查看: 1415|回复: 4
[提问] 用command做了一些图层操作,操作后用ctrl+z要很多次才能撤销,有办法一次撤销么
发表于 2021-11-12 22:22:12 | 显示全部楼层 |阅读模式
(defun c:av ()
;打开所有、关闭计算书图层、
    (setvar "cmdecho" 0)
(setvar "Expert" 1)
(command "Layer" "on" "*"  "")(princ)
(command "Layer" "off" "*建筑图*|*"  "")(princ)
(command "Layer" "off" "*建施*|*"  "")(princ)
(command "Layer" "off" "*景观施*|*"  "")(princ)
(command "Layer" "off" "*人防施*|*"  "")(princ)
(command "Layer" "off" "*wpj*|*"  "")(princ)
(command "Layer" "off" "*配筋*|*"  "")(princ)
(command "Layer" "off" "*导荷*|*"  "")(princ)
(command "Layer" "off" "*板配筋*|*"  "")(princ)
(command "Layer" "off" "*配筋结果*|*"  "")(princ)
(command "Layer" "off" "*计算结果*|*"  "")(princ)
(command "Layer" "off" "*荷载简图*|*"  "")(princ)
(command "Layer" "off" "*荷载校核*|*"  "")(princ)
(command "Layer" "off" "*挠度*|*"  "")(princ)
(command "Layer" "off" "*冲切*|*"  "")(princ)
(command "Layer" "off" "*沉降*|*"  "")(princ)
(command "Layer" "on" "*结构参*"  "")(princ)
(command "Layer" "on" "*建筑参*"  "")(princ)
(setvar "Expert" 0)
    (setvar "cmdecho" 1)
发表于 2021-11-12 23:37:41 | 显示全部楼层
楼主整复杂了,注意command命令不能关闭当前图层.以下为简单示例.
  1. (defun c:tt ()
  2.   (command "undo" "be")
  3.   (command "Layer" "off" "text" "")
  4.   (command "Layer" "off" "text1" "")
  5.   (command "undo" "e")
  6.   (prin1)
  7. )
发表于 2021-11-12 22:25:11 来自手机 | 显示全部楼层
在程序前面加上undo begin,末尾加上undo,论坛搜关键词undo
 楼主| 发表于 2021-11-12 22:55:46 | 显示全部楼层
编组之后,就可以一次撤销
;;编组开始;(command "_.undo" "be")
(defun _StartUndo (*DOC*)
  (_EndUndo *DOC*)
  (vla-StartUndoMark *DOC*)
;;结束编组;(if (= 8 (logand (getvar "undoctl") 8)) (command "_.undo" "_e"))
(defun _EndUndo        (*DOC*)
  (if (= 8 (logand 8 (getvar 'UNDOCTL)))
    (vla-EndUndoMark *DOC*)
(defun c:av ()
;打开所有、关闭计算书图层、
_StartUndo()
(setvar "Expert" 1)
(setvar "Expert" 0)
_EndUndo()
是这样吗,还是不能一步撤掉呢,还是要撤好多步
 楼主| 发表于 2021-11-13 08:57:17 | 显示全部楼层
好的,我是做结构设计的码盲。。。只会简单的调用哈,谢谢~
GMT+8, 2025-5-1 05:56 , Processed in 0.164488 second(s), 26 queries , Gzip On.
