:04 | 显示全部楼层
  (setq ss (ssget "X" '((0 . "MTEXT,TEXT")))) ;在 ...
 楼主| 发表于 2021-1-21 17:04:15 | 显示全部楼层
感谢
GMT+8, 2025-5-17 06:58 , Processed in 0.171747 second(s), 25 queries , Gzip On.
