查看: 1756|回复: 3
[提问] 求一个代码,点文字后自动增加字符“%%u”,如果文字前三个字符是“%%u”,则删除%%u
发表于 2021-11-13 17:22:38 | 显示全部楼层 |阅读模式
5明经币
用来给钢筋符号加下划线,谢谢~ 麻烦用while语句,可以连续点选框选
最佳答案
查看完整内容
;看看下面这个行不行,未测试 (defun c:wzshx() (setvar "cmdecho" 0) (command "_undo" "be" ) (while (setq ent (car (entsel "\n请选取文字:"))) (setq dxf (entget ent)) (setq name (cdr (assoc 0 dxf))) (If (= name "TEXT") (progn (setq dxf1 (assoc 1 dxf)) (setq zfc (cdr dxf1)) (If (wcmatch zfc "%%u*") (setq dxf (subst (co ...
发表于 2021-11-13 17:22:39 | 显示全部楼层
;看看下面这个行不行,未测试
(defun c:wzshx()
       (If (= name "TEXT")
                   (setq dxf (subst (cons 1 (substr zfc 4)) dxf1 dxf))
                   (setq dxf (subst (cons 1 (strcat "%%u" zfc)) dxf1 dxf))
               (entmod dxf)
           (alert "所选取的图元不是单行文字!")
    (command "_undo" "e")
    (setvar "cmdecho" 1)
 楼主| 发表于 2021-11-13 22:57:40 | 显示全部楼层
yshf 发表于 2021-11-13 17:22
;看看下面这个行不行,未测试
(defun c:wzshx()
可以了,谢谢~
发表于 2021-11-14 13:53:19 | 显示全部楼层
这个用增加删除前后缀的就可以了吧
GMT+8, 2025-5-1 06:20 , Processed in 0.135688 second(s), 24 queries , Gzip On.
