- 积分
- 28214
- 明经币
- 个
- 注册时间
- 2003-8-26
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
有很多人觉得 grread加捕捉挺难,以前研究过大神的程序,自己整了个grread带捕捉的子函数,感觉挺好用,需要grread带捕捉功能直接调用子函数。下面是我最新编的画螺纹孔程序用到了,发出来仅供参考。
;;; 功能:螺纹孔程序
;;; 作者:langjs 命令:lwk 日期:2022年02月14日
(defun c:lwk (/ #err $orr bl code color d dbl dd ent ent1 ent2 ent3 ent4 gr h i k loop lst n name1 name2 name3 name4 nearpt
nearpt2 old_lay osmo p pt pt1 pt2 pt3 pt4 pt5 ptx pty ss x
(defun osnappt (ss pt / color d h i k lst nearpt nearpt2 osmo pt1 pt2 pt3 pt4 pt5 ptx pty x) ; grread捕捉子函数
(if (= (type ss) 'ename)
(entdel ss)
(if (= (type ss) 'pickset)
(repeat (setq i (sslength ss))
(entdel (ssname ss (setq i (1- i))))
(redraw)
(if (< (getvar "osmode") 16384)
(setq color (vla-get-autosnapmarkercolor (vla-get-drafting (vla-get-preferences (vlax-get-acad-object))))
h (/ (getvar "viewsize") (cadr (getvar "screensize")))
d (getvar "pickbox")
lst (list (* d h) (* (- d 0.5) h) (* (+ d 0.5) h))
k (* 1.5 d h)
(if (setq nearpt (osnap pt "_END,_CEN,_NOD,_QUA,_INS,_TAN,_EXT"))
(setq osmo 1)
(if (and
(setq nearpt2 (osnap pt "_NEA"))
(not (equal nearpt nearpt2 k))
(setq osmo 2
nearpt nearpt2
(if (and
(setq nearpt2 (osnap pt "_MID"))
(setq osmo 3
nearpt nearpt2
(if (and
(setq nearpt2 (osnap pt "_INT"))
(setq osmo 4
nearpt nearpt2
(entdel ss)
(if nearpt
(setq ptx (car nearpt)
pty (cadr nearpt)
(foreach x lst
(setq pt1 (list (- ptx x) (- pty x))
pt2 (list (+ ptx x) (- pty x))
pt3 (list (+ ptx x) (+ pty x))
pt4 (list (- ptx x) (+ pty x))
pt5 (list ptx (+ pty x))
(cond
((= osmo 1) ; 正方形
(grvecs (list color pt1 pt2 pt2 pt3 pt3 pt4 pt4 pt1))
((= osmo 2) ; 俩三角
(grvecs (list color pt1 pt2 pt2 pt4 pt3 pt4 pt3 pt1))
((= osmo 3) ; 三角
(grvecs (list color pt1 pt2 pt2 pt5 pt5 pt1))
((= osmo 4) ; 交叉
(grvecs (list color pt1 pt3 color pt2 pt4))
(setq pt nearpt)
pt
(defun emod (ent i n) ; 更新图元函数
(subst
(cons i n)
(assoc i ent)
ent
(defun #err (s / i) ; 出错处理子函数
(redraw)
(if ss
(command ".UNDO" "E")
(setq *error* $orr)
(setq $orr *error*)
(setq *error* #err)
(setvar "cmdecho" 0)
(command ".UNDO" "BE")
(setq old_lay (getvar "clayer"))
(if (not (tblsearch "layer" "02细实线层"))
(vl-cmdf "_layer" "make" "02细实线层" "Color" 3 "" "L" "Continuous" "" "")
(if (not (tblsearch "layer" "03中心线层"))
(vl-cmdf "_layer" "make" "03中心线层" "Color" 5 "" "L" "CENTER" "" "")
