查看: 1754|回复: 16
[讨论] 求助一下,如何在小菜选择易如何添加一个标注比例选项,
发表于 2021-11-28 22:56:36 | 显示全部楼层 |阅读模式
求助一下,如何在小菜选择易如何添加一个标注比例的选项,说下原因,我工作时有标注是同一种标注,画大图时用的是1:20,做大样时,比例是1:3左右,标注时大样尺寸会在大图里,很影响观感,就要把大样标注在大图中隐藏,如果一个个隐藏比较费时间,就想到这个办法,能否实现呢。各位大哥,还有个不好意思,我不能发出小菜选择易源码,这是他的劳动成果,我只是想借助下论坛里增加个功能
("通用" ((0 "实体类型") (6 "实体线型") (8 "所在图层") (48 "线型比例") (62 "实体颜色" ((256 "随层") (0 "随块") (1 "红色") (2 "黄色") (3 "绿色")
         (4 "青色") (5 "蓝色") (6 "紫色") (7 "黑白"))) (370 "实体线宽")))
("ARC" ((-4 "圆弧") (10 "圆心坐标") (40 "圆弧半径") (39 "实体厚度") (50 "起点角度") (51 "终点角度")) ("FJ" ("FJ1" "圆弧长度" (len slent))))
("CIRCLE" ((-4 "圆形") (10 "圆心坐标") (40 "圆形半径") (39 "实体厚度")))
("SOLID" ((-4 "SOLID") (39 "实体厚度")))
("POINT" ((-4 "点") (10 "点的位置") (39 "实体厚度") (50 "旋转角度")))
("LINE" ((-4 "直线段") (10 "起点坐标") (11 "终点坐标") (39 "实体厚度")) ("FJ" ("FJ1" "线段长度" (len slent))
         ("FJ2" "线段角度" (REM (ATOF (ANGTOS (ANGLE (DXF 10 slent) (DXF 11 slent)))) 180))))
("ELLIPSE" ((-4 "椭圆") (10 "椭圆中心") (11 "长轴端点") (40 "长短轴比") (41 "开始参数") (42 "结束参数")))
("INSERT" ((-4 "图块") (10 "图块位置") (2 "图块名称") (41 "X 轴比例") (42 "Y 轴比例") (43 "Z 轴比例") (50 "旋转角度")))
           ;("FJ" ("FJ1" "属性标志" (car (attstr slent))) ("FJ2" "属性数值" (cadr (attstr slent)))))
("LWPOLYLINE" ((-4 "轻多义线") (38 "复线标高") (43 "固定宽度") (90 "顶点个数") (39 "复线厚度") (70 "是否闭合" ((0 "不闭合") (1 "闭合"))))
               ("FJ" ("FJ1" "曲线长度" (len slent))))
("POLYLINE" ((-4 "重多义线") (70 "是否闭合" ((0 "不闭合") (1 "闭合")))) ("FJ" ("FJ1" "曲线长度" (len slent ))))
("HATCH" ((-4 "图案填充") (2 "填充图案") (41 "填充比例") (52 "填充角度") (71 "边界关联" ((0 "不关联") (1 "关联")))
          (76 "图案类型" ((0 "用户定义") (1 "预定义") (2 "自定义")))))
("TEXT" ((-4 "文字") (1 "文字内容") (7 "文字样式") (10 "插入位置") (40 "文字高度") (41 "宽度系数") (50 "旋转角度") (51 "倾斜角度")
         (71 "文字镜像" ((0 "默认") (2 "文字反向") (4 "文字倒置") (6 "反向倒置")))
         (72 "水平对齐" ((0 "左对齐") (1 "居中对齐") (2 "右对齐") (3 "对齐") (4 "中间") (5 "拟合")))
         (73 "垂直对齐" ((0 "基线对齐") (1 "底端对齐") (2 "居中对齐") (3 "顶端对齐")))) ("FJ" ("FJ1" "文字数值" (ATOF (DXF 1 slent)))))
("ATTDEF" ((-4 "属性定义") (2 "属性标记") (7 "字型样式") (10 "插入位置") (40 "文字高度") (50 "旋转角度") (51 "倾斜角度")
           (73 "垂直对齐" ((0 "基线对齐") (1 "底端对齐") (2 "居中对齐") (3 "顶端对齐")))) ("FJ" ("FJ1" "标记数值" (ATOF (DXF 2 slent)))))
("MTEXT" ((-4 "多行文字") (10 "插入位置") (1 "文字内容") (7 "文字样式") (40 "文字高度") (50 "旋转角度")))
("SPLINE" ((-4 "样条曲线") (70 "曲线标志") (71 "曲线阶数") (72 "节点数量") (73 "控制点数") (74 "拟合点数")
           (42 "节点公差") (43 "控点公差") (44 "拟合公差")) ("FJ" ("FJ1" "曲线长度" (len slent))))
("DIMENSION" ((-4 "尺寸标注") (1 "标注文字") (42 "测量值") (3 "标注样式") (70 "标注类型" ((32 "水平垂直") (33 "对齐标注") (34 "角度标注")
              (35 "直径标注") (36 "半径标注") (37 "三点角度") (38 "坐标标注")))))
 楼主| 发表于 2021-11-30 09:39:41 | 显示全部楼层
小菜123 发表于 2021-11-29 18:58
大样标在一个图层上,然后这个图层在不需要显示的那个视口冻结,不就可以了吗?
我知道这是可以的,用插件就是为了省点时间,能增加这个功能就能够直接全部冻结这个小的标注,不然还得一个一个冻结呢
 楼主| 发表于 2021-11-30 11:19:57 | 显示全部楼层
小菜123 发表于 2021-11-30 11:01
对这个操作不大熟悉,冻结标注是针对一个视口内的图层,也不需要选择实体
菜大师,我们讨论的是如何在选择易上面显示标注上有比例选项,就是比例大小,再进行选择,我们跑偏了哦
 楼主| 发表于 2021-11-29 10:26:48 | 显示全部楼层
小菜123 发表于 2021-11-29 09:39
在DIMESION的附加过滤处增加代码,发个样图看看
把作者捞过来了,不好意思,发了你的一部分代码,这是图片
直接发dwg  发表于 2021-11-29 11:09
发表于 2021-11-29 09:39:36 | 显示全部楼层
 楼主| 发表于 2021-11-29 11:11:26 | 显示全部楼层
这是DWG格式的
 楼主| 发表于 2021-11-29 11:31:23 | 显示全部楼层
这是DWG格式的
应该要修复一下http://bbs.mjtd.com/forum.php?mod=viewthread&tid=184447&highlight=%D0%DE%B8%B4  发表于 2021-11-29 13:42
为什么显示图形文件无效  发表于 2021-11-29 12:27
 楼主| 发表于 2021-11-29 14:02:29 | 显示全部楼层
现在看呢 ,有没有问题了
忘 了论坛自动加了一个回车,删掉就行了,明天看  发表于 2021-11-29 18:51
发表于 2021-11-29 18:58:31 | 显示全部楼层
发表于 2021-11-29 20:35:49 | 显示全部楼层
DIMSCALE  模型空间设置尺寸比例
DIMLFAC    图纸空间设置尺寸比例
DIMRND    设置尺寸四舍五入值
发表于 2021-11-30 11:01:33 | 显示全部楼层
GMT+8, 2025-5-16 12:27 , Processed in 0.195466 second(s), 33 queries , Gzip On.
