查看: 1195|回复: 6
[提问] repeat中提示参数错误
发表于 2021-4-24 23:24:07 | 显示全部楼层 |阅读模式
(defun C:ff ( / &dis1 &dis2 &k1 &n1  &p1 p2 &ss1 &len os strtemp strtemp_ele ele k g)
         (if (null vlax-dump-object) (vl-load-com) )
         (setq &ss1 '("LINE" "LWPOLYLINE" "CIRCLE" "ARC" "HELIX" "ELLIPSE" "SPLINE" "POLYLINE")) ;曲线有起点:直线,多段线,圆,圆弧,螺旋对象,椭圆,样条曲线,二维多段线
                 (setq &k1 (entsel "\n请选择曲线"))
                         (while (= nil &k1)
                                 (setq &k1 (entsel "\n没有选择曲线,重新选择"))
                   (setq &k1 (car &k1))
        (member (cdr (assoc 0 (entget &k1))) &ss1);确认是曲线
                (setq &p1 (getpoint "\n选择曲线上第一点:"))
                        (while (not (vlax-curve-getDistAtPoint &k1 &p1))
                                (setq &p1 (getpoint "\n没有选在曲线上,重新选择:"))
                        (if(not lenth) ;设置全局变量lenth
                                (setq lenth 30);给全局变量lenth付初始值30
                        (setq &len (getstring (strcat "\n输入偏移长度:" )))
                        (cond
                             ((not &len) (setq &len lenth));把全局变量len的值传递给&len
                                  ((wcmatch &len "*+*") (setq strtemp (strsplit &len "+")))
          ((wcmatch &len "*x*") (setq strtemp (strsplit &len "x")))
    (setq lenth &len);把局部变量&len重新传递给全局变量lenth,以便下次使用
    (setq &p1 (vlax-curve-getclosestpointto &k1 &p1));取得最近点
    (setq &n1 (vlax-curve-getParamAtPoint &k1 &p1));取得参数
    (setq &dis1 (vlax-curve-getDistAtParam &k1 &n1));到起点距离
    (setq os (getvar "osmode"));记录对象捕捉参数
    (setvar "osmode" 0);关闭对象捕捉
    (setq k 0)
    (setq g 1)
    (setq ele 0)
    (cond
              (repeat (length strtemp)
                  (setq strtemp_ele(atof(nth k strtemp)))
                  (setq strtemp_ele(+ strtemp_ele ele))
                  (setq &dis2 (+ &dis1 strtemp_ele))
                  (setq p2 (vlax-curve-getPointAtDist &k1 &dis2))
                  (command "circle" p2 "1");命令行显示
                  (setq k(+ k 1))
                  (setq ele strtemp_ele)
              (repeat atoi(car strtemp)
                  (setq strtemp_ele(atof(cadr strtemp)))
                  (setq strtemp_ele(* strtemp_ele g))
                  (setq g(+ g 1))
    (setq &dis2 (+ &dis1 (atof &len)))
                (setvar "osmode" os);还原对象捕捉设置
; user defined function strsplit.
; strsplit splits a string with delimiter, and return a list.
; example: (strsplit "1,22,333,4444" ",")    -->> ("1","22","333","4444")
;          (strsplit ",1,22,333,4444," ",")  -->> ("" "1" "22" "333" "4444" "")
(defun strsplit(datastr delimiter)
    (setq strlist '()
          str ""
    (setq n (strlen datastr))
    (setq i 1)
    (repeat n
        ; s is a single letter, starts from the first to the end.
        (setq s (substr datastr i 1))
        (if (/= s delimiter)
            ; when s is't a delimiter
                (setq str (strcat str s))
                ; if s is the last letter
                (if (= i n)
                    (setq strlist (cons str strlist))
            ; when s is a delimiter
                (setq str "")
                ; if delimiter is the last letter
                (if (= i n)
                    (setq strlist (cons "" strlist))
        (setq i (1+ i))
    ; reverse list and retrun it
    (reverse strlist)
每次运行到红色字体处,提示参数错误,我知道repeat 后面的n需要的是整数且正数类型,难道atoi这个函数不对吗?
发表于 2021-4-24 23:43:13 | 显示全部楼层
你的括号呢
谢谢  发表于 2021-4-25 11:55
发表于 2021-4-25 07:25:23 | 显示全部楼层
(repeat (atoi (car strtemp))
 楼主| 发表于 2021-4-25 11:55:45 | 显示全部楼层
最近怎么老是出这种低级的问题,我还检查了好几遍 竟然没看出来
发表于 2021-4-25 13:33:18 | 显示全部楼层
不严谨  执行这个操作(car strtemp)之前应该判断下  strtemp是不是为空,为空的在来个atoi也会报错。
 楼主| 发表于 2021-4-25 15:01:07 | 显示全部楼层
这是cond下面的语句,如果为空,前面就跳过去了,到不了这一句
GMT+8, 2025-10-2 06:07 , Processed in 0.152436 second(s), 27 queries , Gzip On.
