查看: 3100|回复: 14
[源码] <*** 分享幾個 3D直梯,U型平台轉折梯,L型平台轉折梯,U型2平台轉折梯 ***>
发表于 2021-5-23 19:21:39 | 显示全部楼层 |阅读模式
這個是從國外論壇得來的,我想對於從事建築的網友應該會有需要,於是將輸入過程整理後分享出來
執行範例:
2. 直梯 3dIstair.lsp
   執行指令:3dIstair
   (1)  Specify elevation <0.0> :500
   (2)  Pick or specify height of stairs <300.0> :
   (3)  Specify number of stairs :18   (4)  Pick or specify height of slab dp= <8.0> :
   (5)  Pick or specify height of under steps plate dp= <5.0> :
   (6)  Pick or specify width of stairs <150.0> :
   (7)  Pick or specify length of stair <30.0> :
   (8)  Choose do you want full steps or without risers [Full/No] <Full> :n
   (9)  Choose do you want railings [Yes/No] <No> :y
   (10) Set the railing layer name and block name [railing ,railing2 ,railing3 ,railing4 ,railing5]:railing2
   (11) Pick or specify height of railings <100.0> :
   (12) How many beams [1/2] <2> :1
   (13) Pick or specify width of beam :30
   (14) Specify number of vertical bars for single step (0.25;0.5;1.0;2.0;3.0...) :2
多参数程序居然能不用对话框?!  发表于 2021-5-25 10:27
start4444 + 1 很给力!
 楼主| 发表于 2021-5-23 19:25:53 | 显示全部楼层
  3. U型平台轉折梯 3dIIstair.lsp
        執行指令:3dIIstair
   (1)  Specify elevation <0.0> :1000
   (2)  Pick or specify height of stairs by single track <150.0> :
   (3)  Specify number of stairs by single track :8
   (6)  Pick or specify width of stairs by single track <100.0> :
   (8)  Pick or specify gap distance between tracks <10.0> :30
   (9)  Choose do you want full steps or without risers [Full/No] <Full> :
   (10) Choose do you want railings [Yes/No] <No> :y
   (11) Set the railing layer name and block name [railing ,railing2 ,railing3 ,railing4 ,railing5]:railing3
   (12) Pick or specify height of railings <100.0> :
   (13) Pick or specify width of beam :20
   (15) Choose side [Left/Right] <Left> :
 楼主| 发表于 2021-5-23 19:27:18 | 显示全部楼层
4.  L型平台轉折梯 3dLstair.lsp         執行指令: 3dLstair
   (1)  Specify elevation <0.0> :1500
   (10) Set the railing layer name and block name [railing ,railing2 ,railing3 ,railing4 ,railing5]:railing4
   (12) Pick or specify width of beam :20
   (13) Specify number of vertical bars for single step (0.25;0.5;1.0;2.0;3.0...) :2
   (14) Choose side [Left/Right] <Left> :
 楼主| 发表于 2021-5-23 19:28:46 | 显示全部楼层
5.  U型2平台轉折梯 3dUstair.lsp     執行指令:3dUstair
   (1)  Specify elevation <0.0> :2000
   (2)  Pick or specify height of stairs by single track <100.0> :
   (3)  Specify number of stairs by single track :5
   (10) Set the railing layer name and block name [railing ,railing2 ,railing3 ,railing4 ,railing5]:railing5
 楼主| 发表于 2021-5-23 19:29:44 | 显示全部楼层
建立 上面各樓梯 3D欄杆造形,3D欄杆 及3D 兩側扶手 請參考下面連結 內的 步驟3 ,  步驟4  ,  步驟5 即可
1. <<<*** 分享一個 3D螺旋樓梯繪製 新增繁,簡版 ***>>>
ps :  程式詢問中的第一項  (1)  Specify elevation <0.0> :
                                         是指圖面中原點 y軸的高度:
ps2: 程式詢問中的這項 Set the railing layer name and block name [railing ,railing2 ,railing3 ,railing4 ,railing5]:&#8629;
       是設定欄杆圖例名稱及欄杆圖層名 按 Enter 內定為 railing
       總共有5種 樓梯造型  假設 你5種樓梯的欄杆造型都要一樣 那在這裡詢問名稱時都按ENTER即可
       若是5種 欄杆造型都要不一樣則名稱須做區分
发表于 2021-5-24 08:13:21 | 显示全部楼层
非常强大的工具插件。
发表于 2021-5-24 09:59:10 | 显示全部楼层
謝謝您分享!
很實用的工具
发表于 2021-5-24 10:21:54 | 显示全部楼层
挺好,文字版的ui困难些。
 楼主| 发表于 2021-5-24 18:58:09 | 显示全部楼层
挺好,文字版的ui困难些。
已補上執行動畫
GMT+8, 2025-5-14 18:41 , Processed in 0.198837 second(s), 30 queries , Gzip On.
