- 积分
- 13762
- 明经币
- 个
- 注册时间
- 2007-1-15
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
如果复制下面的代码如果有问题 请到晓东下载lsp
http://bbs.xdcad.net/thread-727707-1-1.html
;手动替换字体,命令tzt
(defun c:tzt() (GL:changefont))
;替换字体
(defun GL:changefont ( / *error* a b c d date1 e err font_chn font_eng font_lst_chn font_lst_eng font_lst_tru font_tru textstyles x)
(setq font_eng "tssdeng.shx" ;tssdeng.shx英文字体,自行修改
font_chn "tssdchn.shx" ;tssdchn.shx中文字体,自行修改
font_tru "宋体" ;windows系统字体,自行修改
font_lst_eng '()
font_lst_chn '()
font_lst_tru '()
(defun *error* (msg) ;错误处理
(setvar "regenmode" 1)
(command "undo" "e")
(setvar "cmdecho" 1)
(princ msg)
(vl-load-com)
(setvar "cmdecho" 0)
(command "undo" "be")
(setvar "regenmode" 0)
(setq date1 (getvar "millisecs"))
(setq textstyles (vla-get-textstyles (vla-get-activedocument (vlax-get-acad-object))))
(vlax-for x textstyles (vla-getfont x 'a 'b 'c 'd 'e) (if (= a "")
(if (and
(not (findfile (vla-get-fontfile x)))
(not (findfile (strcat (vla-get-fontfile x) ".shx")))
(vla-put-fontfile x font_eng)
(setq font_lst_eng (cons (vla-get-name x) font_lst_eng))
(if (and
(/= (vla-get-bigfontfile x) "")
(not (findfile (vla-get-bigfontfile x)))
(not (findfile (strcat (vla-get-bigfontfile x) ".shx")))
(vla-put-bigfontfile x font_chn)
(setq font_lst_chn (cons (vla-get-name x) font_lst_chn))
(setq err (vl-catch-all-apply 'vla-setfont (list x a b c d e)))
(if (vl-catch-all-error-p err)
(vla-setfont x font_tru b c d e)
(setq font_lst_tru (cons (vla-get-name x) font_lst_tru))
(command "regen")
(princ "\n")
(if (or font_lst_eng font_lst_chn font_lst_tru)
(princ (strcat "字体替换完成,共耗时" (rtos (/ (- (getvar "millisecs") date1)1000.000) 2 3) "秒。 "))
(if font_lst_eng (progn (princ "文字样式:")(princ font_lst_eng)(princ (strcat "的英文字体已替换为" font_eng "。 "))))
(if font_lst_chn (progn (princ "文字样式:")(princ font_lst_chn)(princ (strcat "的中文字体已替换为" font_chn "。 "))))
(if font_lst_tru (progn (princ "文字样式:")(princ font_lst_tru)(princ (strcat "的字体已替换为" font_tru "。 "))))
(princ "\n所有字体均存在,未替换")
;开图自动替换字体
(GL:changefont)
----------------------------------c#版本-------------------------------------------
2021.3.2增加c#版本
源码来自 http://blog.sina.com.cn/s/blog_69e8fdf00100nc58.html 版权归原作者所有,感谢!
