查看: 2499|回复: 4
[2022] 求AUTOCAD 2022的載點嗎?
发表于 2021-4-14 15:52:43 | 显示全部楼层 |阅读模式
AutoCAD 2022的載點嗎?
发表于 2021-4-15 16:24:33 | 显示全部楼层
啥意思?看不懂啊
发表于 2021-4-15 20:59:29 | 显示全部楼层
AutoCAD 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ACD/1E7D4EF7-A28E-3D3E-BA3C-C6FAE4AAB2E0/SFX/AutoCAD_2022_English_Win_64bit_dlm.sfx.exe
AutoCAD LT 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ACDLT/3E4FF57B-0533-3C99-A29F-C9E2838E11E5/SFX/AutoCAD_LT_2022_English_Win_64bit_dlm.sfx.exe
AutoCAD Mechanical 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/AMECH_PP/82C320DD-8EC4-3382-A19F-1AB2019EEFCE/SFX/AutoCAD_Mechanical_2022_English_Win_64bit_dlm.sfx.exe
AutoCAD Architecture 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ARCHDESK/6CE4BFB0-EB1D-3003-9B66-9D421F8291D8/SFX/AutoCAD_Architecture_2022_English_Win_64bit_dlm_001_002.sfx.exe
https://efulfillment.autodesk.com/NetSWDLD/2022/ARCHDESK/6CE4BFB0-EB1D-3003-9B66-9D421F8291D8/SFX/AutoCAD_Architecture_2022_English_Win_64bit_dlm_002_002.sfx.exe
AutoCAD Electrical 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ACAD_E/EE9C996C-F54A-349E-A913-64C473E5F053/SFX/AutoCAD_Electrical_2022_English_Win_64bit_dlm_001_002.sfx.exe
https://efulfillment.autodesk.com/NetSWDLD/2022/ACAD_E/EE9C996C-F54A-349E-A913-64C473E5F053/SFX/AutoCAD_Electrical_2022_English_Win_64bit_dlm_002_002.sfx.exe
AutoCAD LT MAC 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ACDLTM/06FE3ADB-2404-3D20-B984-D191B8F1FE90/ESD/Autodesk_AutoCAD_LT_2022_macOS.dmg
AutoCAD MAC 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ACDMAC/CE8FF7BA-4B63-38FC-A60C-B14579EDCE3F/ESD/Autodesk_AutoCAD_2022_macOS.dmg
Autocad Raster Design 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ARDES/1A008B84-B302-3FAB-AD26-D598D5D2660D/SFX/AutoCAD_Raster_Design_2022_English_Win_64bit_dlm.sfx.exe
Navisworks Manage 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/NAVMAN/C132C0F6-7203-34CF-B8A4-F5A68F1DD494/SFX/Autodesk_Navisworks_Manage_2022_Win_64bit_dlm_001_002.sfx.exe
https://efulfillment.autodesk.com/NetSWDLD/2022/NAVMAN/C132C0F6-7203-34CF-B8A4-F5A68F1DD494/SFX/Autodesk_Navisworks_Manage_2022_Win_64bit_dlm_002_002.sfx.exe
Vault Basic 2022
Server:https://efulfillment.autodesk.com/NetSWDLD/2022/INVVAU/3210F0E3-1011-4A49-89E5-6B9BD0F30084/SFX/VBS2022_ENU_64bit_dlm.sfx.exe
Client:https://efulfillment.autodesk.com/NetSWDLD/2022/PLC0000006/7ECC8B5B-9B80-3DFF-824E-D60582BEEECC/SFX/VBC2022_ENU_64bit_dlm.sfx.exe
Point Layout 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/PNTLAY/978DBE07-1F07-30CA-8CD4-D4BE1C97F5DC/SFX/Autodesk_Point_Layout_2022_Win_32_64bit_dlm.sfx.exe
Vault Basic
