- 积分
- 13735
- 明经币
- 个
- 注册时间
- 2007-1-15
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
试试国际大神李麦克的:
将对象对齐到曲线 http://www.lee-mac.com/objectalign.html
适用所有图元
命令oa,几个简单的英文提示,应该都能看懂吧
(defun c:oa
*error*
bb1 bb2 blk bnm bpt
def dis
ent
fac
gr1 gr2
idx inc
llp lst
mat msg
obj ocs oss
pi2 pt1 pt2 pt3 pt4
sel
tma tmp trm
urp uxa
vec
(defun *error* ( msg )
(if (and (= 'list (type trm)) (= 'ename (type ent)) (entget ent))
(entdel ent)
(if (and (= 'vla-object (type blk)) (not (vlax-erased-p blk)))
(vl-catch-all-apply 'vla-delete (list blk))
(if (and (= 'vla-object (type def)) (not (vlax-erased-p def)))
(vl-catch-all-apply 'vla-delete (list def))
(foreach obj lst
(if (not (vlax-erased-p obj))
(vl-catch-all-apply 'vla-delete (list obj))
(oa:endundo (oa:acdoc))
(if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
(princ (strcat "\nError: " msg))
(oa:startundo (oa:acdoc))
(if (null oa|rot) (setq oa|rot 0.0))
(if (null oa|off) (setq oa|off 0.0))
(cond
( (or (oa:layerlocked (getvar 'clayer))
(oa:layerlocked "0")
(princ "\nThe current layer or layer \"0\" is locked - please unlock these layers before using this program.")
( (null (setq oss (oa:ssget "\nSelect objects to align: " '("_" ((0 . "~VIEWPORT"))))))
(princ "\n*Cancel*")
( (progn
(setq bpt (getpoint "\nSpecify basepoint <center>: "))
(while
(setvar 'errno 0)
(setq sel (nentselp "\nSelect curve to align objects <exit>: "))
(cond
( (= 7 (getvar 'errno))
(princ "\nMissed, try again.")
( (= 'ename (type (car sel)))
(if
(not
(or (= "VERTEX" (cdr (assoc 0 (entget (car sel)))))
(not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list (car sel)))))
(princ "\nInvalid object selected.")
(while (/= 5 (car (setq pt1 (grread t 13 1)))))
(null sel)
( (not
(or
(and
(setq trm (caddr sel))
(setq ent (oa:copynested (car sel) trm))
(and
(setq ent (cdr (assoc 330 (entget (car sel)))))
(setq ent (car sel))
(princ "\nUnable to recreate nested entity.")
( (progn
(setq ocs (trans '(0 0 1) 1 0 t)
uxa (angle '(0.0 0.0) (trans (getvar 'ucsxdir) 0 ocs t))
mat (mxm
(list
(list (cos uxa) (sin uxa) 0.0)
(list (- (sin uxa)) (cos uxa) 0.0)
'(0.0 0.0 1.0)
(mapcar '(lambda ( a ) (trans a ocs 0 t))
(1.0 0.0 0.0)
(0.0 1.0 0.0)
(0.0 0.0 1.0)
vec (mapcar '- (mxv mat (trans '(0.0 0.0 0.0) ocs 0)))
tma (vlax-tmatrix (append (mapcar 'append mat (mapcar 'list vec)) '((0.0 0.0 0.0 1.0))))
(repeat (setq idx (sslength oss))
(setq idx (1- idx)
obj (vla-copy (vlax-ename->vla-object (ssname oss idx)))
lst (cons obj lst)
(vla-transformby obj tma)
(if (and (vlax-method-applicable-p obj 'getboundingbox)
(not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list obj 'llp 'urp))))
(setq bb1 (cons (vlax-safearray->list llp) bb1)
bb2 (cons (vlax-safearray->list urp) bb2)
(vla-put-visible obj :vlax-false)
(not (and bb1 bb2))
(*error* nil)
(princ "\nUnable to calculate bounding box for the selection.")
