 - defun MJ:export (ss SaveName / s)
- (defun MJ:enbox (en)
- (vla-getboundingbox (vlax-ename->vla-object en) 'll 'ur)
- (mapcar 'vlax-safearray->list (list ll ur))
- (defun MJ:SS2en (ss)
- (vl-remove-if-not
- '(lambda (x) (= (type x) 'ename))
- (apply 'append (ssnamex ss))
- (defun MJ:Extents (plist)
- (list (apply 'mapcar (cons 'min plist))
- (apply 'mapcar (cons 'max plist))
- (defun MJ:SSbox (ss / extents ss2en enbox)
- (MJ:extents
- (apply 'append (mapcar 'MJ:enbox (MJ:ss2en ss)))
- (vl-cmdf "_zoom" (car (setq s (MJ:ssbox ss))) (cadr s))
- (command "export" "d:\\1.bmp" "")