本人修改了几处代码并重新编译以适应高版本CAD
使用方法:
1、将DLL文件设为自动加载(不会设的设置的可以参看我发的lisp+c#混合编程帖子的lisp代码)。
2、开图使用Hztxt.shx自动替换未知字体,所以你的CAD至少得有Hztxt.shx字体。
3、DLL可以单独使用,也可以和上面的lisp代码组合使用,当然如果要用DLL就不能干掉字体替换对话框了(干掉C#程序就没法自动选择字体了),不干掉字体选择对话框lisp也是可以自动替换的。
原理:开图出现字体选择对话框时,自动选择Hztxt.shx字体替换未知字体(可以理解为模拟按键,代替手动选择)
明经现在上传不了附件 请到晓东下载DLL文件
修改后的C#源码如下
 - using System.Text;
- using Autodesk.AutoCAD.ApplicationServices;
- using Autodesk.AutoCAD.EditorInput;
- using Autodesk.AutoCAD.Runtime;
- using System.Runtime.InteropServices;
- using System.Threading;
- namespace ChangeFonts
- class PublicTxtIndex
- public static Thread TxtIndex;//声明一个静态变量
- public static Thread PublicTxtIndexN
- get
- return TxtIndex;
- set
- TxtIndex = value;
- public class Init : IExtensionApplication
- public void Initialize()
- Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
- ed.WriteMessage("MOKACAD插件初始化完成。");
- //启动事件
- ChangeFontEvent GoChange = new ChangeFontEvent();
- GoChange.addEvents();
- public void Terminate()
- //程序结束,在里做一些程序的清理工作
- public class ChangeFontEvent
- DocumentCollection CreatNew = Application.DocumentManager;
- DLLChange.GOON dochange = new DLLChange.GOON();
- void documentCreateStarted(object sender, DocumentCollectionEventArgs e)
- try
- //如果这个时候还没有文档(原一个文档都没有,那到这里就要CAD致命错误)
- ed.WriteMessage("开始自动替换字体");
- catch
- Thread thread1 = new Thread(new ThreadStart(dochange.Reportfont));
- PublicTxtIndex.PublicTxtIndexN = thread1;
- StartOrAbort(true);
- //打开或关闭
- void StartOrAbort(bool flag)
- if (flag == true)//如果需要开启
- PublicTxtIndex.PublicTxtIndexN.Start();
- else
- PublicTxtIndex.PublicTxtIndexN.Abort(); //终止线程
- void documentCreated(object sender, DocumentCollectionEventArgs e)
- StartOrAbort(false);
- ed.WriteMessage("自动替换字体结束");
- public void addEvents()
- //把事件处理函数与相应的事件进行连接
- CreatNew.DocumentCreateStarted += new DocumentCollectionEventHandler(documentCreateStarted);
- CreatNew.DocumentCreated += new DocumentCollectionEventHandler(documentCreated);
- public void removeEvents()
- //断开所有的事件处理函数
- CreatNew.DocumentCreateStarted -= new DocumentCollectionEventHandler(documentCreateStarted);
- CreatNew.DocumentCreated -= new DocumentCollectionEventHandler(documentCreated);
- namespace DLLChange
- public delegate bool CallBack(int hwnd, int y);
- public class GOON
- #region API声明
- [DllImport("user32.dll")]
- public static extern int EnumWindows(CallBack x, int y);
- [DllImport("user32.dll", EntryPoint = "EnumChildWindows")]//枚举子窗体
- public static extern bool EnumChildWindows(int hwndParent, CallBack EnumFunc, int lParam);
- [DllImport("User32.dll", EntryPoint = "FindWindow")]//找指定窗体
- private static extern int FindWindow(string lpClassName, string lpWindowName);
- [DllImport("user32")]
- public static extern int GetWindowText(int hwnd, StringBuilder lptrString, int nMaxCount);
- public static extern int IsWindowVisible(int hwnd);
- [DllImport("User32.Dll")]
- public static extern void GetClassName(int hwnd, StringBuilder s, int nMaxCount);
- [DllImport("user32.dll", EntryPoint = "SendMessage", CharSet = CharSet.Ansi)]
- public static extern int SendMessage(int hwnd, int msg, int wParam, int lParam);
- [DllImport("User32.dll", EntryPoint = "SendMessage", CharSet = CharSet.Ansi)]
- public static extern int SendMessage(int hWnd, int uMsg, int wParam, StringBuilder lParam);
