查看: 1201|回复: 7
[源码] 我也写了一个另类的数字表平均分组法
发表于 2021-10-5 12:25:37 | 显示全部楼层 |阅读模式
;;由于我的不小心,当时错传了文件(误传了试验过程中的文件)。在此感谢发现错误的大师。
;;2021.10.23重新覆盖上传下面内容
;;思路:粗分组=>优化(单项对调、多项对调)
;;缺点:不一定能得到最优解
;;函数wrf3upp 分组数 优化次数 数字表)
;;返回:(极差 (sum1 lst1)(sum2 lst2)...)
;;(wrf3upp 3 7 '(5.4 5.0 4.8 4.2 2.8 2.8 2.8 2.8 2.8 2.8))
;;(1.4 (11.2 (2.8 2.8 2.8 2.8)) (12.4 (5.4 4.2 2.8)) (12.6 (5.0 4.8 2.8)))
;;例子:
;;出题目:(setq lst (createlst4 1000 3 100)) ;;将实数1000按离散度为100随机分成拆成3组
;; (wrf3upp 3 7 lst)
;; (wrf3upp 3 7 (createlst4 1000 3 100))
;;对实数表lst,均分成n组
;;分组数n----n应大于等于3
;;优化次数i---i取9
;;(wrf3upp n i lst) ;;(fuzz (su1 lst1)(su2 lst2) ... (sun lstn)
(defun wrf3upp_new ( n lst / su a n li lst_out ll offset )
        (setq su (apply '+ lst))
        (setq a (/ su (* n 1.0)))
        (while (> n 0)
                (setq li (H_L lst a))
                (setq lst_out (cons li lst_out))
                (setq ll (cadr li))
                (while ll
                        (setq lst (XD:ist:RemoveE (car ll) lst nil))
                        (setq ll (cdr ll))
                (setq n (- n 1))
        (setq lst_out (l-sort lst_out))
        (setq offset (- (car (car (reverse lst_out))) (car (car lst_out))))
        (cons offset lst_out)
(defun wrf3upp ( n i lst / l1 l2 l3 su1 su2 su3 ll
                                        minterm li sui newterm offset lll
        (setq lst (XD::list:sort lst '>))
        (setq ll (createlst1 n))
        (while lst
                (setq minterm (car ll))
                (setq li (reverse (cons (car lst) (reverse (cadr minterm)))))
                (setq sui (+ (car minterm) (car lst)))
                (setq newterm (list sui li))
                (setq ll (cons newterm (cdr ll)))
                (setq ll (l-sort ll))
                (setq lst (cdr lst))
        (setq offset (- (car (car (reverse ll))) (car (car ll))))
        (setq lll (cons (cons offset ll) lll))
        (repeat i
                (if (< (car (car ll)) (car (car (reverse ll))))
                                (setq ll (youhua_new ll))
        (setq lll (l-sort lll))
        (setq lll (XD:ist:DelSame lll))
        (setq ll (car lll))
(defun anyx ( lst / sumlst lst)
        (setq sumlst nil)
        (while lst
                (setq sumlst (cons (apply '+ (car lst)) sumlst))
        (setq sumlst (reverse sumlst))
(defun l-sort ( L / L1 LL)
        (defun foo1 (a b)
                (cond ((<= (car a) (car b))
                                (T
                                        nil)
        (setq li (vl-sort-i l 'foo1))
        (while Li
                (setq LL (cons (nth (car Li) L) LL))
                (setq Li (cdr Li))
        (reverse LL)
(defun xd::list:position-fuzz (e l fuzz)
  (if (atom e)
    (vl-position
      (xd::list:car-member-if '(lambda (x) (equal e x fuzz)) l)
      l
  (vl-position e l)
(defun findterm ( l1 l2 a / n m ll sn fu yn ni mi snlst )
        (cond         ((and (= (length l1) 1) (= (length l2) 1))
                                nil)
                        ((= a 0)
                                nil)
                        (T
                                (setq n (length l1))
                                (setq m (length l2))
                                (setq ll l1)
                                (setq sn (fix (/ 60 (length l2))))
                                (if (<= sn 4) (setq sn 4))
                                (setq sn 4)
                                (setq fu (/ a sn 1.0))
                                (setq yn T)
                                (setq snlst (crlst5 sn))
                                (while (and yn snlst)
                                        (setq ll l1)
                                        (while (and ll yn)
                                                (if (xd::list:position-fuzz (+ (car ll) (* fu (car snlst))) l2 (* fu 0.9))
        (setq ni (- n (length ll)))
        (setq mi (xd::list:position-fuzz (+ (car ll) (* fu (car snlst))) l2 (* fu 0.9)))
        (setq yn nil)
                                                (setq ll (cdr ll))
                                        (setq snlst (cdr snlst))
                                (if yn
                                        nil