( t
(setq bb1 (apply 'mapcar (cons 'min bb1))
bb2 (apply 'mapcar (cons 'max bb2))
bpt (cond ( bpt (mapcar '+ (mxv mat (trans bpt 1 0)) vec)) ((mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) bb1 bb2)))
fac (/ (- (cadr bb2) (cadr bb1)) 2.0)
pi2 (/ pi -2.0)
inc 0
(if (equal 0.0 fac 1e-8)
(if (equal bb1 bb2 1e-8)
(setq fac 1.0)
(setq fac (/ (- (car bb2) (car bb1)) 2.0))
(while (tblsearch "block" (setq bnm (strcat "$tmp" (itoa (setq inc (1+ inc)))))))
(foreach obj lst (vla-put-visible obj :vlax-true))
(vla-copyobjects (oa:acdoc)
(vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray vlax-vbobject (cons 0 (1- (length lst))))
lst
(setq def (vla-add (vla-get-blocks (oa:acdoc)) (vlax-3D-point bpt) bnm))
(foreach obj lst (vla-delete obj))
(setq lst nil
blk
(vla-insertblock
(vlax-get-property (oa:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
(vlax-3D-point (trans (cadr pt1) 1 0))
bnm 1.0 1.0 1.0 0.0
(vla-put-layer blk "0")
(vla-put-normal blk (vlax-3D-point ocs))
(setq msg (princ "\n[+/-] for [O]ffset | [</>] for [R]otation | [M]ultiple | <[E]xit>: "))
(while
(setq gr1 (grread t 15 0)
gr2 (cadr gr1)
gr1 (car gr1)
(cond
( (member gr1 '(3 5))
(setq pt2 (trans gr2 1 0)
pt1 (vlax-curve-getclosestpointtoprojection ent pt2 ocs)
pt3 (oa:2d (trans pt1 0 ocs))
pt4 (oa:2d (trans pt2 0 ocs))
(if (not (equal pt3 pt4 1e-8))
(setq dis (/ (* fac oa|off) (distance pt3 pt4)))
(vla-put-insertionpoint blk
(vlax-3D-point
(trans
(append
(mapcar '(lambda ( a b ) (+ a (* (- b a) dis))) pt3 pt4)
(list (caddr (trans pt1 0 ocs)))
ocs 0
(vla-put-rotation blk (+ (angle (trans pt1 0 ocs) (trans gr2 1 ocs)) oa|rot pi2))
(cond
( (= 5 gr1))
( (progn (vla-explode blk) oa|mtp))
( (= 2 gr1)
(cond
( (member gr2 '(043 061))
(setq oa|off (+ oa|off 0.1))
( (member gr2 '(045 095))
(setq oa|off (- oa|off 0.1))
( (member gr2 '(044 060))
(setq oa|rot (+ oa|rot (/ pi 4.0)))
( (member gr2 '(046 062))
(setq oa|rot (- oa|rot (/ pi 4.0)))
( (member gr2 '(013 032 069 101))
nil
( (member gr2 '(082 114))
(if (setq tmp (getangle (strcat "\nSpecify Rotation <" (angtos oa|rot) ">: ")))
(setq oa|rot tmp)
(princ msg)
( (member gr2 '(079 111))
(if (setq tmp (getdist (strcat "\nSpecify Offset <" (rtos (* fac oa|off)) ">: ")))
(setq oa|off (/ tmp fac))
(princ msg)
( (member gr2 '(077 109))
(if (setq oa|mtp (not oa|mtp))
(princ "\n<Multiple mode on>")
(princ "\n<Multiple mode off>")
(princ msg)
( t )
( (member gr1 '(011 025))
nil
( t )
(if trm (entdel ent))
(vla-delete blk)
(vla-delete def)
(defun oa:2d ( x ) (list (car x) (cadr x)))
(defun oa:layerlocked ( lay / def )
(and
(setq def (tblsearch "layer" lay))
(= 4 (logand 4 (cdr (assoc 70 def))))
(defun oa:copynested ( ent mat / enx tmp )
(if (= 1 (cdr (assoc 66 (setq enx (entget ent)))))
(oa:entmakex enx)
(setq ent (entnext ent)
enx (entget ent)
(while (/= "SEQEND" (cdr (assoc 0 enx)))
(oa:entmakex enx)
enx (entget ent)
(setq tmp (cdr (assoc 330 (entget (oa:entmakex enx)))))
(setq tmp (oa:entmakex enx))
(if tmp (vla-transformby (vlax-ename->vla-object tmp) (vlax-tmatrix mat)))
tmp
(defun oa:entmakex ( enx )
(entmakex
(append
(vl-remove-if
(function
(lambda ( x )
(or (member (car x) '(005 006 008 039 048 062 102 370))
(= 'ename (type (cdr x)))
enx
(006 . "CONTINUOUS")
(008 . "0")
(039 . 0.0)
(048 . 1.0)
(062 . 7)
(370 . 0)
(defun oa:ssget ( msg arg / sel )
(princ msg)
(setvar 'nomutt 1)
(setq sel (vl-catch-all-apply 'ssget arg))
(setvar 'nomutt 0)
(if (not (vl-catch-all-error-p sel)) sel)
(defun oa:startundo ( doc )
(oa:endundo doc)
(vla-startundomark doc)
(defun oa:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
(defun oa:acdoc nil
(eval (list 'defun 'oa:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(oa:acdoc)
;; Matrix Transpose - Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
(apply 'mapcar (cons 'list m))
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
(vl-load-com)
(princ
(strcat
"\n:: ObjectAlign.lsp | Version 1.7 | \\U+00A9 Lee Mac "
((lambda ( y ) (if (= y (menucmd "m=$(edtime,0,yyyy)")) y (strcat y "-" (menucmd "m=$(edtime,0,yyyy)")))) "2010")
" www.lee-mac.com ::"
"\n:: Type \"oa\" to Invoke ::"
