查看: 1121|回复: 5
[提问] Eentsel 选取对象问题
发表于 2021-4-14 10:03:49 | 显示全部楼层 |阅读模式
请大师指正一下,希望实现选取对象ractang是一个矩形,如果不是,继续选取。
  • (defun c:HV(/)
  •   (setvar "cmdecho" 0)
  •   (setq rectang (car(entsel"选择一个矩形")))
  •   (setq re_content (entget rectang))
  •   (setq Lst (mapcar 'cdr(vl-remove-if '(lambda (x) (/= (car x) 10)) re_content))
  •     s1 (nth 0 Lst)
  •     s2 (nth 1 Lst)
  •     s3 (nth 2 Lst)
  •     s4 (nth 3 Lst)
  •   (command "ucs" "z" "0")
  •   (command "plan" "")
  •   (command "ucs" "")
  •   (command "'-VIEW" "W" "v1" s2 s4)
  •   (command "'-VIEW" "R" "v1")
  •   (princ
发表于 2021-4-14 12:32:55 | 显示全部楼层
(while (/= name "AcDbrectang")
(and(setq en (car(entsel)))
(= (cdr(assoc 0(entget en))) "LWPOLYLINE")
(setq ob(vlax-ename->vla-object en))
(= (vlax-curve-getendparam ob) 4)
(setq a(vlax-curve-getDistAtParam ob 1))
(equal (vlax-curve-getArea ob)(* a (- (vlax-curve-getDistAtParam ob 2)a))1e-4)
(setq name "AcDbrectang")
发表于 2021-4-14 14:23:52 | 显示全部楼层
(defun c:tt (/ ss)
(while (= ss nil)
(OR (setq ss(ssget ":S" '((0 . "LWPOLYLINE"))))
  (princ "\n没选到"))
(princ "选到了")
(prin1)
 楼主| 发表于 2021-4-14 19:33:43 | 显示全部楼层
(= (cdr(assoc 0(entget en))) "LWPO ...
提示错误
error: bad argument type: consp nil
 楼主| 发表于 2021-4-14 19:34:57 | 显示全部楼层
菜卷鱼 发表于 2021-4-14 14:23
(defun c:tt (/ ss)
(while (= ss nil)
貌似不可以用ssget的,会出错,只能用entsel
发表于 2021-4-15 09:02:35 | 显示全部楼层
程序前加(vl-load-com)
选择前加(setq name nil)
GMT+8, 2025-10-2 04:39 , Processed in 0.189989 second(s), 25 queries , Gzip On.