(setvar "clayer" old_lay)
(if (null d)
(setq d (getreal "\n螺纹孔尺寸M:"))
(princ (strcat "\n螺纹孔尺寸:<M" (rtos d 2 2) ">"))
(setq lst (list '(1.2 0.25) '(1.4 0.3) '(1.8 0.35) '(2 0.4) '(2.5 0.45) '(3 0.5) '(3.5 0.6) '(4 0.7) '(4.5 0.75) '
(5.5 0.8) '(6 1) '(9 1.25) '(11 1.5) '(12 1.75) '(16 2) '(22 2.5) '(27 3) '(33 3.5) '(39 4) '(45 4.5) '
(52 5) '(60 5.5) '(149 6) '(1000000 8)
(foreach x lst
(if (and
(null p)
(<= d (car x))
(setq p (cadr x))
(if (<= d 1.2)
(setq p (* 0.2 d))
(setq dbl (getvar "DIMSCALE"))
(if (< d (* 3 dbl))
(setq dd d)
(setq dd (+ (* 0.5 d) (* 3 dbl)))
(if (< (setq n (* 2 dd))
(* 2 dbl)
(setq bl (/ n (cdr (assoc 40 (tblsearch "ltype" "CENTER"))) (getvar "LTSCALE")))
(setq bl (/ (* 2 dbl) (cdr (assoc 40 (tblsearch "ltype" "CENTER"))) (getvar "LTSCALE")))
(setq ss (ssadd))
(entmake (list '(0 . "LINE") (cons 8 "03中心线层") (cons 48 bl) (cons 10 '(0.0 0.0)) (cons 11 '(0.0 0.0))))
(setq name1 (entlast)
ent1 (entget name1)
ss (ssadd)
ss (ssadd name1 ss)
(setq name2 (entlast)
ss (ssadd name2 ss)
ent2 (entget name2)
(entmake (list '(0 . "ARC") (cons 8 "02细实线层") (cons 10 '(0.0 0.0)) (cons 40 (* 0.5 d)) (cons 50 (* 1.5 pi))
(cons 51 pi)
(setq name3 (entlast)
ent3 (entget name3)
ss (ssadd name3 ss)
(entmake (list '(0 . "CIRCLE") (cons 10 '(0.0 0.0)) (cons 40 (* 0.5 (- d p)))))
(setq name4 (entlast)
ent4 (entget name4)
ss (ssadd name4 ss)
(setq loop t)
(while loop
(setq gr (grread t 15 1)
code (car gr)
pt (cadr gr)
(cond
((= code 5) ; 鼠标移动
(redraw)
(setq pt (osnappt ss pt)) ; 取得grread捕捉点
(setq ent1 (emod ent1 10 (polar pt 0.0 dd)))
(entmod (emod ent1 11 (polar pt pi dd)))
(setq ent2 (emod ent2 10 (polar pt (* 0.5 pi) dd)))
(entmod (emod ent2 11 (polar pt (* -0.5 pi) dd)))
(entmod (emod ent3 10 pt))
(entmod (emod ent4 10 pt))
((= code 3) ; 鼠标左键
(redraw)
(entmake (list '(0 . "LINE") (cons 8 "03中心线层") (cons 48 bl) (cons 10 (polar pt 0.0 dd)) (cons 11 (polar pt pi dd))))
(entmake (list '(0 . "LINE") (cons 8 "03中心线层") (cons 48 bl) (cons 10 (polar pt (* 0.5 pi) dd)) (cons 11
(polar pt
(* -0.5
pi
) dd
(entmake (list '(0 . "ARC") (cons 8 "02细实线层") (cons 10 pt) (cons 40 (* 0.5 d)) (cons 50 (* 1.5 pi)) (cons 51 pi)))
(entmake (list '(0 . "CIRCLE") (cons 10 pt) (cons 40 (* 0.5 (- d p)))))
((member code '(11 25)) ; 鼠标右击
(redraw)
(setq loop nil)
(setq *error* $orr)
