查看: 1867|回复: 3
[2021] AutoCAD 2022 GSF Update for Version 2022.0.1
发表于 2021-6-13 10:43:24 | 显示全部楼层 |阅读模式
不知道大神@编程小子
请示单独更新一下这个BDIS独立安装包。
如果抽不出时间就等桌子的下个大补丁吧。。。。。毕竟这种活没有任何收益,纯粹是为中华之崛起而奉献
Affected ProductsThis Update applies to the following:
• 2022.0.1 Update version of AutoCAD and AutoCAD 2022-based products andspecialized toolsets. Note that this update should be applied to AutoCAD builds afterAutoCAD 2022.0.1 Update has been installed – version information should be S.074.0.0for the AutoCAD build.
• This does not apply to versions of AutoCAD 2022 that have not been updated to Update0.1.Issues Resolved by This UpdateThis Update resolves the following GSF issues:
• FILLET does not work properly in GSF
• POINT is not displayed in GSF.
• PLINE width and thickness doesn’t work in GSF
• Grips in GSF mode should be in blue color like they are displayed in GS1
• GSF is forcing double sided material on
• Retain needed shader parameters during highlight
• First layer change in GSF causes invalidation
• Editing 2D SOLID should display in all viewports
• Highlight node requires viewport draw support
• SOLID doesn't drag correctly in a multi viewport config
• Complex line types were not supported in GSF
• Mid point OSNAP is missing or wrong for PLINE
英文的发布日期是Jun 04 2021
This is a new update to the 3D Graphics Technical Preview for AutoCAD 2022 and AutoCAD 2022-based products and specialized toolsets. The Technical Preview is a completely new cross platform 3D graphics system being developed for AutoCAD, leveraging all the power of modern GPUs and multi-core CPUs to offer a smooth navigation experience for much larger drawings than in prior releases. More information can be found here
Note that this update should be applied to AutoCAD builds after AutoCAD 2022.0.1 Update has been installed – version information should be S.074.0.0 for the AutoCAD build.
This update contains many bug fixes and some functionality improvements (refer to the Readme file for more info). We invite you to join the conversation about this technical preview at "AutoCAD Forum on GSF".
AutoCAD GSF team.
中文版
https://knowledge.autodesk.com/zh-hans/support/autocad/troubleshooting/caas/downloads/downloads/CHS/content/autocad-2022-gsf-update.html
发表于 2021-6-13 11:34:33 | 显示全部楼层
这个是干嘛用的,有必要更新吗?
发表于 2021-6-13 18:42:26 | 显示全部楼层
我解包看了一下文件信息,感觉不需要借助BDIS就能直接安装了。
如果想出整合到2022.0.1的版本,就看实际情况了。
发表于 2021-6-16 10:51:00 | 显示全部楼层
如果想出整合到2022.0.1的版本,就看实际情 ...
你好,安装autocad 2022时闪退,请问有没有什么办法解决,谢谢!
已经解决,安全模式下安装!
GMT+8, 2025-5-17 21:36 , Processed in 0.203467 second(s), 28 queries , Gzip On.
