查看: 5511|回复: 25
庆祝明经论坛恢复,改造的Z轴归零程序,展示下
发表于 2021-10-22 16:23:05 | 显示全部楼层 |阅读模式
  • ;;Z坐标归零
  • (defun c:zzz0 (/ s)
  •   (setq s (ssget))
  •   (zzz0 s)
  • ;;Z坐标归零-------【开始】-----------------
  • ;;----实体归零(一级)------------
  • (defun zero-ent (e / dxf new)
  •   (defun move-region-to-wcs-plan (ename / obj z)
  •     (setq obj (en2obj ename))
  •     (if (and
  •           (= "AcDbRegion" (vla-get-objectname obj))
  •           (/= 0.0 (setq z (caddr (car (get-box ename)))))
  •       (vla-move obj (vlax-3d-point (list 0 0 z)) (vlax-3d-point (list 0 0 0)))
  •   ;;210组码处理---------------------
  •   (defun correct210 (ent / obj za)
  •     (setq obj (en2obj ent))
  •     (if (and (vlax-property-available-p obj 'normal t)
  •           (not (equal '(0 0 1) (setq za (vlax-safearray->list (vlax-variant-value (vla-get-normal obj))))))
  •       (vl-catch-all-apply 'vla-put-normal (list obj (vlax-3d-point '(0 0 1))))
  •   (defun zero-group (e)
  •     (cond
  •       ;; 处理 10-14 段,含 Z 坐标且非零组码,设置Z = 0.0
  •       ((and (>= (car e) 10)
  •          (<= (car e) 14)
  •          (> (length e) 3)
  •          (/= 0.0 (nth 3 e))
  •         (setq c10 (1+ c10))
  •         (cons (car e) (list (cadr e) (caddr e) 0.0))
  •       ;; 处理 38 段(标高属性)
  •       ((and (= (car e) 38) (/= 0.0 (cdr e)))
  •         (setq c38 (1+ c38))
  •         '(38 . 0.0)
  •       ;; 其余组码原样返回
  •       (t e)
  •   (correct210 e) ;;210组码强制转换
  •   (setq dxf (entget e))
  •   (if (= (cdr (assoc 0 dxf)) "REGION")
  •     (move-region-to-wcs-plan e)
  •     (progn
  •       (setq new (mapcar 'zero-group dxf))
  •       (if (not (equal dxf new))
  •         (entmod new)
  •   new
  • ;;选择集归零---------(一级)------------------
  • (defun zzz0 (ss / c10 c38 dxf ent i len cmd)
  •   (setq len (sslength ss) i 0 c10 0 c38 0 cmd (getvar "cmdecho"))
  •   (_Undo1)
  •   (repeat len
  •     (setq ent (ssname ss i))
  •     (if (or (and (= (dxf1 ent 0) "ELLIPSE") (/= (dxf1 ent 41) 0)) ;椭圆弧BUG,采用二次归零处理
  •           (and (= (dxf1 ent 0) "ARC") (/= (dxf1 ent 370) nil))    ;370组码存在
  •       (progn
  •         (princ "\n 二次归零...")
