查看: 1214|回复: 1
[提问] 如何插入外部块
发表于 2021-4-2 20:44:50 | 显示全部楼层 |阅读模式
如何插入外部块
发表于 2021-4-3 08:57:46 | 显示全部楼层
  1. (@:add-menu "文件布图" "等距插入" "(at-dwgfiles:insert-files)" )
  2. (defun at-dwgfiles:insert-files (/ dir i%)
  3.   (@:help (strcat "输入一个目录,然后在绘图区点击两个点,按两点的角度和距离排入图纸。"))
  4.   (push-var)
  5.   (setvar "osmode" 0)
  6.   (setvar "attreq" 0)
  7.   (if (setq dir (system:get-folder "请选择要插入dwg文件所在的目录"))
  8.       (progn
  9.         (setq i% 0)
  10.         (setq pt (getpoint "请输入第一点:"))
  11.         (setq pt2 (getpoint pt "请输入第二点,用于确定图块排列方式:"))
  12.         (foreach dwg (vl-directory-files dir "*.dwg" 1)
  13.                  (command "-insert" (strcat dir "\\" dwg) (polar pt (angle pt pt2) (* i% (distance pt pt2)))  "1" "1" "0" )
  14.                  (setq i% (1+ i%)))))
  15.   (pop-var)
  16.   )
GMT+8, 2025-10-2 05:05 , Processed in 0.161200 second(s), 26 queries , Gzip On.
