查看: 1061|回复: 10
[源码] (SDSCALE)对象距离缩放(只改变对象距离位置,不改变对象大小)
发表于 2021-6-24 09:10:11 | 显示全部楼层 |阅读模式
;;说明:对象距离缩放(只改变对象距离位置,不改变对象大小) by 忘霄 2021.5.12
(defun C:SDSCALE(/ *error* bf-mat-translation ent iscpy mat n nmidpt obj omidpt p0 pc0 pc1 pc2 sca scae scas ss)
        (vl-load-com)
        (defun *error*(msg)
                (if (= iscpy T) (command-S "_.ERASE" ss ""))
                (prin1)
        ;;;name:BF-Mat-Translation
        ;;;desc:根据矢量计算平移矩阵
        ;;;arg:v:平移矢量
        ;;;return:4X4的平移矩阵
        ;;;exampleBF-Mat-Translation '(1 0 0))
        (defun BF-Mat-Translation (v)
                (list
                        (list 1. 0. 0. (float (car v)))
                        (list 0. 1. 0. (float (cadr v)))
                        (list 0. 0. 1. (float (caddr v)))
                        (list 0. 0. 0. 1.)
        (if (and (setq ss (ssget)) (setq p0 (getpoint "\n指定距离缩放中心点:")))
                        (setq iscpy nil n -1)
                        (initget "C c R r")
                        (setq sca (getdist p0 "\n指定缩放比例或 [复制(C)/参照(R)] <1.00>:"))
                        (if (or (= p0 "") (= p0 nil)) (setq sca 1.0))
                        (while (= (type sca) 'STR)
                                (setq sca (strcase sca))
                                (cond
                                        ((and (not iscpy) (equal sca "C"))
                                                (command "_.COPY" ss "" "non" '(0 0 0) "non" '(0 0 0))
                                                (setq iscpy T)
                                                (initget "R r")
                                                (setq sca (getdist p0 "指定缩放比例或 [参照(R)] <1.00>:"))
                                        ((equal sca "R")
                                                (setq pc0 (getpoint "\n指定参照长度 <1.00>:"))
                                                (if (or (= pc0 "") (= pc0 nil))
        (setq pc0 p0 scas 1.0 pc2 (getpoint pc0 "\n指定新长度<1.00>:"))
        (if (or (= pc2 "") (= pc2 nil))
        (setq scae 1.0)
        (setq scae (distance pc0 pc2))
        (setq pc1 (getpoint pc0 "指定第二点:"))
        (if (or (= pc1 "") (= pc1 nil))
        (setq scas 1.0)
        (setq scas (distance pc0 pc1) pc2 (getpoint pc0 "\n指定新长度<1.00>:"))
        (setq scae 1.0)
                                                (setq sca (/ scae scas))
                        (while (setq ent (ssname ss (setq n (1+ n))))
                                (setq obj (vlax-ename->vla-object ent))
                                (vla-GetBoundingBox obj 'mn 'mx)
                                (setq omidpt (mapcar '* (mapcar '+ (vlax-safearray->list mn) (vlax-safearray->list mx)) (list 0.5 0.5 0.5)))
                                (setq nmidpt (polar p0 (angle p0 omidpt) (* sca (distance p0 omidpt))))
                                (setq mat (vlax-make-safearray vlax-vbDouble '(0 . 3) '(0 . 3)))
                                (vlax-safearray-fill mat (BF-Mat-Translation (mapcar '- nmidpt omidpt)))
                                (vla-TransformBy obj mat)
        (prin1)
(princ "\n对象距离缩放:SDSCALE!")
(prin1)
发表于 2021-6-24 11:12:52 | 显示全部楼层
非常好用,谢谢大神!