Server 2022:https://dds.autodesk.com/NetSWDLD/2022/INVVAU/3210F0E3-1011-4A49-89E5-6B9BD0F30084/SFX/VBS2022_ENU_64bit_dlm.sfx.exe
Client 2022:https://dds.autodesk.com/NetSWDLD/2022/PLC0000006/7ECC8B5B-9B80-3DFF-824E-D60582BEEECC/SFX/VBC2022_ENU_64bit_dlm.sfx.exe
Navisworks Simulate 2022
https://dds.autodesk.com/NetSWDLD/2022/NAVSIM/1C47B54C-DC8E-3B8B-BE6A-B9A43506452F/SFX/Autodesk_Navisworks_Simulate_2022_Win_64bit_dlm_001_002.sfx.exe
AutoCAD Map 3D 2022
https://dds.autodesk.com/NetSWDLD/2022/MAP/26212EB2-57B3-3645-B9D6-A7754F91717F/SFX/AutoCAD_Map_2022_English_Win_64bit_dlm_001_002.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/MAP/26212EB2-57B3-3645-B9D6-A7754F91717F/SFX/AutoCAD_Map_2022_English_Win_64bit_dlm_002_002.sfx.exe
AutoCAD Plant 3D 2022
https://dds.autodesk.com/NetSWDLD/2022/PLNT3D/6D0F56E4-48FB-3AC2-AD42-19667DAD54B7/SFX/AutoCAD_Plant_3D_2022_English_Win_64bit_dlm_001_002.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/PLNT3D/6D0F56E4-48FB-3AC2-AD42-19667DAD54B7/SFX/AutoCAD_Plant_3D_2022_English_Win_64bit_dlm_002_002.sfx.exe
AutoCAD MEP 2022
https://dds.autodesk.com/NetSWDLD/2022/BLDSYS/5F7A4C13-961C-344F-BD80-55CE1A455B7E/SFX/AutoCAD_MEP_2022_English_Win_64bit_dlm_001_003.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/BLDSYS/5F7A4C13-961C-344F-BD80-55CE1A455B7E/SFX/AutoCAD_MEP_2022_English_Win_64bit_dlm_002_003.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/BLDSYS/5F7A4C13-961C-344F-BD80-55CE1A455B7E/SFX/AutoCAD_MEP_2022_English_Win_64bit_dlm_003_003.sfx.exe
3DS MAX 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/3DSMAX/B2EF7E27-4824-3656-A115-BFF401F11F7C/SFX/Autodesk_3ds_Max_2022_EFGJKPS_Win_64bit_004_004.sfx.exe
MotionBuilder 2022
https://dds.autodesk.com/NetSWDLD/2022/MOBPRO/330EFCEA-0952-3C68-842C-69A9FEB04127/SFX/Autodesk_MB_2022_ML_Windows_64bit_dlm.sfx.exe
MAYA 2022
https://dds.autodesk.com/NetSWDLD/2022/MAYA/9D725D29-4BE6-3ED9-A585-F4D5E20CECEE/SFX/Autodesk_Maya_2022_ML_Windows_64bit_dlm_001_002.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/MAYA/9D725D29-4BE6-3ED9-A585-F4D5E20CECEE/SFX/Autodesk_Maya_2022_ML_Windows_64bit_dlm_002_002.sfx.exe
3ds Max Interactive
https://dds.autodesk.com/NetSWDLD/2019/3DSMXI/1F8CD3FB-7A7C-425A-9815-B65C238DA830/SFX/Autodesk_3ds_Max_Interactive_2_5_0_0_EN_Win_64bit_dlm.sfx.exe
3ds Max 2022
https://dds.autodesk.com/NetSWDLD/2022/3DSMAX/B2EF7E27-4824-3656-A115-BFF401F11F7C/SFX/Autodesk_3ds_Max_2022_EFGJKPS_Win_64bit_001_004.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/3DSMAX/B2EF7E27-4824-3656-A115-BFF401F11F7C/SFX/Autodesk_3ds_Max_2022_EFGJKPS_Win_64bit_002_004.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/3DSMAX/B2EF7E27-4824-3656-A115-BFF401F11F7C/SFX/Autodesk_3ds_Max_2022_EFGJKPS_Win_64bit_003_004.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/3DSMAX/B2EF7E27-4824-3656-A115-BFF401F11F7C/SFX/Autodesk_3ds_Max_2022_EFGJKPS_Win_64bit_004_004.sfx.exe
