查看: 8196|回复: 21
[源码] 首尾相连直线转多段线程序
发表于 2021-12-30 11:48:54 | 显示全部楼层 |阅读模式
;贡献一个首尾相连直线转多段线程序,程序虽小感觉比CAD自带的PE命令好用,支持面域,多线,区域覆盖直接转多段线。
(defun c:pee (/ ent ent1 i j la name name1 ss ss0 ss1)
  (setvar "cmdecho" 0)
  (setvar "peditaccept" 1)
  (if (setq ss0 (ssget))
    (progn (setq ss (ssadd))
      (repeat (setq i (sslength ss0))
        (setq name (ssname ss0 (setq i (1- i)))  ent (entget name))
        (if (member (cdr (assoc 0 ent)) (list "REGION" "WIPEOUT" "MLINE"))
          (progn (setq la (cdr (assoc 8 ent)))
            (command "explode" name)
            (if (setq ss1 (ssget "p"))
              (repeat (setq j (sslength ss1))
                (setq name1 (ssname ss1 (setq j (1- j))) ent1 (entget name1))
                (entmod (subst (cons 8 la) (assoc 8 ent1) ent1))
                (setq ss (ssadd name1 ss))))))
        (setq ss (ssadd name ss)))
      (command "PEDIT" "M" ss "" "J" 0.0 "")))
参与人数 2明经币 +2 收起 理由
趣意人生 + 1 赞一个!
断箭 + 1 很给力!
发表于 2021-12-31 17:57:00 | 显示全部楼层
(defun c:gp (/ *error* s2 n e ty wd index pt rad r1 r2 old_lay date1 ffg oos)
(defun *error* (msg)
  (if oos
   (setvar "osmode" oos)
  (if old_lay
   (setvar "clayer" old_lay)
(setq oos (getvar "osmode"))
(setvar "osmode" 0)
(setq old_lay (getvar "clayer"))
(prompt "\n请选择要连接成多义线的线(line,arc,circle,lwpolyline)<退出>:")
(setq s2 (ssget '((-4 . "<AND") (0 . "LINE,LWPOLYLINE,ARC,CIRCLE")
    (-4 . "AND>")
(if (/= s2 nil)
   (setq date1 (getvar "CDATE"))
   (setq wd (getdist "多义线宽度<0>:")
  wd (if wd
      wd
      0
   (setq n (sslength s2))
   (setq index 0)
   (repeat n
    (setq e (ssname s2 index)
   ent (entget e)
   index (+ 1 index)
   ty (assoc 0 ent)
    (if (= "LWPOLYLINE" (cdr ty))
      (command ".change" s2 "" "P" "C" "bylayer" "")
      (setq ffg (cdr (assoc 70 ent)))
      (if (= ffg 0)
       (command ".pedit" e "j" s2 "" "w" wd "")
       (command ".pedit" e "w" wd "")
    (if (= "LINE" (cdr ty))
      (command ".pedit" e "y" "j" s2 "" "w" wd "")
    (if (= "CIRCLE" (cdr ty))
      (setq pt (cdr (assoc 10 ent)))
      (setq rad (cdr (assoc 40 ent)))
      (setq r1 (- (* rad 2) wd))
      (setq r2 (+ (* rad 2) wd))
      (if (> wd (* 2 rad))
(setq r1 0)
(setq r2 (* rad 2))
      (command "_donut" r1 r2 pt "")
      (entdel e)
    (if (= "ARC" (cdr ty))
      (setq r1 (cdr (assoc 10 ent)))
      (setq r2 (cdr (assoc 40 ent)))
      (setq pt (cdr (assoc 50 ent)))
      (setq rad (cdr (assoc 51 ent)))
      (setq p1 (polar r1 pt r2))
      (setq p2 (polar r1 rad r2))
      (command "_pline" p1 "_w" wd wd "_a" "_ce" r1 p2 "")
      (entdel e)
   (setq n (itoa n)
  wd (rtos wd 2 0)
   (prompt (strcat "\n共有\"" n "\"条线宽度变为\"" wd "\"的多义线。耗时\"" (rtos (* (- (getvar "CDATE") date1) 86400) 2 3)
     "\"秒。"
(command "_clayer" old_lay)
(setvar "cmdecho" 1)
这个线宽不支持40
发表于 2022-1-4 20:13:20 | 显示全部楼层
lxl217114 发表于 2022-1-4 16:45
朗大师,如果可以直接点击选中“首尾相连的线/多段线”中间的任意一段,就可以执行这个程序那就更强大了。
;;;全屏幕自动连接线段
(Defun C:tt (/ Ssa Pt1 Pt2)
    (Setvar "Cmdecho" 0)
    (Setq Pt1 (Getvar "Vsmin"));屏幕左下
    (Setq Pt2 (Getvar "Vsmax"));屏幕右上
    (setq ssa (ssget "w" pt1 pt2  '((0 . "LINE,ARC,LWPOLYLINE,POLYLINE"))))
  (Vl-Cmdf "_pedit" "m" ssa "" "j" "0.0002" "")
  (Setvar "Cmdecho" 1)
  (Princ)
不用选搞定多段线
发表于 2021-12-30 13:24:19 | 显示全部楼层
这个太强大了!
发表于 2021-12-30 23:52:49 | 显示全部楼层
刚好用到,学习学习
发表于 2021-12-31 17:17:25 | 显示全部楼层
可不可以搞一个容差呀
发表于 2021-12-31 17:49:23 | 显示全部楼层
楼主,要是再加入线宽呢
发表于 2021-12-31 19:07:32 | 显示全部楼层
可以用上,不错!
发表于 2022-1-4 16:45:24 | 显示全部楼层
发表于 2022-1-4 19:10:57 | 显示全部楼层
非常不错,谢谢分享
GMT+8, 2025-12-12 23:38 , Processed in 0.213157 second(s), 32 queries , Gzip On.