                                        (list ni mi)
(defun changeterm ( l1 l2 a / n m ll sn fu yn l1_new l2_new snlst )
                                nil)
                        ((= a 0)
                                nil)
                        (T
                                (setq ll l1)
                                (setq sn 4)
                                (setq yn T)
                                        (setq ll l1)
                                        (while (and ll yn)
                                                (if (setq ls_z (findr_fu_k (+ (car ll) (* fu (car snlst)))
        l2
        (* fu 0.9)
        (setq l1_new (append (XD:ist:RemoveE (car ll) l1 nil) ls_z))
        (setq l1_new (reverse (wrf::list:sort l1_new)))
        (while ls_z
        (setq l2 (XD:ist:RemoveE (car ls_z) l2 nil))
        (setq ls_z (cdr ls_z))
        (setq l2_new (cons (car ll) l2))
        (setq l2_new (reverse (wrf::list:sort l2_new)))
        (setq yn nil)
                                                (setq ll (cdr ll))
                                (if yn
                                        nil
                                                (setq ll (list l1_new l2_new))
                                                (setq ll (list (anyx ll) ll))
                                                (apply 'mapcar (cons 'list ll))
(defun youhua ( ll / minterm maxterm a lmin lmax nm
                                term_min term_max new_lmin_h new_lmin_t
                                new_lmax_h new_lmax_t
                                new_lmin new_lmax minterm maxterm
        (cond ((setq lmin (car (cdr (car ll)))
                                        lmax (car (cdr (car (reverse ll))))
                                        a (- (car (car (reverse ll))) (car (car ll)))
                                        nm (findterm lmin lmax (/ a 2.0)))
                                (setq term_min (nth (car nm) lmin))
                                (setq term_max (nth (cadr nm) lmax))
                                (setq new_lmin_h (XD:ist:N-M lmin 1 (car nm)))
                                (setq new_lmin_t (XD:ist:N-M lmin (+ (car nm) 2) (length lmin)))
                                (setq new_lmax_h (XD:ist:N-M lmax 1 (cadr nm)))
                                (setq new_lmax_t (XD:ist:N-M lmax (+ (cadr nm) 2) (length lmax)))
                                (setq new_lmin (append new_lmin_h (cons term_max new_lmin_t)))
                                (setq new_lmax (append new_lmax_h (cons term_min new_lmax_t)))
                                (setq new_lmin (reverse (wrf::list:sort new_lmin)))
                                (setq new_lmax (reverse (wrf::list:sort new_lmax)))
                                (setq minterm (list (apply '+ new_lmin) new_lmin))
                                (setq maxterm (list (apply '+ new_lmax) new_lmax))
                                (setq ll (cons minterm (reverse (cons maxterm (cdr (reverse (cdr ll)))))))
                                        lmax (car (cdr (cadr (reverse ll))))
                                        a (- (car (cadr (reverse ll))) (car (car ll)))
                                (setq ll (cons minterm (reverse (cons maxterm (cons (car (reverse ll)) (cddr (reverse (cdr ll))))))))
                        ((setq lmin (car (cdr (cadr ll)))
                                        a (- (car (car (reverse ll))) (car (cadr ll)))
                                (setq ll (cons (car ll) (cons minterm (reverse (cons maxterm (cdr (reverse (cddr ll))))))))
                        (T
                                ll
(defun youhua_new ( ll / minterm maxterm a lmin lmax nm
                                        nm (changeterm lmin lmax (/ a 2.0)))
                                (setq ll (cons (car nm)(reverse (cons (cadr nm) (cdr (reverse (cdr ll)))))))
                                (setq ll (cons (car nm) (reverse (cons (cadr nm) (cons (car (reverse ll)) (cddr (reverse (cdr ll))))))))
                                (setq ll (cons (car ll) (cons (car nm) (reverse (cons (cadr nm) (cdr (reverse (cddr ll))))))))
                        (T
