查看: 814|回复: 0
[提问] 选取同一个矩形范围内的对象,执行多个不同的命令
发表于 2021-10-30 09:59:36 | 显示全部楼层 |阅读模式
选取同一个矩形范围内的对象,执行多个不同的命令,这样会提示无效选择
(defun C:BNN()
(princ "\n---炸开+查找复线+自动串接---")
(setq P1 (getpoint "\n指定第一点: "))
(setq P2 (getcorner P1 "\n指定第二点: "))
(princ "\n---炸开对象---")
(command "EXPLODE" "w" P1 P2)
(princ "\n---查找复线---")
(command "DUP" "w" P1 P2)
(princ "\n---局部串接---")
(command "AJ" "w" P1 P2 )
GMT+8, 2025-5-16 11:33 , Processed in 0.165771 second(s), 24 queries , Gzip On.