Autodesk Navisworks Freedom 2022
https://dds.autodesk.com/NetSWDLD/2022/NAVFREE/087B95DF-F444-3F18-B633-4A7A0A0488A4/SFX/Autodesk_Navisworks_Freedom_2022_Win_64bit_dlm.sfx.exe
Autodesk Navisworks NWC Export Utility 2022
https://dds.autodesk.com/NetSWDLD/2022/PLC0000012/05406BA4-DDA2-3639-A844-5477CB26DED0/SFX/Autodesk_Navisworks_Exporters_2022_Win_64bit_dlm.sfx.exe
Autodesk Mudbox 2022
https://dds.autodesk.com/NetSWDLD/2022/MBXPRO/293D17F8-F7B0-33BA-82A8-6300BB870032/SFX/Autodesk_Mudbox_2022_ML_Win_64bit_dlm.sfx.exe
Maya 2022 Mac
https://efulfillment.autodesk.com/NetSWDLD/2022/MAYA/1E192D76-1C3B-3CC3-82EF-7A45EE23E312/ESD/Autodesk_Maya_2022_ML_macOS.dmg
Autodesk Inventor Professional 2022
http://trial2.autodesk.com/NetSWDLD/2022/INVPROSA/15FAE334-7AC7-3147-BA02-CD075026EA49/SFX/Inventor_Pro_2022_English_Win_64bit_Dlm_001_003.sfx.exe
http://trial2.autodesk.com/NetSWDLD/2022/INVPROSA/15FAE334-7AC7-3147-BA02-CD075026EA49/SFX/Inventor_Pro_2022_English_Win_64bit_Dlm_002_003.sfx.exe
http://trial2.autodesk.com/NetSWDLD/2022/INVPROSA/15FAE334-7AC7-3147-BA02-CD075026EA49/SFX/Inventor_Pro_2022_English_Win_64bit_Dlm_003_003.sfx.exe
Revit 2022
https://trial2.autodesk.com/NetSWDLD/2022/RVT/03BD6A4A-C858-3AD2-9353-DF2974C9918B/SFX/Revit_2022_G1_Win_64bit_dlm_001_005.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2022/RVT/03BD6A4A-C858-3AD2-9353-DF2974C9918B/SFX/Revit_2022_G1_Win_64bit_dlm_002_005.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2022/RVT/03BD6A4A-C858-3AD2-9353-DF2974C9918B/SFX/Revit_2022_G1_Win_64bit_dlm_003_005.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2022/RVT/03BD6A4A-C858-3AD2-9353-DF2974C9918B/SFX/Revit_2022_G1_Win_64bit_dlm_004_005.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2022/RVT/03BD6A4A-C858-3AD2-9353-DF2974C9918B/SFX/Revit_2022_G1_Win_64bit_dlm_005_005.sfx.exe
Revit LT 2022
https://dds.autodesk.com/NetSWDLD/2022/RVTLT/78B46141-E345-3230-A38E-CC9F925C2859/SFX/RevitLT_2022_G1_Win_64bit_dlm_001_004.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/RVTLT/78B46141-E345-3230-A38E-CC9F925C2859/SFX/RevitLT_2022_G1_Win_64bit_dlm_002_004.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/RVTLT/78B46141-E345-3230-A38E-CC9F925C2859/SFX/RevitLT_2022_G1_Win_64bit_dlm_003_004.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/RVTLT/78B46141-E345-3230-A38E-CC9F925C2859/SFX/RevitLT_2022_G1_Win_64bit_dlm_004_004.sfx.exe
Factory Design Utilities 2022
