查看: 1658|回复: 3
[求助]3dface
发表于 2004-3-24 20:02:00 | 显示全部楼层 |阅读模式
谁有办法降3dface转换为pline
发表于 2004-3-24 21:35:00 | 显示全部楼层
Sub main()
Dim Sel As AcadSelectionSet
Do While ThisDrawing.SelectionSets.Count <> 0
ThisDrawing.SelectionSets.Item(0).Delete
Loop
Set Sel = ThisDrawing.SelectionSets.Add("3DFace")
Sel.SelectOnScreen Dim Obj As AcadObject, My3DFace As Acad3DFace, Poins
For Each Obj In Sel
If TypeName(Obj) = "IAcad3DFace" Then
Set My3DFace = Obj
Poins = My3DFace.Coordinates
ReDim Preserve Poins(UBound(Poins) + 3)
Poins(UBound(Poins) - 2) = Poins(0)
Poins(UBound(Poins) - 1) = Poins(1)
Poins(UBound(Poins)) = Poins(2)
ThisDrawing.ModelSpace.AddPolyline Poins
Obj.Delete
End If
Next
End Sub
发表于 2004-3-24 21:36:00 | 显示全部楼层
用SendCommand方法来炸开,然后再把线组合成Pline
发表于 2004-3-24 22:26:00 | 显示全部楼层
3楼的方法在速度上会更快一些。
GMT+8, 2025-5-25 16:14 , Processed in 0.144529 second(s), 22 queries , Gzip On.
