查看: 2297|回复: 10
[资源] 论坛压缩包不能打开的修复程序
发表于 2021-12-19 19:36:08 | 显示全部楼层 |阅读模式
论坛可能避免为病毒感染,自动添加修改了首字节,运行下面的lisp程序可以自动删除首字节,
压缩包即可正常解开。这个程序就不打包上传了,不然无法解开压缩包。
  1. ;; 明经通道论坛 2021-12-19  yxp
  2. ;; 删除一个文件多余的head字节,0D0A
  3. (vl-load-com)
  4. (defun c:deletebyte (/ a LSP isUnnec)
  5.   (setq a (getfiled "选择需要删除首字节的文件"
  6.                     (if filesPathDefault filesPathDefault "")
  7.                     "*"
  8.                     0
  9.           )
  10.   )
  11.   (if a
  12.     (progn
  13.       (setq filesPathDefault a
  14.             LSP              (read_Bin a)
  15.             isUnnec          (and (= (car LSP) 13) (= (cadr LSP) 10))
  16.             exten            (vl-filename-extension a)
  17.             fnanme           (vl-string-trim exten a)
  18.             newFilesName     (strcat fnanme "_mod" exten)
  19.       )
  20.       (if isUnnec
  21.         (progn
  22.           (write_Bin (cddr LSP) newFilesName)
  23.           (princ "\n文件首字节已删除,保存在 ")
  24.           (princ newFilesName)
  25.         )
  26.         (princ "文件首字节不符合删除要求")
  27.       )
  28.     )
  29.   )
  30.   (princ)
  31. )
  32. (defun write_Bin (Blist file / ADO vbin)
  33.   (setq vbin (vlax-make-safearray 17 (cons 0 (1- (length Blist)))))
  34.   (vlax-safearray-fill vbin Blist)
  35.   (vlax-make-variant vbin)
  36.   (setq ADO (vlax-create-object "ADODB.Stream"))
  37.   (vlax-put-property ADO 'type 1)
  38.   (vlax-invoke-method ADO 'open 'nil 'nil 'nil 'nil 'nil)
  39.   (vlax-invoke-method ADO 'Write vbin)
  40.   (vlax-invoke-method ADO 'saveToFile file 2)
  41.   (vlax-invoke-method ADO 'close)
  42.   (vlax-release-object ADO)
  43. )
  44. (defun read_Bin (file / vbin ADO)
  45.   (setq ADO (vlax-create-object "ADODB.Stream"))
  46.   (vlax-put-property ADO 'type 1)
  47.   (vlax-invoke-method ADO 'open 'nil 'nil 'nil 'nil 'nil)
  48.   (vlax-invoke-method ADO 'LoadFromFile file)
  49.   (setq vbin (vlax-invoke-method ADO 'read 'nil))
  50.   (vlax-invoke-method ADO 'close)
  51.   (vlax-release-object ADO)
  52.   (vlax-safearray->list (vlax-variant-value vbin))
  53. )
  54. (princ "载入成功,命令:deletebyte")
  55. (princ)
参与人数 3明经币 +3 收起 理由
wanghangshun + 1 赞一个!
bssurvey + 1 赞一个!
tigcat + 1 感谢Y版分享程序
发表于 2021-12-19 19:50:54 | 显示全部楼层
很不错的lsp程序
发表于 2021-12-19 20:23:45 | 显示全部楼层
666不错的lsp
发表于 2021-12-20 07:35:24 | 显示全部楼层
很不錯的lsp程序
发表于 2021-12-20 12:52:56 | 显示全部楼层
感谢y版的修复工具
发表于 2021-12-20 22:26:50 | 显示全部楼层
很不錯的lsp程序
发表于 2021-12-21 09:18:50 | 显示全部楼层
chrome浏览器用Internet Download Manager下载,不用搞修复这回事,一点问题都没有
发表于 2021-12-21 10:21:02 | 显示全部楼层
这个也是一个大神写的,海大神的,也分享给大家!
(vl-Load-COM)
(defun try-file-ReadBinary (FileName / node size str stream xmldom)
        (setq xmldom (vlax-create-object "Microsoft.XMLDOM"))
        (setq node (vlax-invoke-method xmldom 'CreateElement "binary"))
        (vlax-put-Property node 'DataType "bin.hex")
        (setq stream (vlax-create-object "ADODB.Stream"))
        (vlax-put-Property stream 'type 1)
        (Vlax-Invoke stream 'open)
        (vlax-invoke-method
                stream
                'LoadFromFile
                FileName
        (setq size(vlax-get-Property stream 'size))
        (vlax-put-Property node 'NodeTypedValue (Vlax-Invoke-Method stream 'Read size))
        (Vlax-Invoke-Method stream 'close)
        (setq str (vlax-get-Property node 'text))
        (vlax-release-object xmldom)
        str
(defun try-file-WriteBinary (file str / node stream xmldom)
        (vlax-put-Property node 'Text str)
        (vlax-invoke-method stream 'write
                (vlax-get-Property node 'NodeTypedValue)
        (vlax-invoke-method stream 'saveToFile file 2)
        (vlax-release-object stream)
(defun c:mjtd (/ file h16 h16-2 newfile)
        (setq file(getfiled "选择一个文件" "" "*" 0))
        (or file (exit))
        (setq
                h16(try-file-ReadBinary file)
                h16-2(substr h16 5)
        (setq newfile (strcat(vl-filename-directory file)"\\"(vl-filename-base file)"_new"(vl-filename-extension file)))
        (try-file-WriteBinary newfile h16-2)
        (princ(strcat"\n处理完成,生成新文件"newfile))(princ)
发表于 2021-12-21 10:28:57 | 显示全部楼层
大神的ssget总结让人受益匪浅
发表于 2021-12-21 14:12:24 | 显示全部楼层
不错不错,收藏使用了
GMT+8, 2025-12-15 07:04 , Processed in 0.183987 second(s), 30 queries , Gzip On.