- const int LB_SETTOPINDEX = 0x0197;
- const int LB_SETCURSEL = 0x0186;
- const int LB_GETCOUNT = 0x18B;
- const int WM_GETTEXT = 0x000D;
- const int BM_CLICK = 0x00F5;
- const int VK_UP = 0x26;//方向键
- const int VK_DOWN = 0x28;
- const int WM_CHAR = 0x102;
- const int WM_KEYDOWN = 0x100;
- #endregion
- #region 相当于public变量
- class ClassSqlString
- public static int SqlString;//声明一个静态变量
- public static int GlobalUserName
- get
- return SqlString;
- set
- SqlString = value;
- class PublicButtonHwnd
- public static int ButtonHwnd;//声明一个静态变量
- public static int YButtonHwnd
- get
- return ButtonHwnd;
- set
- ButtonHwnd = value;
- public static int TxtIndex;//声明一个静态变量
- public static int PublicTxtIndexN
- get
- return TxtIndex;
- set
- TxtIndex = value;
- #endregion
- #region 查找AutoCAD替换字体的窗口,返回得到这个窗口的句柄
- public bool Report(int hwnd, int lParam)
- if (IsWindowVisible(hwnd) == 1)
- //if (pHwnd == 0 && IsWindowVisible(hwnd) == 1)
- StringBuilder sb = new StringBuilder(512);
- GetWindowText(hwnd, sb, sb.Capacity);
- string CadString;
- CadString = sb.ToString();
- if (CadString.Length > 7 && CadString.Substring(0, 7) == "指定字体给样式")
- {//找到字体窗口
- ClassSqlString.GlobalUserName = hwnd;
- return false;
- return true;
- #endregion
- #region 在这个替换字体的主窗口内查找子窗口
- public bool Reportfa(int hwnd, int lParam)//循环查找替换listbox
- string lpszParentClass = "ListBox"; //整个窗口的类名
- StringBuilder sbClassName = new StringBuilder(255);
- GetClassName(hwnd, sbClassName, 255);
- //由于现查找到这个确定按钮,所以先设置这个值
- if (sbClassName.ToString() == "Button")
- StringBuilder strButton = new StringBuilder(10);//用来存放窗口标题
- GetWindowText(hwnd, strButton, strButton.Capacity);
- if (strButton.ToString() == "确定")
- PublicButtonHwnd.YButtonHwnd = hwnd;//得到确定的按钮
- if (lpszParentClass == sbClassName.ToString())
- //找到一个listbox,就看他的标题是不是空,空的舍弃
- StringBuilder str = new StringBuilder(512);//用来存放窗口标题
- GetWindowText(hwnd, str, str.Capacity);
- string strEnd = string.Empty;
- strEnd = str.ToString();//转换为字符串
- if (strEnd.Length > 0)//如果长度大于0,就找到这个啦
- if (PublicTxtIndex.PublicTxtIndexN == 0)
- GetfontIndex(hwnd);
- //设置listbox值
- SendMessage(hwnd, LB_SETCURSEL, PublicTxtIndex.PublicTxtIndexN, 0);
- //下移一行
- SendMessage(hwnd, WM_KEYDOWN, VK_DOWN, 0);
- //发送确定按钮
- SendMessage(PublicButtonHwnd.YButtonHwnd, BM_CLICK, 0, 0);
- return false;
- return true;
- #endregion
- #region 得到hztxt.shx的位置,设置PublicTxtIndexN
- public void GetfontIndex(int hwnd)
- //先查找一共有多少项
- int ListCount;
- ListCount = SendMessage(hwnd, LB_GETCOUNT, 0, 0);
- StringBuilder strshx = new StringBuilder(60);//用来存放窗口标题 原版为20 现改为用60个字符-CAD高版本要多一些内存才行
- for (int i = 0; i <= ListCount - 1; i++)
- //设定某项来比较
- SendMessage(hwnd, LB_SETCURSEL, i, 0);
- SendMessage(hwnd, WM_GETTEXT, strshx.Capacity, strshx);
- //if (strshx.ToString() == "hztxt.shx|1|0000000") //原版代码
- if (strshx.ToString().Substring(0, 9) == "hztxt.shx")
- //MessageBox.Show(strshx.ToString());
- //得到hztxt前一个值
- PublicTxtIndex.PublicTxtIndexN = i - 1;
- break;
- #endregion
- //循环查找替换
- public void Reportfont()
- // Process[] ProcArray = Process.GetProcesses();
- int Nub = 1;
- while (Nub > 0)
- EnumWindows(this.Report, 0);//这里会得到下面的kaka的值
- int kaka;
- kaka = ClassSqlString.GlobalUserName;//替换字体的对话框的句柄
- EnumChildWindows(kaka, this.Reportfa, 0);
- //this.DoEvents();
