查看: 2250|回复: 12
[提问] 各位大神看下,这个是明经里面的程序,截取文字并改,能不能改成截取文字到粘贴板
发表于 2021-12-3 14:55:50 | 显示全部楼层 |阅读模式
(defun explodestr(a / c);;字串拆分by llsheng_73
  (setq a(vl-string->list a))
  (while(if(<(car a)129)
          (setq c(cons(chr(car a))c)a(cdr a))
          (setq c(cons(strcat(chr(car a))(chr(cadr a)))c)a(cddr a))))
  (reverse c))
(defun Rot2D(v a / c s x y)
(setq c(cos a)s(sin a))
  (setq x(car v)y(cadr v))
  (list(-(* x c)(* y s))(+(* x s)(* y c))))
(defun ponline(p p1 p2)
  (setq p(trans(mapcar'- P P1)0(mapcar'- P2 P1)))
  (list(last p)(car p)))
(defun TextUnder(e / a p);;by llsheng_73
  (setq p(cdr(assoc 10 e))
        a(cdr(assoc 50 e))
        e(textbox e))
  (mapcar'(lambda(x)(mapcar'+(Rot2D x a)p))(list(car e)(list(caadr e)(cadar e)))))
(defun positionoftxt(e p1 / p d strs i j str a)
  (setq e(entget e)i 1
        a(assoc 1 e)
        p(TextUnder e)str'nil
        d(car(apply'ponline(cons p1 p)))
        d(if(> d(apply'distance p))(apply'distance p)d)
        strs(explodestr(cdr(assoc 1 e)))
        str(mapcar'(lambda(x)(vl-string-translate" ""-"x))
                  (reverse(repeat(length strs)(setq j 0 i(1+ i)str(cons(apply'strcat(vl-remove-if'(lambda(x)(>=(setq j(1+ j))i))strs))str))))))
  (cond((<= d(apply'distance(TextUnder(subst(cons 1(car str))a e))))0)
       ((<=(apply'distance(TextUnder(subst(cons 1(nth(1-(length str))str))(assoc 1 e)e)))d)(length str))
       (t(setq j 0)
        (while(not(<(apply'distance(TextUnder(subst(cons 1(nth j str))a e)))d
                    (apply'distance(TextUnder(subst(cons 1(nth(setq j(1+ j))str))a e))))))j)
(defun c:tt(/ a b p1 p2 i s c1 c2 c3 p str strs);;屏幕改字
  (while(and(setq b(*(getvar'viewsize)0.01(getvar'cursorsize))
                       i 0 p1(getpoint"\n截取文字第一点"))
                 (setq p2(getpoint"第二点"p1))
                 (setq a(angle p1 p2))
                   (while(and(< i 4)(null(setq i(1+ i)s(ssget"F"(list(polar p1(+ a pi)(* b i))(polar p2 a(* b i)))'((0 . "TEXT")))))))
                   (setq s(if s(ssname s 0)))))
    (setq p(vl-sort(mapcar'(lambda(x)(positionoftxt s(trans x 1 0)))(list p1 p2))'<)
          s(entget s)
          a(assoc 1 s)
          strs(explodestr(cdr a))
          i -1 c1'nil c2'nil c3 nil
          c1(apply'strcat(reverse(repeat(car p)(setq i(1+ i)c1(cons(nth i strs)c1)))))
          i(1-(car p))
          c2(if(apply'= p)(nth(car p)strs)(apply'strcat(reverse(repeat(-(last p)(car p))(setq i(1+ i)c2(cons(nth i strs)c2))))))
          i(1-(last p))
          c3(apply'strcat(reverse(repeat(-(length strs)(last p))(setq i(1+ i)c3(cons(nth i strs)c3))))))
    (if(setq str(getstring(strcat" \""c2"\"替换为:")t))
      (entmod(subst(cons 1(strcat c1 str c3))(assoc 1 s)s))))
  (princ))
发表于 2021-12-4 17:14:45 | 显示全部楼层
  • (defun explodestr(a / c);;字串拆分by llsheng_73
  •   (setq a(vl-string->list a))
  •   (while(if(<(car a)129)
  •           (setq c(cons(chr(car a))c)a(cdr a))
  •           (setq c(cons(strcat(chr(car a))(chr(cadr a)))c)a(cddr a))))
  •   (reverse c))
  • (defun Rot2D(v a / c s x y)
  • (setq c(cos a)s(sin a))
  •   (setq x(car v)y(cadr v))
  •   (list(-(* x c)(* y s))(+(* x s)(* y c))))
  • (defun ponline(p p1 p2)
  •   (setq p(trans(mapcar'- P P1)0(mapcar'- P2 P1)))
  •   (list(last p)(car p)))
  • (defun TextUnder(e / a p);;by llsheng_73
  •   (setq p(cdr(assoc 10 e))
  •         a(cdr(assoc 50 e))
  •         e(textbox e))
  •   (mapcar'(lambda(x)(mapcar'+(Rot2D x a)p))(list(car e)(list(caadr e)(cadar e)))))
  • (defun positionoftxt(e p1 / p d strs i j str a)
  •   (setq e(entget e)i 1
  •         a(assoc 1 e)
  •         p(TextUnder e)str'nil
  •         d(car(apply'ponline(cons p1 p)))
  •         d(if(> d(apply'distance p))(apply'distance p)d)
