查看: 620|回复: 2
[提问] 知道椭圆信息 求椭圆上一点的41 42码
发表于 2021-7-6 00:19:29 | 显示全部楼层 |阅读模式
如题 ,可以通过lisp获取椭圆上的所有参数 ,现在知道 椭圆上任意一点   怎么求该点的绘图参数啊  我用endpoint进行测试,结果得不到
(defun c:t1()
   (vl-load-com)
   (setq name (car (entsel)))
   (Setq cen (Vlax-Get (Vlax-Ename->Vla-Object name) 'Center ))
   (Setq pt(Vlax-Get (Vlax-Ename->Vla-Object name) 'EndPoint ))
   (Setq axis (Vlax-Get (Vlax-Ename->Vla-Object name) 'MajorAxis ))
   (Setq ratio (Vlax-Get (Vlax-Ename->Vla-Object name) 'RadiusRatio ))
  (setq endparam (Vlax-Get (Vlax-Ename->Vla-Object name) 'EndParameter)
  (pt2ep ptend  cen axis ratio)
(princ "\n程序加载完成")
(princ "\n")
(defun pt2ep (pt cen axis ratio / ang param)
(setq ang (- (angle cen pt) (angle '(0. 0. 0.) axis)))
(setq param (atan (sin ang) (* (cos ang) ratio)))
(if (< (cos ang) 0.0)
  (setq param (+ pi param))
param
发表于 2021-7-6 08:02:08 | 显示全部楼层
不懂这是个什么玩法
 楼主| 发表于 2021-7-6 09:57:37 | 显示全部楼层
(princ (vlax-curve-getParamAtPoint obj1 pt ))
GMT+8, 2025-5-16 18:32 , Processed in 0.180132 second(s), 25 queries , Gzip On.
