查看: 1064|回复: 2
[提问] 关于提取交点坐标遇到问题
发表于 2021-9-16 11:13:01 | 显示全部楼层 |阅读模式
以下代码(来自本论坛提取点坐标 - AutoLISP/Visual LISP 编程技术 - CAD论坛 - 明经CAD社区 - Powered by Discuz! (mjtd.com))第一个疑问:我使用时候有些T字交点坐标提取不了。只能提取十字交点坐标。如下图每根纵先总共7个交点,现在只提取了5个交点坐标。
第二个,交点坐标不需要小数点,怎么调整?
(vl-load-com)
(defun c:tt (/ ss lst lst1 m n x y f)
  (defun x_ssn (ss / n lst)
    (repeat (setq N (sslength ss))
      (setq LST (cons (ssname SS (setq N (1- N))) LST))
  (defun deldup        (ptLst alw / pt1)
    (cond ((<= (length ptLst) 1) ptLst)
          (t
           (setq pt1 (car ptLst))
           (cons pt1
                 (vl-remove-if
                   '(lambda (x) (equal pt1 x alw))
                   (deldup (cdr ptLst) alw)
  (defun get_dxf (en num /) (cdr (assoc num (entget en))))
  (setq f (open (getfiled "坐标输出为:" "d:/" "txt" 1) "w"))
  (prompt "\n仅选择纵向线:")
  (setq        ss  (ssget)
        lst (x_ssn ss)
        lst (vl-sort
              lst
              '(lambda (x y) (< (car (get_dxf x 10)) (car (get_dxf y 10))))
  (foreach n lst
    (setq ss (ssget "f" (list (get_dxf n 10) (get_dxf n 11))))
    (setq lst1 (x_ssn ss))
    (setq lst1 (deldup (vl-remove nil
                                  (mapcar '(lambda (x)
                                             (vlax-invoke
                                               (vlax-ename->vla-object n)
                                               'IntersectWith
                                               (vlax-ename->vla-object x)
                                               acExtendNone
                                          lst1
                       1e-6
          lst1 (vl-sort lst1 '(lambda (x y) (< (cadr x) (cadr y))))
    (foreach m lst1
      (write-line
        (strcat (rtos (car m) 2 3) "," (rtos (cadr m) 2 3))
        f
    (write-line "下一个" f)
  (close f)
发表于 2021-9-16 16:10:55 | 显示全部楼层
上图,这段程序不一定适合您的需求。可能制图精度的问题,ssget "f"没有选到某个图元
 楼主| 发表于 2021-9-17 11:50:35 | 显示全部楼层
可能精度问题。把线修延长一点就可以了。基本上能用了。就是有点麻烦
GMT+8, 2025-5-16 11:53 , Processed in 0.156414 second(s), 26 queries , Gzip On.