  •         strs(explodestr(cdr(assoc 1 e)))
  •         str(mapcar'(lambda(x)(vl-string-translate" ""-"x))
  •                   (reverse(repeat(length strs)(setq j 0 i(1+ i)str(cons(apply'strcat(vl-remove-if'(lambda(x)(>=(setq j(1+ j))i))strs))str))))))
  •   (cond((<= d(apply'distance(TextUnder(subst(cons 1(car str))a e))))0)
  •        ((<=(apply'distance(TextUnder(subst(cons 1(nth(1-(length str))str))(assoc 1 e)e)))d)(length str))
  •        (t(setq j 0)
  •         (while(not(<(apply'distance(TextUnder(subst(cons 1(nth j str))a e)))d
  •                     (apply'distance(TextUnder(subst(cons 1(nth(setq j(1+ j))str))a e))))))j)
  • (defun ZML-CLIP-SETSTRING (STR / HTML RESULT)
  •   (and (= (type STR) 'STR)
  •        (setq HTML (vlax-create-object "htmlfile"))
  •        (setq RESULT (vlax-invoke
  •                       (vlax-get        (vlax-get HTML 'PARENTWINDOW)
  •                                 'CLIPBOARDDATA
  •                       'SETDATA
  •                       "Text"
  •                       STR
  •        (vlax-release-object HTML)
  • (defun c:tt (/ a b p1 p2 i s c1 c2 c3 p str strs esc os);;屏幕改字
  •   (setq os (getvar "OSMODE"))
  •   (setvar "OSMODE" 16384)
  •   (while (and (null esc)
  •            (setq b (* (getvar'viewsize) 0.01 (getvar'cursorsize))
  •                 i 0
  •                 p1 (getpoint"\n截取文字第一点")
  •            (setq p2 (getpoint "第二点" p1))
  •            (setq a (angle p1 p2))
  •            (progn
  •              (while (and (< i 4)
  •                       (null (setq i (1+ i)
  •                               s (ssget "F" (list (polar p1 (+ a pi) (* b i)) (polar p2 a (* b i))) '((0 . "TEXT")))
  •              (setq s (if s (ssname s 0)))
  •     (setq p (vl-sort (mapcar '(lambda (x)
  •                                 (positionoftxt s(trans x 1 0)))
  •                        (list p1 p2)
  •       s (entget s)
  •       a (assoc 1 s)
  •       strs (explodestr(cdr a))
  •       i -1
  •       c1 'nil
  •       c2 'nil
  •       c3 nil
  •       c1 (apply 'strcat (reverse (repeat (car p)
  •                                    (setq i (1+ i)
  •                                      c1 (cons (nth i strs) c1)
  •       i (1- (car p))
  •       c2 (if (apply '= p)
  •            (nth (car p) strs)
  •            (apply 'strcat
  •              (reverse (repeat (- (last p) (car p))
  •                         (setq i (1+ i)
  •                           c2 (cons (nth i strs) c2)
  •       i (1- (last p))
  •       c3 (apply 'strcat
  •            (reverse (repeat (- (length strs) (last p))
  •                       (setq i (1+ i)
  •                         c3 (cons (nth i strs) c3)
  •     (if c2
  •       (progn
  •         (ZML-CLIP-SETSTRING c2)
  •         (setq esc T)
  •         (princ (strcat "\n>>>>>>成功复制:" c2))
  •       (princ "\n>>>>>>未选中文字对象!")
  •   (setvar "OSMODE" os)
  •   (princ)
 楼主| 发表于 2024-4-27 17:19:04 | 显示全部楼层
ssyfeng 发表于 2021-12-6 12:05
没有这个函数,我发文件你直接加载试试:
大哥你好,这个能不能能改一下,改成截取文字后,直接提示点击屏幕上的一点 ,然后把截取的部分插入到cad里面,文字的属性和原来的都一样
 楼主| 发表于 2021-12-5 09:54:02 | 显示全部楼层
  •   (while( ...
  • 你好大神怎么运行不起来
     楼主| 发表于 2021-12-5 09:49:44 | 显示全部楼层
  •   (while( ...
  • 谢谢大神.....
    发表于 2021-12-6 09:11:22 | 显示全部楼层
    可能是你捕捉开着吧,我等下修改一下,把拾取点的时候把捕捉关了就好了。你自己可以关了捕捉试试
    发表于 2021-12-6 09:15:33 | 显示全部楼层
     楼主| 发表于 2021-12-6 11:03:03 | 显示全部楼层
    好了是吗 ,那我试一下 哦
     楼主| 发表于 2021-12-6 11:04:10 | 显示全部楼层
    no function definition: A为啥一直提示的这个
    发表于 2021-12-6 12:05:03 | 显示全部楼层
    没有这个函数,我发文件你直接加载试试:
     楼主| 发表于 2021-12-6 14:38:03 | 显示全部楼层
    没有这个函数,我发文件你直接加载试试:
    你好大佬你发的这个就可以运行谢谢了
    GMT+8, 2025-4-23 05:51 , Processed in 0.210677 second(s), 29 queries , Gzip On.
