查看: 2003|回复: 8
[讨论] 快速关闭尺寸界线
发表于 2021-5-28 12:11:52 | 显示全部楼层 |阅读模式
在明经里看到一个大师的作品,想知道能否实现如下图我点选1这边就自动关1这边,点先2那一边则自动2那边。
  • (defun chdim (fs en / oldds cs)
  •   (command"undo" "be")
  •   (if (= "1" fs)
  •     (setq cs "2")
  •     (setq cs "1")
  •   (setq oldds (getvar "dimstyle"))
  •   (command "dimstyle" "restore" "" en)
  •   (setq oldv (getvar (strcat "dimblk" cs)))
  •   (if (= "" oldv)
  •     (setq oldv (getvar "dimblk"))
  •   (if (= "" oldv)
  •     (setq oldv ".")
  •   (setvar "dimsah" 1)
  •   (setvar "dimblk" ".")
  •   (setvar (strcat "dimblk" fs) ".")
  •   (setvar (strcat "dimblk" cs) oldv)
  •   (setvar (strcat "dimse" fs) 1)
  •   ;;;  (setvar "dimblk" oldv)
  •   (command "dimstyle" "a" en "")
  •   (command "dimstyle" "r" oldds)
  •   (command"undo" "e")
  • (defun c:cdt (/ ss fs)
  •   (initget "1 2")
  •   (setq fs (getkword "\n请输入要改变的箭头[左<1>或右<2>]:"))
  •   (setq ss (ssget '((0 . "dimension"))))
  •   (if ss
  •     (progn
  •       (setq n -1)
  •       (repeat (sslength ss)
  •         (setq en (ssname ss (setq n (1+ n))))
  •         (chdim fs en)
  •   (princ)
发表于 2021-5-29 20:43:00 | 显示全部楼层
判断出距离拾取点最近点位,然后关闭相应的界限和尺寸线即可。
 楼主| 发表于 2021-5-30 10:41:05 | 显示全部楼层
理论大家都懂
发表于 2021-5-31 15:13:25 | 显示全部楼层
  (if (= "1" fs)
    (setq cs "2")
    (setq cs "1")
  (if (= "" oldv)
  (if (= "" oldv)
    (setq oldv ".")
  (setvar "dimsah" 1)
(defun c:tt5 (/ en fs n ptx ss)
        (setq ptx (getpoint "\n选择隐藏边:"))
  ;(setq fs (getkword "\n请输入要改变的箭头[左<1>或右<2>]:"))
  (if ss
      (setq n -1)
                                (if (< (distance ptx (cdr (assoc 13 (entget en)))) (distance ptx (cdr (assoc 14 (entget en))))) (setq fs "1") (setq fs "2"))
        (chdim fs en)
        (command"undo" "e")
发表于 2021-5-31 16:46:34 | 显示全部楼层
箭头不是也要顺带隐藏的吗
 楼主| 发表于 2021-5-31 20:12:58 | 显示全部楼层
  (if (= "1" fs)
谢谢,有没有可能ptx可以根据ssget的时候的选择点来获得呢?我的三脚猫功夫没整成功
  (setq t_ent (car ss))
  (setq t_sel_point (cadr ss))
  (setq tx_ent (vlax-ename->vla-object t_ent))
   (setq        ptx
         (vlax-curve-getclosestpointto
           tx_ent
           (trans t_sel_point 1 0)
 楼主| 发表于 2021-5-31 20:13:28 | 显示全部楼层
sunny_8848 发表于 2021-5-31 16:46
箭头不是也要顺带隐藏的吗
不用隐藏箭头的
发表于 2021-6-1 10:44:47 | 显示全部楼层
  (setq s ...
那就是单选了
  (if (= "1" fs)
    (setq cs "2")
    (setq cs "1")
  (if (= "" oldv)
  (if (= "" oldv)
    (setq oldv ".")
  (setvar "dimsah" 1)
(defun c:tt5 (/ en fs n ptx ss enl)
        (setq en (car (setq enl (entsel "\n选择对象:"))) ptx (cadr enl))
        (chdim fs en)
        (command"undo" "e")
参与人数 1明经币 +1 金钱 +20 收起 理由
dennylaw163 + 1 + 20 很给力!
 楼主| 发表于 2021-6-1 11:22:17 | 显示全部楼层
start4444 发表于 2021-6-1 10:44
那就是单选了
太给力了,谢谢!
GMT+8, 2025-10-2 06:07 , Processed in 0.157852 second(s), 28 queries , Gzip On.
