查看: 1100|回复: 8
[提问] 求帮修改一下代码,显视删除数量
发表于 2021-4-8 11:58:18 | 显示全部楼层 |阅读模式
1明经币
(defun c:tt (/ center center-lst dxf lst name radius ss temp)
        (if (setq ss (ssget '((0 . "CIRCLE"))))
                        (while (setq name (ssname ss 0))
                                (setq dxf (entget name))
                                (setq Center (cdr (assoc 10 dxf)))
                                (setq radius (cdr (assoc 40 dxf)))
                                (setq lst (append lst (list (list Center radius name))))
                                (ssdel name ss)
                        (foreach x lst
                                (if (not (member (car x) Center-lst))
                                        (setq Center-lst (append Center-lst (list (car x))))
                        (foreach x Center-lst
                                (setq temp nil)
                                (foreach xx lst
                                        (if (equal (car xx) x)
                                                (setq temp (append temp (list (list (cadr xx) (caddr xx)))))
                                (setq temp (cdr (vl-sort temp '(lambda (a b)
      (< (car a) (car b))
                                (foreach x temp
                                        (entdel (cadr x))
感谢
发表于 2021-4-8 11:58:19 | 显示全部楼层
  1. (defun c:tt1 (/ center center-lst dxf lst name radius ss temp n)
  2.   (if (setq ss (ssget '((0 . "CIRCLE"))))
  3.     (progn
  4.       (while (setq name (ssname ss 0))
  5.         (setq dxf (entget name))
  6.         (setq Center (cdr (assoc 10 dxf)))
  7.         (setq radius (cdr (assoc 40 dxf)))
  8.         (setq lst (append lst (list (list Center radius name))))
  9.         (ssdel name ss)
  10.       )
  11.       (foreach x lst
  12.         (if (not (member (car x) Center-lst))
  13.           (setq Center-lst (append Center-lst (list (car x))))
  14.         )
  15.       )
  16.       (setq n 0 )
  17.       (foreach x Center-lst
  18.         (setq temp nil)
  19.         (foreach xx lst
  20.           (if (equal (car xx) x)
  21.             (setq temp (append temp (list (list (cadr xx) (caddr xx)))))
  22.           )
  23.         )
  24.         (setq temp (cdr (vl-sort temp '(lambda (a b)
  25.                                          (< (car a) (car b))
  26.                                        ))))
  27.         (foreach x temp
  28.           (entdel (cadr x))(setq n (1+ n))
  29.         )
  30.       )
  31.       (princ "删了")
  32.       (princ n )
  33.     )
  34.   )
  35.   (princ)
  36. )
发表于 2021-4-8 12:12:43 | 显示全部楼层
选择对象: 指定对角点: 找到 ****个
 楼主| 发表于 2021-4-8 13:34:05 | 显示全部楼层
要的是要显视,删了多少个
发表于 2021-4-8 15:18:55 | 显示全部楼层
 楼主| 发表于 2021-4-8 18:10:52 | 显示全部楼层
发表于 2021-4-8 19:11:50 | 显示全部楼层
你这个代码  是删除啥情况下的圆呀,没看明白,求指教
 楼主| 发表于 2021-4-8 20:30:31 | 显示全部楼层
同心圆,只留最小的,做刀路时,处理牙孔用到。
发表于 2021-4-20 14:21:21 | 显示全部楼层
能加上容差就好了,因为CAD数据图上误差0.000001毫米的圆心也不是同心圆,无法删除。
GMT+8, 2025-10-2 04:42 , Processed in 0.174587 second(s), 25 queries , Gzip On.
