2623| 10
[提问] 求帮忙改代码,清除重线。 |
3明经币
最佳答案(defun C:lr ()
(princ "\n★功能:删除重复的直线、圆弧.\n提示:只可删除在相同图层的重线!")
(setvar "cmdecho" 0)
(setvar "plinewid" 0)
(command "undo" "be")
(vl-load-com)
(if (not (setq ss (ssget "p" '((0 . "ARC,LINE")))))
(setq ss (ssget '((0 . "ARC,LINE"))))
;(setq Nme (getstring "\n请输入图层名称"))
;(if (or (= 33 (ascii Nme))(= 0 (ascii Nme)))
(setq Nm ...