https://dds.autodesk.com/NetSWDLD/2022/FDU/D3FD82EF-BFC3-33C7-8464-0A9013F62186/SFX/FDU_2022_EN_WIN_64BIT_DLM.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/FDU/876C0776-3291-34BF-A904-27B1309BE089/SFX/FDU_2022_RU_WIN_64BIT_DLM.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/FDU/6D73124F-9780-34E3-94E9-42A38D7AD548/SFX/FDU_2022_FR_WIN_64BIT_DLM.sfx.exe
Inventor Nastran 2022
https://dds.autodesk.com/NetSWDLD/2022/NINCAD/FB876E4F-D23C-3BDC-A28A-A8CF318C5DF6/SFX/Autodesk_Inventor_Nastran_R0_2022_DLM.sfx.exe
Vault Office 2022
https://dds.autodesk.com/NetSWDLD/2022/PCOFFI/331199D6-C50D-3BDF-BFD7-E077A07E61E6/SFX/VPO2022_ENU_64bit_dlm_001_002.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/PCOFFI/331199D6-C50D-3BDF-BFD7-E077A07E61E6/SFX/VPO2022_ENU_64bit_dlm_002_002.sfx.exe
Vault Office - for Vault Workgroup users 2022
https://dds.autodesk.com/NetSWDLD/2022/VO4VWGU/1B4361C7-AACE-3348-A9E6-726123D89EB9/SFX/VWO2022_ENU_64bit_dlm.sfx.exe
Vault Professional 2022
https://dds.autodesk.com/NetSWDLD/2022/VLTM/A2C9BA8C-8A6B-477D-ADB6-E9918E55714B/SFX/VPS2022_ENU_64bit_dlm_001_002.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/VLTM/A2C9BA8C-8A6B-477D-ADB6-E9918E55714B/SFX/VPS2022_ENU_64bit_dlm_002_002.sfx.exe
Vault Professional Client 2022
https://dds.autodesk.com/NetSWDLD/2022/PLC0000004/547127E5-2B55-3E73-B51B-F13D5E7EF173/SFX/VPC2022_ENU_64bit_dlm_001_002.sfx.exe
https://dds.autodesk.com/NetSWDLD/2022/PLC0000004/547127E5-2B55-3E73-B51B-F13D5E7EF173/SFX/VPC2022_ENU_64bit_dlm_002_002.sfx.exe
Vault Workgroup 2022
https://dds.autodesk.com/NetSWDLD/2022/VLTWG/0E497705-1E5B-48CF-82A7-C0FC68039D7D/SFX/VWS2022_ENU_64bit_dlm.sfx.exe
Vault Workgroup Client 2022
https://dds.autodesk.com/NetSWDLD/2022/PLC0000005/AF37DE99-E596-369B-89A5-B0FC90BE688A/SFX/VWC2022_ENU_64bit_dlm.sfx.exe
Revit Infraworks Updater 2022
https://up.autodesk.com/2022/RVT/02ABF98D-9418-3115-BA25-D773D1F0F4AF/IWExportToRevit.exe
United Kingdom for Revit 2022
https://up.autodesk.com/2022/RVT/013E135A-0414-3D38-ACAA-AD84529FE856/RVTCPENG.exe
United States Content for Revit 2022
https://up.autodesk.com/2022/RVT/B8322C50-CA90-339E-80AD-A11ABA519F7E/RVTCPENU.exe
Solar Analysis for Revit 2022
https://up.autodesk.com/2022/RVT/5B7E1A99-CD96-3331-8495-7066B8291CF8/SolarAnalysis.exe
Roombook Areabook Buildingbook for Revit 2022
https://up.autodesk.com/2022/RVT/4D45061E-4CCE-3063-ACA1-D9AE44ED46F9/Roombook.exe
Robot Structural Analysis Extension for Revit 2022
https://up.autodesk.com/2022/RVT/60FC3C91-930E-36BB-9A38-4EB559B89A44/RobotStructuralAnalysisExtensionforRevit.exe
Revit DB Link 2022
https://up.autodesk.com/2022/RVT/0E551A34-625F-341A-8C6E-DA17FCCAC2CF/DBLink.exe
