查看: 2056|回复: 4
将dat中数据设置为CAD坐标形式
发表于 2021-6-25 10:51:20 | 显示全部楼层 |阅读模式
Sub 宏1()
    Selection.TextToColumns Destination:=Range("A1"), DataType:=xlDelimited, _
        TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=False, Tab:=True, _
        Semicolon:=False, Comma:=False, Space:=False, Other:=True, OtherChar _
        :="]", FieldInfo:=Array(Array(1, 1), Array(2, 1), Array(3, 1), Array(4, 1), Array(5, _
        1), Array(6, 1), Array(7, 1), Array(8, 1), Array(9, 1), Array(10, 1), Array(11, 1), Array(12 _
        , 1), Array(13, 1), Array(14, 1), Array(15, 1), Array(16, 1), Array(17, 1), Array(18, 1), _
        Array(19, 1), Array(20, 1), Array(21, 1), Array(22, 1), Array(23, 1), Array(24, 1), Array( _
        25, 1), Array(26, 1), Array(27, 1), Array(28, 1)), TrailingMinusNumbers:=True
    Cells.Select
    Selection.Replace What:="line:", Replacement:="", LookAt:=xlPart, _
        SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
        ReplaceFormat:=False
    Selection.Replace What:=", [", Replacement:="", LookAt:=xlPart, _
    Selection.Replace What:="[", Replacement:="", LookAt:=xlPart, _
    Selection.Replace What:=" ", Replacement:="", LookAt:=xlPart, _
        Selection.Replace What:="3q", Replacement:="3q ", LookAt:=xlPart, _
    'For i = 1 To Cells(1, 1).End(xlDown).Row
    For i = 1 To Range("A65536").End(xlUp).Row
        b = Cells(i, 1).End(xlToRight).Column
        Cells(i, b) = Cells(i, b) + " "
    Next i
    Call h2
End Sub
发表于 2021-6-26 08:42:42 | 显示全部楼层
你好兄弟这个怎么用能搞一个动图吗
 楼主| 发表于 2021-6-27 16:17:26 | 显示全部楼层
664571221 发表于 2021-6-26 08:42
你好兄弟这个怎么用能搞一个动图吗
你也需要这个吗
发表于 2021-6-28 08:18:25 | 显示全部楼层
yuebu 发表于 2021-6-27 16:17
你也需要这个吗
是的兄弟....
 楼主| 发表于 2021-6-30 09:53:51 | 显示全部楼层
我这是EI里转出的DAT哦
GMT+8, 2025-12-20 04:22 , Processed in 0.195742 second(s), 23 queries , Gzip On.
