查看: 4848|回复: 19
[提问] 求一个画弧形投影线的工具
发表于 2022-2-16 10:02:38 | 显示全部楼层 |阅读模式
10明经币
求一个画弧形投影线的工具
类似这样的
选中平面的弧形,然后可以自动实现立面正投影,并添加这种投影线,最好能给个源码。谢谢了
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2022-2-16 10:02:39 | 显示全部楼层
  1. (defun c:tt ()
  2.   (defun SSelEntnext (en / ss)
  3.     (setq ss (ssadd))
  4.     (while (setq en (entnext en)) (ssadd en ss))
  5.     ss
  6.   )
  7.   (setq nn (getint "\n等分数量: "))
  8.   (or nn (setq nn 21))
  9.   (setq s1 (car (entsel "\n选择曲线: ")))
  10.   (setvar "osmode" 0)
  11.   (setq s0 (entlast))
  12.   (command "divide" s1 nn)
  13.   (setq        ss  (SSelEntnext s0)
  14.         p1  (vlax-curve-getEndPoint s1)
  15.         i   -1
  16.         ptn '()
  17.   )
  18.   (while (setq s1 (ssname ss (setq i (1+ i))))
  19.     (setq ptn (cons (cdr (assoc 10 (entget s1))) ptn))
  20.   )
  21.   (command "erase" ss "")
  22.   (setq        ptn  (mapcar '(lambda (x) (list (car x) (cadr p1))) ptn)
  23.         ptn1 (mapcar '(lambda (x) (list (car x) (- (cadr x) 1000))) ptn)
  24.   )
  25.   (mapcar '(lambda (x y) (command "line" x y "")) ptn ptn1)
  26.   (command "line" (car ptn) (last ptn) "")
  27.   (command "line" (car ptn1) (last ptn1) "")
  28.   (princ)
  29. )
发表于 2022-2-16 11:01:01 | 显示全部楼层
需求不是很详细,粗略写了一个,您可以试试
  1. (defun c:test1 (/ dis en lst n pause pt1 pt2 pt3 pt4 ss)
  2.   (defun G-pertoline (pt pt1 pt2 / norm)
  3.     (setq norm (mapcar '- pt2 pt1)
  4.           pt1  (trans pt1 0 norm)
  5.           pt   (trans pt 0 norm)
  6.           )
  7.     (trans (list (car pt1) (cadr pt1) (caddr pt)) norm 0)
  8.     )
  9.   (setq        en  (vlax-ename->vla-object (car (entsel "\n选:")))
  10.         n   (getint "\n等分数")
  11.         ss  (ssadd)
  12.         dis (/ (vlax-curve-getdistatparam en (vlax-curve-getendparam en))
  13.                n
  14.                )
  15.         )
  16.   (repeat (1+ n)
  17.     (setq
  18.       lst (cons (vlax-curve-getpointatdist en (* n dis)) lst)
  19.       n          (1- n)
  20.       )
  21.     )
  22.   (vla-getboundingbox en 'pt1 'pt2)
  23.   (setq        pt1 (vlax-safearray->list pt1)
  24.         pt2 (vlax-safearray->list pt2)
  25.         pt3 (list (car pt2) (cadr pt1))
  26.         pt4 (list (car pt1) (cadr pt2))
  27.         )
  28.   (setq        ss (ssadd (entmakex (list '(0 . "line")
  29.                                   (cons 10 pt1)
  30.                                   (cons 11 pt3)
  31.                                   )
  32.                             )
  33.                   ss
  34.                   )
  35.         ss (ssadd (entmakex (list '(0 . "line")
  36.                                   (cons 10 pt4)
  37.                                   (cons 11 pt2)
  38.                                   )
  39.                             )
  40.                   ss
  41.                   )
  42.         )
  43.   (foreach n lst
  44.     (setq ss (ssadd (entmakex (list '(0 . "line")
  45.                                     (cons 10 (G-pertoline n pt1 pt3))
  46.                                     (cons 11 (G-pertoline n pt2 pt4))
  47.                                     )
  48.                               )
  49.                     ss
  50.                     )
  51.           )
  52.     )
  53.   (command "move" ss "" pt4 pt1)
  54.   )
USER2128 + 1 赞一个!
 楼主| 发表于 2022-2-16 15:43:37 | 显示全部楼层
你好 报错  命令: ; 错误: 输入的字符串有缺陷   。。不知道什么原因
发表于 2022-2-16 16:31:28 | 显示全部楼层
我测试的时候没出现呢   但是效果好像有点不太一样 那种渐变的感觉没有  不过渐变好像挺费劲
发表于 2022-2-16 17:41:25 | 显示全部楼层
你那个透视关系不太对哟
最开始想到的是批量线上加点 然后由点画线!但是用的比较少,也就用了个笨方法
1.圆弧转多段线
2.QDIM 标注
3.炸开标注 删除多余部分.
 楼主| 发表于 2022-2-17 10:34:43 | 显示全部楼层
cq4920 发表于 2022-2-16 17:41
你那个透视关系不太对哟
最开始想到的是批量线上加点 然后由点画线!但是用的比较少,也就用了个笨 ...
谢谢 ,就是这个意思
发表于 2022-2-17 20:27:12 | 显示全部楼层
他牛逼了,非常感谢
发表于 2022-2-17 21:14:57 | 显示全部楼层
代码没拷贝全吧
发表于 2022-2-17 21:19:07 | 显示全部楼层
按他那种渐变确实费劲,要算斜率
GMT+8, 2025-12-13 04:27 , Processed in 0.173779 second(s), 26 queries , Gzip On.