Lighting Analysis for Revit 2022
https://up.autodesk.com/2022/RVT/E433D021-A2E2-35D9-A12B-5DA286D977F4/LightingAnalysis.exe
BIM Interoperability Tools v8.0.7744.0 for Revit 2022
https://up.autodesk.com/2022/RVT/B62A978D-290F-388C-91FC-786B0040E624/BIMInteropTools2022_8_0_7744_0.exe
German Content for Revit 2022
https://up.autodesk.com/2022/RVT/69D22CB6-23CB-3B31-A8FE-BFCFA2953138/RVTCPDEU.exe
Japanese Content for Revit 2022
https://up.autodesk.com/2022/RVT/74907384-7487-3863-A3A5-F4301B5662B9/RVTCPJPN.exe
Fabrication CADmep 2022
https://dds.autodesk.com/NetSWDLD/2022/CADMEP/5A949850-5376-3453-A310-15496C9D36E5/SFX/CADMEP_2022_EN_WIN_64BIT_dlm.sfx.exe
Fabrication CAMduct 2022
https://dds.autodesk.com/NetSWDLD/2022/CAMDCT/4F454628-FB45-34A0-9953-6075E26335D9/SFX/CAMDCT_2022_EN_WIN_64BIT_dlm.sfx.exe
Fabrication ESTmep 2022
Advance Steel 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/ADSTPR/A6C08877-90C3-3396-81F4-F51C3D14D25F/SFX/Advance_Steel_2022_English_Win_64bit_dlm_001_002.sfx.exe
https://efulfillment.autodesk.com/NetSWDLD/2022/ADSTPR/A6C08877-90C3-3396-81F4-F51C3D14D25F/SFX/Advance_Steel_2022_English_Win_64bit_dlm_002_002.sfx.exe
Advance Steel 2022
https://trial2.autodesk.com/NetSWDLD/2022/ADSTPR/A6C08877-90C3-3396-81F4-F51C3D14D25F/SFX/Advance_Steel_2022_English_Win_64bit_dlm_001_002.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2022/ADSTPR/A6C08877-90C3-3396-81F4-F51C3D14D25F/SFX/Advance_Steel_2022_English_Win_64bit_dlm_002_002.sfx.exe
FormIt Pro 2022
https://trial2.autodesk.com/NetSWDLD/2022/FORMIT/F35ABF23-9561-36BA-ABCC-9B82E8CD667D/SFX/FormIt_English_Win_64bit_dlm.sfx.exe
Autodesk Robot Structural Analysis Professional 2022 (x64) Multilanguage
https://trial2.autodesk.com/NetSWDLD/2022/RSAPRO/F6641944-1AFB-30C4-95B1-4BE3B7CC2492/SFX/Robot_Structural_Analysis_Professional_2022_Multilingual_Win_64bit_dlm.sfx.exe
http://dds.autodesk.com/NetSWDLD/2022/PNTLAY/FA545307-9E85-311F-9FA0-5ACD2202340E/SFX/Autodesk_Point_Layout_2022_Win_32_64bit_dlm.sfx.exe
Mudbox for mac and Linux
https://trial2.autodesk.com/NetSWDLD/2022/MBXPRO/F0C953B7-7648-4977-B8A5-049204AAC7D5/ESD/Autodesk_Mudbox_2022_ML_macOS.dmg
https://trial2.autodesk.com/NetSWDLD/2022/MBXPRO/F6D847A7-0B32-410C-B1F6-C1F7D7BD7492/ESD/Autodesk_Mudbox_2022_ML_Linux64.tgz
Maya 2022 for mac and Linux
https://trial2.autodesk.com/NetSWDLD/2022/MAYA/1E192D76-1C3B-3CC3-82EF-7A45EE23E312/ESD/Autodesk_Maya_2022_ML_macOS.dmg
https://trial2.autodesk.com/NetSWDLD/2022/MAYA/7AA0A333-D72A-3C65-AB0F-0FE0F802014A/ESD/Autodesk_Maya_2022_ML_Linux_64bit.tgz
Offline Help for Maya 2022
https://download.autodesk.com/us/support/maya_user_guide/2022/autodesk-maya-user-guide-2022-1-htm-ade-2.1-en.zip
