查看: 877|回复: 3
[讨论] 请大侠指点:下面的代码为何不能输入0
发表于 2021-12-13 23:56:15 | 显示全部楼层 |阅读模式
偏移量输入默认值0就运行不了,为什么呢?输入不为0的数值都正常
(defun c:O ()
        (setq x(getreal (strcat "输入水平偏移:<" (rtos 0) ">")))
        (setq y(getreal (strcat "输入垂直偏移:<" (rtos 0) ">")))
        (setq cp(getpoint "选择基点:"))
        (setq px1(car cp))
        (setq py1(cadr cp))
        (setq mx(+ px1 x))
        (setq my(+ py1 y))
        (setq mpt(list mx my))
        (command "LINE" mpt PAUSE "")
发表于 2021-12-14 11:39:58 | 显示全部楼层
(defun c:O (/ cp x y)
        (setq x (if (= (setq x (getreal (strcat "\n输入水平偏移:<" (rtos 0) ">"))) nil) 0 x))
        (setq y (if (= (setq y (getreal (strcat "\n输入水平偏移:<" (rtos 0) ">"))) nil) 0 y))
        (setq cp (getpoint "\n选择基点:"))
        (command "LINE" (list (+ (car cp) x) (+ (cadr cp) y)) PAUSE "")
发表于 2021-12-14 10:56:23 | 显示全部楼层
x y 默认值没有设置,直接确认,输入为空
发表于 2021-12-14 16:22:58 | 显示全部楼层
fangmin723為基礎
       (if (not x) (setq x 0))  ;增加這一行
        (if (not y) (setq y 0))  ;增加這一行
        (setq x (if (= (setq x (getreal (strcat "\n输入水平偏移:<" (rtos x) ">"))) nil) 0 x)) ;(rtos 0)改成(rtos x)
        (setq y (if (= (setq y (getreal (strcat "\n输入水平偏移:<" (rtos y) ">"))) nil) 0 y)) ;(rtos 0)改成(rtos y) 就可以記憶上次輸入的值了
GMT+8, 2025-5-16 11:28 , Processed in 0.167676 second(s), 25 queries , Gzip On.
