- 积分
- 5883
- 明经币
- 个
- 注册时间
- 2019-11-2
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
3明经币
求帮助改一段程序,出处明经,忘了那个贴了,如有侵犯请提出,必改。能不能改为,打散后,不变图层与颜色。
;;;*****分解文字 程序开始*****
(defun c:tu (/ PtList)
(setvar "cmdecho" 0)
(setvar "osmode" 15359)
(princ "\n★功能:将文字分解为曲线。\n提示:若出现变变换错误,请先将UCS设置为默认。\n")
(command "undo" "be")
(princ "\n请选取要分解为曲线的文字:")
(setq ss (ssget '((0 . "TEXT,MTEXT"))))
(if (not ss)
(progn (princ "\n提示:未选中文字,程序退出!\n") (exit))
(setvar "mirrtext" 1)
(setvar "osmode" 0)
(setq i 0)
(repeat (setq num (sslength ss))
(setq entnam (ssname ss i))
(command "zoom" "o" entnam "")
(setq PixelSize (getvar "screensize")
;以像素为单位读取当前视口大小(X 和 Y)
ViewHeigh (getvar "viewsize");以图形单位测量当前视口中显示的视图的高度
ViewCenter (getvar "viewctr") ;以UCS坐标表示当前视口中的视图的中心
PtList (list (list (- (car ViewCenter)
(* 0.5
(* ViewHeigh
(/ (car PixelSize)
(cadr PixelSize)
(- (cadr ViewCenter) (* 0.5 ViewHeigh))
) ;视窗区左下角的坐标点
(list (+ (car ViewCenter)
(* 0.5
(* ViewHeigh
(/ (car PixelSize)
(cadr PixelSize)
(+ (cadr ViewCenter)
(* 0.5 ViewHeigh)
) ;视窗区右上角的坐标点
LTPoint (list (caar PtList) ;视窗区左下角的X坐标
(cadadr PtList) ;视窗区右上角的Y坐标
(setq TempFil (strcat (getenv "Temp") "\\textb.wmf"))
(command "mirror" entnam "" ViewCenter "@0,1" "y") ;以Y轴镜像
(command "wmfout" TempFil
entnam ""
"erase" entnam
"" "wmfin"
TempFil LTPoint
"2.0" ""
(command "mirror" (entlast) "" ViewCenter "@0,1" "y") ;以Y轴镜像
(setq entnam2 (vlax-ename->vla-object (entlast)))
(setq list1 (vlax-safearray->list
(vlax-variant-value (vla-explode entnam2))
list2 nil
list3 nil
(foreach entnam3 list1
(if (eq (vla-get-ObjectName entnam3) "AcDbLine")
(setq entnam41 (vlax-curve-getpointatparam
entnam3
(/ (vlax-curve-getendparam entnam3) 2.0)
entnam42 (strcat (rtos (car entnam41) 2 8)
(rtos (cadr entnam41) 2 8)
(if (setq entnam43 (assoc entnam42 list3))
(vla-delete entnam3)
(vla-delete (cadr entnam43))
(setq list3 (cons (list entnam42 entnam3) list3))
(setq list2
(append (vlax-safearray->list
(vlax-variant-value (vla-explode entnam3))
list2
(foreach entnam3 list2
(if (eq (vla-get-length entnam3) 0.0)
(if (not (vlax-erased-p entnam3))
(setq entnam41 (vlax-curve-getstartpoint entnam3)
entnam41 (vlax-curve-getendpoint entnam3)
entnam44 (strcat entnam42
entnam45 (strcat (rtos (car entnam41) 2 8)
entnam42
(if (or (setq entnam43 (assoc entnam44 list3))
(setq entnam43 (assoc entnam45 list3))
(if (not (vlax-erased-p (cadr entnam43)))
(setq list3 (cons (list entnam44 entnam3) list3))
(vla-delete entnam2)
(setq i (1+ i))
(command "zoom" "p")
(vl-file-delete TempFil)
(setvar "mirrtext" 0)
(setvar "osmode" 167)
(command "undo" "e")
(princ (strcat "\n提示:共将" (itoa num) "个文字对象成功分解为曲线。\n"))
;;;*****分解文字 程序结束*****
最佳答案
查看完整内容
(setq clayer (getvar "clayer"))
(if (not ss)
(progn (princ "\n提示:未选中文字,程 ...