                                ll
(defun createlst1 ( n / ll)
        (repeat n (setq ll (cons (list 0 nil) ll)))
(defun createlst2 ( n / ll)
        (repeat n (setq ll (cons (list 0 "" nil nil) ll)))
(defun createlst3 ( r n m / ll su a)
        (setq r (* r 1.0))
        (repeat n
                (setq ll (cons (XD::math:rand 1 m) ll))
        (setq su (apply '+ ll))
        (setq a (/ r su))
        (setq ll (mapcar '(lambda (x) (* x a)) ll))
(defun createlst4 ( r n m / ll )
        (repeat n
                (setq ll (append (createlst3 r (XD::math:rand 4 30) m) ll))
(defun crlst5 ( i / n ll )
        (setq n (* i 2))
        (while (> n 0)
                (setq ll (cons n ll))
                (setq n (- n 1))
        (setq ll (append (reverse (XD:ist:N-M ll 1 i)) (XD:ist:N-M ll (+ i 1) (- (length ll) 1))))
(defun findtwo ( r lst / lst2 lstsu ll i lstr )
        (setq lst2 (apply 'mapcar (cons 'list (list lst (cdr lst)))))
        (setq lstsu (mapcar '(lambda (x) (apply '+  x)) lst2))
        (if (setq ll (member r lstsu))
                        (setq i (- (length lst) (length ll)))
                        (setq lstr (XD:ist:N-M lst i (+ i (- 2 1))))
                nil
(defun findthr ( r lst / lst2 lstsu i ll lstr )
        (setq lst2 (apply 'mapcar (cons 'list (list lst (cdr lst) (cddr lst)))))
                        (setq i (- (length lst) (length ll) 1))
                        (setq lstr (XD:ist:N-M lst i (+ i (- 3 1))))
                nil
(defun powerset (L)
  (if (null L)
    (list nil)
    (apply (function (lambda (a) (append (mapcar '(lambda (x) (append (list (car L)) x)) a) a)))
           (list (powerset (cdr L)))
(defun findr ( r lst / lst2 lstsu ll i lstr )
        (setq lst2 (cdr (reverse (powerset lst))))
                        (setq i (- (length lstsu)(length ll)))
                        (setq lstr (nth i lst2))
                nil
(defun findr_k ( r lst / ll)
        (cond ((setq ll (member r lst))
                                (list (car ll)))
                        ((setq ll (findtwo r lst))
                                ll)
                        ((setq ll (findthr r lst))
                                ll)
                        (T
                                nil)
(defun findtwo_fu ( r lst fu / lst2 lstsu i lstr )
        (if (setq i (xd::list:position-fuzz r lstsu fu))
                        (setq lstr (XD:ist:N-M lst (+ i 1) (+ i 2)))
                nil
(defun findthr_fu ( r lst fu / lst2 lstsu i lstr )
                        (setq lstr (XD:ist:N-M lst (+ i 1) (+ i 3)))
                nil
(defun powerset (L)
  (if (null L)
    (list nil)
(defun findr_fu ( r lst fu / lst2 lstsu i lstr )
                nil
(defun findr_fu_k ( r lst fu / i ll )
        (cond ((setq i (xd::list:position-fuzz r lst fu))
                                (list (nth i lst)))
                        ((setq ll (findtwo_fu r lst fu))
                                ll)
                        ((setq ll (findthr_fu r lst fu))
                                ll)
                        (T
                                nil)
(defun H_L (lst L)
  (setq i -1)
  (setq lst1 (mapcar '(lambda (x y)
        (setq i (+ i 1))
        (list (if (> (+ x y) L) x (+ x y))
        y
        (if  (> (+ x y) L)
        (list x)
        (list  x y)
                      (reverse (cdr (reverse lst)))
                      (cdr lst)
  (while (cdr lst1)
        (if (> (+ (car x) (cadr y)) L)
        (if (>= (car x)  (car y))
        (list        (car x)
        (cadr y)
        (last x)
        y
        (if (> (+ (car x) (cadr y)) (car y))
        (list (+ (car x) (cadr y))
        (cadr y)
        (cons (cadr y) (last x))
        y
                           (reverse (cdr (reverse lst1)))
                           (cdr lst1)
  (cons (car (car lst1))(list (last (car lst1))))
(defun wrf::list:sort ( L / L1 LL)
        (setq L1 (vl-sort-i L '<))
        (setq LL nil)
        (while L1
                (setq LL (cons (nth (car L1) L) LL))
                (setq L1 (cdr L1))
        (reverse LL)
(defun XD:ist:DelSame (l)
  (if l
   (cons (car l) (XD:ist:DelSame (vl-remove (car l) l)))
bssurvey + 1 赞一个!
