查看: 1932|回复: 5
沙漠骆驼工具箱源码-2图层操作
发表于 2022-2-9 15:14:12 | 显示全部楼层 |阅读模式
工具条:图层操作:界面和代码如下
1界面:
2 代码如下
Private Sub closelayerssub()  '关闭对象所在的图层1
    Dim s1 As AcadSelectionSet
    Dim element As AcadEntity
    On Error Resume Next
    Set s1 = ThisDrawing.SelectionSets.Add("ss1")
    If Err.Number <> 0 Then '如果选择集存在
        Err.Clear
        Set s1 = ThisDrawing.SelectionSets.Item("ss1")
        s1.Clear                '清空选择集
    End If
    s1.SelectOnScreen
    If s1.count = 0 Then Exit Sub
    For Each element In s1     '遍历选择集
        ThisDrawing.Layers.Item(element.Layer).LayerOn = False
    Next
    'ThisDrawing.Regen acActiveViewport
End Sub
Private Sub uncloselayerssub() '反向打开关闭图层  2
    Dim count As Integer, i As Integer
    count = ThisDrawing.Layers.count
    'MsgBox count & "  " & ThisDrawing.Layers.Item(3).Name
    For i = 0 To count - 1
        If ThisDrawing.Layers.Item(i).LayerOn = True Then
            ThisDrawing.Layers.Item(i).LayerOn = False
        Else
        End If
    Next
End Sub
Private Sub locklayerssub() '锁定对象所在的图层  3
        Err.Clear
        s1.Clear                '清空选择集
    End If
    s1.SelectOnScreen
        ThisDrawing.Layers.Item(element.Layer).Lock = True
    Next
End Sub
Private Sub clearlocklayerssub() '解锁对象所在的图层 4
        Err.Clear
        s1.Clear                '清空选择集
    End If
    s1.SelectOnScreen
        ThisDrawing.Layers.Item(element.Layer).Lock = False
    Next
End Sub
Private Sub openalllayerssub() '打开所有图层 5
    Next
End Sub
Private Sub closealllayerssub() '关闭所有图层 6
    Next
End Sub
Private Sub freezealllayerssub() '冻结所有图层 7
        ThisDrawing.Layers.Item(i).Freeze = True
    Next
End Sub
Private Sub unfreezealllayerssub() '解冻所有图层 8
        ThisDrawing.Layers.Item(i).Freeze = False
    Next
    ThisDrawing.SendCommand "REGEN" & vbCr
End Sub
Private Sub lockalllayerssub() '锁定所有图层 9
        ThisDrawing.Layers.Item(i).Lock = True
    Next
End Sub
Private Sub unlockalllayerssub() '解锁所有图层 10
        ThisDrawing.Layers.Item(i).Lock = False
    Next
End Sub
Private Sub unlocklayerssub() '反向锁定图层  11
        If ThisDrawing.Layers.Item(i).Lock = True Then
        Else
        End If
    Next
End Sub
Private Sub closelocklayerssub() '关闭锁定的图层  12
        End If
    Next
End Sub
Private Sub closeotherlayerssub()  '关闭选取对象以外的图层  13
        Err.Clear
        s1.Clear                '清空选择集
    End If
    s1.SelectOnScreen
    Next
        ThisDrawing.Layers.Item(element.Layer).LayerOn = True
    Next
End Sub
Private Sub freezelayerssub() '冻结选取图层  14
        Err.Clear
        s1.Clear                '清空选择集
    End If
    s1.SelectOnScreen
        ThisDrawing.Layers.Item(element.Layer).Freeze = True
    Next
End Sub
Private Sub Freezeotherlayerssub()  '冻结选取外图层  15
        Err.Clear
        s1.Clear                '清空选择集
    End If
    s1.SelectOnScreen
    Next
        ThisDrawing.Layers.Item(element.Layer).Freeze = False
    Next
End Sub
Private Sub alllayersopensub()  '打开全部图层 16
        With ThisDrawing.Layers.Item(i)
            .LayerOn = True
            .Lock = False
            .Freeze = False
        End With
    Next
End Sub
Private Sub unFreezelayerssub() '反向冻结图层  17
        If ThisDrawing.Layers.Item(i).Freeze = True Then
        Else
        End If
    Next
End Sub
Private Sub CommandButton1_Click()
    tuceng.Hide
    Call closelayerssub
    tuceng.show
End Sub
Private Sub CommandButton10_Click()
    tuceng.Hide
    Call Freezeotherlayerssub
    tuceng.show
End Sub
Private Sub CommandButton11_Click()
    Call unFreezelayerssub
End Sub
Private Sub CommandButton12_Click()
    Call unfreezealllayerssub
End Sub
Private Sub CommandButton13_Click()
    Call alllayersopensub
End Sub
Private Sub CommandButton14_Click()
    Dim basepnt As Variant
    ThisDrawing.Utility.GetEntity element, basepnt, "请拾取对象以获取图层名称:"
    'MsgBox element.Layer
    If Err Then
        Err.Clear
        Me.show
    End If
    ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item(element.Layer)
End Sub
Private Sub CommandButton15_Click() '冻结隐藏图层
        If ThisDrawing.Layers.Item(i).LayerOn = False Then ThisDrawing.Layers.Item(i).Freeze = True
    Next
End Sub
Private Sub CommandButton16_Click() '锁定隐藏图层
        If ThisDrawing.Layers.Item(i).LayerOn = False Then ThisDrawing.Layers.Item(i).Lock = True
    Next
End Sub
Private Sub CommandButton2_Click()
    tuceng.Hide
    Call closeotherlayerssub
    tuceng.show
End Sub
Private Sub CommandButton3_Click()
    Call uncloselayerssub
End Sub
Private Sub CommandButton4_Click()
    Call openalllayerssub
End Sub
Private Sub CommandButton5_Click()
    tuceng.Hide
    Call locklayerssub
    tuceng.show
End Sub
Private Sub CommandButton6_Click()
    tuceng.Hide
    Call clearlocklayerssub
    tuceng.show
End Sub
Private Sub CommandButton7_Click()
    Call unlocklayerssub
End Sub
Private Sub CommandButton8_Click()
    Call unlockalllayerssub
End Sub
Private Sub CommandButton9_Click()
    tuceng.Hide
    Call freezelayerssub
    tuceng.show
End Sub
参与人数 2明经币 +2 金钱 +5 收起 理由
tiancao100 + 1 + 5 很给力!
bssurvey + 1 赞一个!
发表于 2022-2-9 17:33:23 | 显示全部楼层
支持使用vb的兄弟
 楼主| 发表于 2022-2-10 14:34:45 | 显示全部楼层
tiancao100 发表于 2022-2-9 17:33
支持使用vb的兄弟
希望对大家有一些帮助
发表于 2022-3-11 11:44:48 | 显示全部楼层
同行啊,而且还是水利地质口的
发表于 2022-5-8 00:43:16 | 显示全部楼层
谢谢楼主分享!
发表于 2022-6-7 18:12:21 来自手机 | 显示全部楼层
感谢楼主的大公无私
GMT+8, 2025-5-24 16:39 , Processed in 0.171335 second(s), 25 queries , Gzip On.
