查看: 1200|回复: 3
[源码] (MBWP)打断于多边形(欢迎大佬们多给建议和意见)
发表于 2021-4-20 14:50:30 | 显示全部楼层 |阅读模式
  1. ;;说明:打断于多边形  by-忘霄 2021.4.20
  2. (defun C:MBWP(/ bf-list-split-3d breakapt edta ename ent eptlst getptlst interwithpt ss startbreak);c:MyBreakWithPolygon
  3.   (defun breakapt(ent elst iptlst / ilst)
  4.     (foreach e elst
  5.       (if (setq ilst (InterWithPt ent e))
  6.         (foreach p ilst
  7.           (if (not (member p iptlst))
  8.             (progn
  9.               (command "_.BREAK" e "_non" (trans p 0 1) "_non" (trans p 0 1))
  10.               ;(command "_.BREAK" e p "@")
  11.               (breakapt
  12.                 ent
  13.                 (if (and (= 1 (length (setq ips (InterWithPt ent e)))) (equal (car ips) p 1e-8))
  14.                   (vl-remove e (cons (entlast) elst))
  15.                   (if (and (= 1 (length (setq ips (InterWithPt ent (entlast))))) (equal (car ips) p 1e-8))
  16.                     elst
  17.                     (cons (entlast) elst)
  18.                   )
  19.                 )
  20.                 (cons p iptlst)
  21.               )
  22.             )
  23.           )
  24.         )
  25.       )
  26.     )
  27.   )
  28.   (defun InterWithPt(ent1 ent2 / bf-list-split-3d var)
  29.     (defun BF-list-split-3d (lst)
  30.       (if lst (cons (list (car lst) (cadr lst) (caddr lst)) (BF-list-split-3d (cdddr lst))))
  31.     )
  32.     (if (> (vlax-safearray-get-u-bound (setq var (vlax-variant-value (vla-IntersectWith (vlax-ename->vla-object ent1) (vlax-ename->vla-object ent2) acExtendNone))) 1) 1)
  33.       (BF-list-split-3d (vlax-safearray->list var))
  34.       nil
  35.     )
  36.   )
  37.   (defun getptlst(e) (mapcar 'cdr (vl-remove-if-not (function (lambda(x) (= 10 (car x)))) (entget e))))
  38.   (defun BF-list-split-3d (lst)
  39.     (if lst (cons (list (car lst) (cadr lst) (caddr lst)) (BF-list-split-3d (cdddr lst))))
  40.   )
  41.   (defun startbreak(ent ss / ient inlst n)
  42.     (setq n -1)
  43.     (while (setq ient (ssname ss (setq n (1+ n))))
  44.       (if (setq inlst (InterWithPt ent ient))
  45.         (breakapt ent (list ient) '())
  46.       )
  47.     )
  48.   )
  49.   (command "_.UNDO" "be")
  50.   (if (setq ent (car (entsel "\n请选择【直线】或者【由多段线构成的多边形】:")))
  51.     (progn
  52.       (setq ename (cdr (assoc 0 (setq edta (entget ent)))))
  53.       (cond
  54.         ((equal ename "LINE")
  55.           (setq ss (ssdel ent (ssget "F" (list (cdr (assoc 10 edta)) (cdr (assoc 11 edta))))))
  56.           (startbreak ent ss)
  57.         )
  58.         ((equal ename "LWPOLYLINE")
  59.           (if (<= (length (setq eptlst (getptlst ent))) 2)
  60.             (setq ss (ssdel ent (ssget "F" eptlst)))
  61.             (setq ss (ssdel ent (ssget "CP" (append (setq eptlst (getptlst ent)) (list (car eptlst))))))
  62.           )
  63.           (startbreak ent ss)
  64.         )
  65.       )
  66.     )
  67.   )
  68.   (command "_.UNDO" "e")
  69.   (prin1)
  70. )
参与人数 4明经币 +4 收起 理由
xj6019 + 1 很给力!
zixuan203344 + 1 小青春牛逼!
USER2128 + 1 赞一个!
bssurvey + 1 很给力!
发表于 2021-4-22 02:54:12 | 显示全部楼层
又不能生成面域,否则功能会十分强大
发表于 2021-4-22 07:28:52 | 显示全部楼层
感谢大佬的分享精神
 楼主| 发表于 2021-4-22 08:52:57 | 显示全部楼层
meja 发表于 2021-4-22 02:54
又不能生成面域,否则功能会十分强大
生成面域论坛应该有,我记得G版写过一个
GMT+8, 2025-10-2 04:44 , Processed in 0.156334 second(s), 27 queries , Gzip On.