  •         (setvar "cmdecho" 0)
  •         (terpri)
  •         (command ".ucs" "w")
  •         (command ".move" ent "" '(0 0 1e99) "" ".move" "p" "" '(0 0 -1e99) "")
  •       (if (/= (dxf1 ent 0) "INSERT")
  •         (zero-ent ent)
  •     (setq i (1+ i))
  •   (_Undo2)
  •   (command "_.regen")
  •   (princ (strcat "\n 选择的 " (itoa len) " 个对象中,\n" (itoa c10) " 个非零Z坐标, \n" (itoa c38) " 个标高被强制清零-->图元Z坐标值已全部归零"))
  •   (setvar "cmdecho" cmd)
  • ;;Z坐标归零-------【结束】-----------------
对于块内实体归零,还是没有好代码存在,会有BUG,暂且略去不处理。
210组码处理有BUG,圆弧法相调整后图元会自动被镜像,图元被镜像这是很严重的问题呀。希望楼主能优化下  发表于 2022-4-4 10:41
发表于 2021-10-23 22:55:38 | 显示全部楼层
不知道站长在搞什么名堂,如果没精力搞了,可以转给我,我来继续维护。
发表于 2022-3-22 17:01:52 | 显示全部楼层
(defun c:zzz0 (/ s)
  (setq s (ssget))
  (zzz0 s)
    (if (and
    (cond
         (<= (car e) 14)
         (> (length e) 3)
         (/= 0.0 (nth 3 e))
        (setq c10 (1+ c10))
      ;; 处理 38 段(标高属性)
        (setq c38 (1+ c38))
        '(38 . 0.0)
      ;; 其余组码原样返回
      (t e)
        (entmod new)
  new
  (_Undo1)
  (repeat len
        (terpri)
        (zero-ent ent)
    (setq i (1+ i))
  (_Undo2)
  (command "_.regen")
 楼主| 发表于 2021-10-24 16:40:37 | 显示全部楼层
lxl217114 发表于 2021-10-24 11:34
选择对象:  ; 错误: no function definition: _UNDO1
  • (if (null vlax-dump-object) (vl-load-com));;将 Visual LISP 扩展功能加载到 AutoLISP----0000级加载
  • ;;常量定义
  • (setq *Acad* (vlax-get-acad-object)
  •   *AcDocument* (vla-get-activedocument *Acad*)  ; 获取当前图档指针
  •   *Model-Space* (vla-get-modelspace *AcDocument*)
  •   *Paper-Space* (vla-get-PaperSpace *AcDocument*)
  •   *BLKS* (vla-get-Blocks *AcDocument*)
  •   *LAYS* (vla-get-Layers *AcDocument*)
  •   *ACLYS*  (vla-get-activeLayer *AcDocument*)
  •   *LTS*  (vla-get-Linetypes *AcDocument*)
  •   pi2     (* pi 0.5)
  •   pi4     (* pi 0.25)
  •   3pi4   (* 0.75 pi)
  •   2pi     (+ pi pi)
  •   3pi2   (+ 3pi4 3pi4)  ;; (* 1.5 pi)
  •   5pi4   (+ pi pi4)  ;;(* 1.25 pi)
  •   7pi4   (+ 3pi2 pi4) ;;(* 1.75 pi)
  • (defun _Undo1 () (vla-StartUndoMark *AcDocument*))
  • (defun _Undo2 () (vla-EndUndoMark *AcDocument*))
  • ;;例setq h (dxf1 ent 40)) ; ent 为实体名或实体entget,取得图元参数值内容----------(一级)------------------
  • (defun dxf1 (ent i / tmp)
  •   (if (= (type ent) 'ENAME)
  •     (setq ent (entget ent '("*")))
  •   (setq tmp (cdr (assoc i ent)))
  •   (if (null tmp)
  •     (cond
  •       ((= i 66) 0)
  •       ((= i 62) 256)
  •       ((= i 370) (setq tmp -1))
  •       ((= i 6) "ByLayer")
  •     tmp
  • ;;返回 obj的 vla对象名-------(一级)------------------
  • (defun en2obj (object)
  •   (cond
  •     ((= (type object) 'vla-object)
  •       object
  •     ((= (type object) 'ename)
  •       (vl-catch-all-apply '(lambda () (setq object (vlax-ename->vla-object object))))  ;;避免天正实体出错退出
  •   object
这都函数罢了,
发表于 2021-10-22 22:21:43 | 显示全部楼层
感谢尘缘分享.
发表于 2021-10-23 08:53:40 | 显示全部楼层
我都等了好久的明经了,这次奔溃的有点久哈哈。
发表于 2021-10-23 10:55:44 | 显示全部楼层
同贺,关了半个月,终于重见天日
发表于 2021-10-23 17:19:19 | 显示全部楼层
论坛恢复是
值得高兴的事
谢谢大师的分享
 楼主| 发表于 2021-10-23 23:20:57 | 显示全部楼层
不是站长的事,是服务器问题,也不一定是黑客攻击,可能服务器在维护吧。
发表于 2021-10-24 11:34:33 | 显示全部楼层
发表于 2021-10-24 11:59:30 | 显示全部楼层
CAD2020显示
GMT+8, 2025-5-24 15:56 , Processed in 0.204675 second(s), 25 queries , Gzip On.