Offline Developer Help for Maya 2022
https://damassets.autodesk.net/content/dam/autodesk/files/maya-2022-developer-help_enu.zip
Maya 2022 devkit Downloads
https://autodesk-adn-transfer.s3-us-west-2.amazonaws.com/ADN+Extranet/M%26E/Maya/devkit+2022/Autodesk_Maya_2022_DEVKIT_Windows.zip
Offline Help for Mudbox 2022 (Windows Only)
https://download.autodesk.com/us/support/mudbox_2022/mudbox-2022-user-guide_enu_offline.zip
Offline Help for 3ds Max 2022
https://download.autodesk.com/us/support/3ds_max_2022_help/3dsmaxhelp2022_enu.exe
Autodesk 3ds Max 2022 MAXScript Help
https://download.autodesk.com/us/adn/products/3dsmax/2022/maxscript-2022-help.zip
Autodesk 3ds Max 2022 Python API Help
https://download.autodesk.com/us/adn/products/3dsmax/2022/3dsmax-2022-pythonapi-help.zip
https://download.autodesk.com/us/adn/products/3dsmax/2022/3dsmax-2022-pythonapi-help-chm.zip
Autodesk 3ds Max 2022 SDK
https://autodesk-adn-transfer.s3-us-west-2.amazonaws.com/ADN+Extranet/M%26E/Max/Autodesk+3ds+Max+2022/SDK_3dsMax2022.msi
Spanish Content for Revit 2022
https://up.autodesk.com/2022/RVT/C2445E35-54AC-3702-A509-7BF5CC67B8A4//RVTCPESP.exe
Russian Content for Revit 2022
https://up.autodesk.com/2022/RVT/0DE311E2-DA98-3B27-8F35-40939763ABE7//RVTCPRUS.exe
Polish Content for Revit 2022:
https://up.autodesk.com/2022/RVT/261D44C4-312C-3EA2-B578-865EE73B465C//RVTCPPLK.exe
Korean Content for Revit 2022:
https://up.autodesk.com/2022/RVT/0918C180-1BB5-3152-A8F8-FC225883A48F//RVTCPKOR.exe
Italian Content for Revit 2022:
https://up.autodesk.com/2022/RVT/7F57DBF2-079D-3E70-989C-7DD00DA707C9//RVTCPITA.exe
Czech Content for Revit 2022:
https://up.autodesk.com/2022/RVT/E8D54E74-9521-3F8B-BACF-FD3A2381CA2F//RVTCPCSY.exe
Chinese Traditional Content for Revit 2022:
https://up.autodesk.com/2022/RVT/EFEEFE3F-516F-3854-BCD4-5DB00222AFF6//RVTCPCHT.exe
Brazilian Portuguese Content for Revit 2022:
https://up.autodesk.com/2022/RVT/B9C42284-2173-3859-AA04-EE45CC2B3E19//RVTCPPTB.exe
International English - Thailand Content for Revit 2022:
https://up.autodesk.com/2022/RVT/005ABFBC-C8FE-3523-BA95-2AD5F7DC1974//RVTCPENTHAILAND.exe
International English - Sweden Content for Revit 2022:
https://up.autodesk.com/2022/RVT/C575DE4D-C597-37D6-B843-D18FD6B00401//RVTCPENSWEDEN.exe
International English - South Asia Pacific Content for Revit 2022:
https://up.autodesk.com/2022/RVT/F6CAA344-7CBA-3741-804C-417669299DAA//RVTCPENSASIA.exe
International English - South Africa Content for Revit 2022:
https://up.autodesk.com/2022/RVT/47CB21CB-4ECE-3859-A07E-D2FCAD13F9D8//RVTCPENSAFRICA.exe
International English - Singapore Content for Revit 2022:
https://up.autodesk.com/2022/RVT/6F2CEA7C-6231-3688-BCA1-24E2A22D4A2B//RVTCPENSINGAPORE.exe
International English - Romania Content for Revit 2022:
https://up.autodesk.com/2022/RVT/E3010F8F-4709-37A0-A350-EF9748E1448F//RVTCPENROMANIA.exe
autocad Update 2022.0.1
http://up.autodesk.com/2022/ACD/4FE06AED-7BE6-3578-8ACD-F8CF697A4318/AutoCAD_2022.0.1_Update.exe
Civil 3D 2022
https://efulfillment.autodesk.com/NetSWDLD/2022/CIV3D/10D9CD4B-857C-31F4-9BDD-281EA33D53A7/SFX/Autodesk_Civil_3D_2022_English_Win_64bit_dlm_001_002.sfx.exe
https://efulfillment.autodesk.com/NetSWDLD/2022/CIV3D/10D9CD4B-857C-31F4-9BDD-281EA33D53A7/SFX/Autodesk_Civil_3D_2022_English_Win_64bit_dlm_002_002.sfx.exe
Flame 2022
https://trial2.autodesk.com/NetSWDLD/2022/A250/48E6A226-9664-38BB-90EF-3CF084970782/ESD/Autodesk_Flame_Trial_2022_macOS.dmg
https://trial2.autodesk.com/NetSWDLD/2022/A250/8889D302-B27B-30F5-80C0-C3D74BAA5F64/ESD/autodesk_flame_trial_2022_LINUX64_CENTOS.tar
ReCap Pro 2022
https://trial2.autodesk.com/NetSWDLD/2022/RECAP/CF66BFA3-1B48-3CB1-9226-FBFA1850C192/SFX/ReCap_2022_G1_Win_64bit_dlm.sfx.exe
Alias Concept 2022
https://trial2.autodesk.com/NetSWDLD/2022/ALSCPT/D6EBD7C9-17C6-3723-BEBE-9B1AFBA3FBE8/SFX/Autodesk_ALSCPT_2022_0_Enu_64bit_dlm_001_002.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2022/ALSCPT/D6EBD7C9-17C6-3723-BEBE-9B1AFBA3FBE8/SFX/Autodesk_ALSCPT_2022_0_Enu_64bit_dlm_002_002.sfx.exe
Alias Surface 2022
https://trial2.autodesk.com/NetSWDLD/2022/SURFST/9BB1B9B8-30C6-35DA-8B5F-A3EA2C553506/SFX/Autodesk_SURFST_2022_0_Enu_64bit_dlm_001_002.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2022/SURFST/9BB1B9B8-30C6-35DA-8B5F-A3EA2C553506/SFX/Autodesk_SURFST_2022_0_Enu_64bit_dlm_002_002.sfx.exe
HSMWorks Ultimate 2022
https://trial2.autodesk.com/NetSWDLD/2022/HSMPRM/4403BB25-7F83-38F4-8ADF-687FF406E34D/SFX/HSMWorks_2022_ML_16_0_0_43892_Win_64Bit_dlm.sfx.exe
Inventor CAM Ultimate 2022
https://trial2.autodesk.com/NetSWDLD/2022/INHSMP/118D34EE-0E52-31F1-B7EB-81BBA147E237/SFX/INV_CAM_2022_ML_9_0_0_24791_Win_64Bit_dlm.sfx.exe
VRED Design 2022
https://trial2.autodesk.com/NetSWDLD/2022/VRDDES/977A8B24-672F-3F55-AD93-2B66B56D1C44/SFX/Autodesk_VREDDES_2022_0_Enu_Win_64bit_dlm.sfx.exe
VRED Professional 2022
https://trial2.autodesk.com/NetSWDLD/2022/VRDPRO/F0FF6C9F-8072-339A-8133-39C769660344/SFX/Autodesk_VREDPRO_2022_0_Enu_Win_64bit_dlm.sfx.exe
Vehicle Tracking 2022
http://dds.autodesk.com/NetSWDLD/2022/VEHTRK/B5E5E9F1-0C74-32D3-B1B2-978769BA6544/SFX/Autodesk_Vehicle_Tracking_2022_2404_Win_64bit_DLM.sfx.exe
发表于 2021-4-22 15:23:42 | 显示全部楼层
请问Autodesk Inventor Professional 2022有简体中文版的吗
GMT+8, 2025-7-2 01:06 , Processed in 0.177928 second(s), 23 queries , Gzip On.
