;N阶矩阵
 - (defun tt (n / x m lst1 lst2 lst3)
- (if (> n 1)
- (progn
- (setq x 0
- lst1 '()
- lst3 '()
- (while (< x n)
- (setq lst1 (cons (strcat "x" (vl-princ-to-string x)) lst1)
- x (1+ x))
- (while (> x 0)
- (setq lst2 '()
- x (- x 1))
- (foreach m lst1
- (if (= m (strcat "x" (vl-princ-to-string x)))
- (setq lst2 (cons 1.0 lst2))
- (setq lst2 (cons 0.0 lst2))
- (setq lst3 ( cons lst2 lst3))
- lst3
以上是以前仿照(XD::Mat:Identity)写的一个任一N阶单位矩阵的 ,
(if (> n 1)
(setq x 0
lst1 '()
lst3 '()
(while (< x n)
x (1+ x))
(while (> x 0)
(setq lst2 '()
x (- x 1))
(mapcar
'(lambda(m)
) lst1
lst3