发表于 2021-6-25 20:33:36 | 显示全部楼层
顶起顶起,,谢谢楼主的无私奉献,一个好的想法和功能实现了
发表于 2024-1-12 11:44:34 | 显示全部楼层
如果能支持三维对象的3坐标缩放,那就跟橱柜的爆炸功能一样强大了
可以试试下帖代码  发表于 2024-1-13 10:21
发表于 2024-1-13 10:16:04 | 显示全部楼层
  1. (defun c:tt ()
  2.   "对象距离缩放(只改变对象距离位置,不改变对象大小)"
  3.   (defun Ureal (bit kwd msg def / inp)
  4.     (if def
  5.       (setq msg (strcat "\n" msg "<" (rtos def 2) ">: ")
  6.             bit (* 2 (fix (/ bit 2)))
  7.       )
  8.       (setq msg (strcat "\n" msg ": "))
  9.     )
  10.     (initget bit kwd)
  11.     (setq inp (getreal msg))
  12.     (if inp inp def)
  13.   )
  14.   (defun cen (s1 / x y a b)
  15.     (vla-GetBoundingBox (vlax-ename->vla-object s1) 'a 'b)
  16.     (mapcar '(lambda (x y) (* (+ x y) 0.5))(vlax-safearray->list a)(vlax-safearray->list b))
  17.   )
  18.   (defun ss2list (ss)
  19.     (vl-remove-if-not'(lambda (x) (equal (type x) 'ENAME))(mapcar 'cadr (ssnamex ss)))
  20.   )
  21.   ;;
  22.   (or sc (setq sc 2.))
  23.   (setq sc (Ureal 7 "" "缩放比例" sc))
  24.   (if (and (setq ss (ssget))
  25.            (setq p0 (getpoint "\n缩放基点<退出>: "))
  26.       )
  27.     (setq lst (mapcar '(lambda (x)
  28.                          (setq p1 (cen x)
  29.                                dd (* (distance p0 p1) sc)
  30.                                p2 (polar p0 (angle p0 p1) dd)
  31.                          )
  32.                          (command "move" x "" "non" p1 "non" p2)
  33.                        )
  34.                       (ss2list ss)
  35.               )
  36.     )
  37.   )
  38.   (princ)
  39. )
发表于 2024-1-13 10:18:43 | 显示全部楼层
  1. (defun c:tt ()
  3.   (xyp-Start)
  4.   (or sc (setq sc 2.))
  5.   (setq sc (Ureal 7 "" "缩放比例" sc))
  6.   (princ "\n选择实体<退出>: ")
  7.   (if (and (setq ss (ssget))(setq p0 (getpoint "\n缩放中心<退出>: ")))
  8.     (mapcar '(lambda (x)
  9.                (setq p1 (xyp-9pt x 5) dd (* (distance p0 p1) sc)p2 (polar p0 (angle p0 p1) dd))
  10.                (xyp-move x p1 p2)
  11.              )
  12.             (xyp-ss2list ss)
  13.     )
  14.   )
  15.   (xyp-End)
  16. )
发表于 2024-1-13 15:40:18 | 显示全部楼层
感谢院长指导~  我去测试下
发表于 2024-1-13 16:03:14 | 显示全部楼层
院长,已测试
十分感谢,代码已实现对三维对象的支持,
目前缩放的对象都在同一平面上
实现Z轴的缩放是否可行?
可否赐教
发表于 2024-1-13 16:41:20 | 显示全部楼层
  1. (defun c:tt ()
  3.   (xyp-Start)
  8.            (setq p0 (getpoint "\n缩放中心<退出>: "))
  9.       )
  10.     (mapcar '(lambda (x)
  11.                (setq p1 (xyp-9pt x 5)
  12.                      dd (* (distance p0 p1) sc)
  13.                      p2 (xyp-PtAlong2PtByDist p0 p1 dd)
  14.                 )
  15.                (xyp-move  x p1 p2)
  16.              )
  17.             (xyp-ss2list ss)
  18.     )
  19.   )
  20.   (xyp-End)
  21. )
发表于 2024-1-15 08:58:24 | 显示全部楼层
帅炸了~   已测试   非常完美!
GMT+8, 2024-11-25 23:24 , Processed in 0.181987 second(s), 27 queries , Gzip On.