发表于 2021-10-5 20:52:12 | 显示全部楼层
试了一下,结果不对,不知道是不是哪个函数对不上
(2.2 (2.8 (2.8)) (4.8 (4.8)) (5.0 (5.0)))
 楼主| 发表于 2021-10-6 07:26:37 | 显示全部楼层
(wrf3upp 3 7 '(5.4 5.0 4.8 4.2 2.8 2.8 2.8 2.8 2.8 2 ...
;;最外层只用了5个函数,在加载源文件后,分别试一下:
;;(xd::list:position-fuzz 4 '(1 2 3 4.021 5 6 7) 1e-1) ;;=>3
;;验证:XD:list:car-member-if和vl-position
;;(l-sort (list '(30 (10 10 10)) '(20 (10 10)) '(10 (10)));=>((10 (10)) (20 (10 10)) (30 (10 10 10)))
;;验证vl-sort-i
;(XD:ist:N-M '(2334 556 33 44 66 77 22) 3 5);=>(33 44 66)
;(XD:ist:sort '(5 4 2 0) '<);=>
;(XD:ist:DelSame '(0 1 2 3 2 3 4 5 0));=>(0 1 2 3 4 5)
;验证vl-remove
;(XD::math:rand 4 30);;应该不会出问题
;;如果上面没问题,可试一下:
;;(findterm '(76 71 45 9) '(92 73 48 10 3) 1.0) ;;(3 3)
;;(findterm '(76 71 45 9) '(92 73 48 10 3) 2.0) ;;(1 1)
;;(findterm '(76 71 45 9) '(92 73 48 10 3) 3.0) ;;(2 2)
;;(findterm '(76 71 45 9) '(92 73 48 10 3) 4.0) ;;(2 2)
;;(findterm '(76 71 45 9) '(92 73 48 10 3) 5.0) ;;(2 2)
;;(findterm '(76 71 45 9) '(92 73 48 10 3) 6.0) ;;(2 2)
;;(findterm '(76 71 45 9) '(92 73 48 10 3) 9.0) ;;nil
发表于 2021-10-6 20:44:09 | 显示全部楼层
createlst3和createlst4只是测试用,没有用到
(setq lst (reverse (XD::list:sort lst '<)))这句有点奇怪,为什么不直接 '>
有个函数有误,修改以后
这几个对不上:
(findterm '(76 71 45 9) '(92 73 48 10 3) 4.0) => (2 nil)
(findterm '(76 71 45 9) '(92 73 48 10 3) 6.0) => (1 1)
(findterm '(76 71 45 9) '(92 73 48 10 3) 9.0) => (2 2)
(wrf3upp 3 7 '(5.4 5.0 4.8 4.2 2.8 2.8 2.8 2.8 2.8 2.8)) => (1.4 (10.4 (5.4 5.0)) (11.2 (2.8 2.8 2.8 2.8)) (11.8 (4.8 4.2 2.8)))
 楼主| 发表于 2021-10-23 11:44:13 | 显示全部楼层
最近我打不开明经CAD平台。感谢小菜123发现了我的错误,原来我上传文件时误传了调试过程中的文件。我已在1楼改正了。请你重新复制1楼的代码,再试一下。给大家带来了不便,表示歉意!
发表于 2021-10-23 18:01:01 | 显示全部楼层
谢谢楼主的源码,虽然看不懂,结果还不错。
youhua这个函数似乎不用了?wrf3upp_new这个函数也不知道有什么用,用它算出的结果也不对。前面的测试函数结果对不上的有:(findterm '(76 71 45 9) '(92 73 48 10 3) 9.0) => (2 2)
 楼主| 发表于 2021-10-24 08:29:01 | 显示全部楼层
youhua这个函数似乎不用了?wrf3upp_new这个函数也不知道有什 ...
1. 当时想找到最优解,准备一个wrf3upp_new函数,结果难度大,放弃了。没有写成功。
2. 写findterm函数时,前后思路不同,追求最大获利与见利就收。目前代码中下面结果可以获利:
发表于 2021-10-24 09:31:10 | 显示全部楼层
那我的结果就是对的了,谢谢!
GMT+8, 2025-5-16 19:04 , Processed in 0.205386 second(s), 27 queries , Gzip On.
