- 积分
- 9615
- 明经币
- 个
- 注册时间
- 2019-6-5
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
2明经币
请教下大佬如下图功能,我通过拼凑出来的功能,就是先通过批量块缩放,把块缩放指定比例,在通过lee的程序把块内部区域的图元清空,在通过批量块缩放,恢复到之前比例。但是使用过程中感觉不是很流畅,特别是发现有不对的地方撤销(U)回去的时候,只能一个一个回,不能编组之后回,请教下大佬们这种该如何优化好呢,或者有其他新的想法的能实现这个效果的程序吗
我拼凑的程序如下
(defun c:kp( / *error* inc rot sel )
(defun err(msg)
(command-s ".UNDO" "E")
(setq *error* err)
(command ".UNDO" "BE")
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(defun cen (en / MAXP MINP X Y)
(vla-GetBoundingBox (vlax-ename->vla-object en) 'MinP 'MaxP)
(setq MinP (vlax-safearray->list MinP))
(setq MaxP (vlax-safearray->list MaxP))
(mapcar '(lambda (X Y) (/ (+ X Y) 2.0)) MinP MaxP)
(setq rot (= "ON" (getenv "LMac\\ABBRotation")))
(if (setq sel (ssget '((0 . "INSERT"))))
(setq num (getreal "\n 缩放比例: "))
(if (and num sel)
(repeat (setq n (sslength sel))
(setq en (ssname sel (setq n (1- n))))
(vl-cmdf "_.scale" en "" (cen en) num)
(LM:startundo (LM:acdoc))
(repeat (setq inc (sslength sel))
(LM:AutoBlockBreak (ssname sel (setq inc (1- inc))) rot)
(if (and num sel)
(vl-cmdf "_.scale" en "" (cen en) (/ 1 num))
(defun LM:autoblockbreak ( ent rot / *error* _furthestapart ang bbx brk cmd crv di1 di2 enx idx ins int lst ply sel tmp )
(if (and (= 'vla-object (type ply)) (vlax-write-enabled-p ply))
(vla-delete ply)
(if (= 'int (type cmd))
(setvar 'cmdecho cmd)
(defun _furthestapart ( lst / dis mxd out pt1 pt2 )
(setq mxd 0.0)
(while (setq pt1 (car lst))
(foreach pt2 (setq lst (cdr lst))
(if (< mxd (setq dis (distance pt1 pt2)))
(setq mxd dis
out (list pt1 pt2)
out
(if (and (= 'ename (type ent))
(setq enx (entget ent))
(= "INSERT" (cdr (assoc 0 enx)))
(if
(and
rot
(setq bbx (LM:blockboundingbox (vlax-ename->vla-object ent)))
(setq sel
(ssget "_C"
(trans (car bbx) 0 1)
(trans (caddr bbx) 0 1)
'((0 . "ARC,ELLIPSE,CIRCLE,LINE,XLINE,SPLINE,*POLYLINE"))
(setq ins (trans (cdr (assoc 10 enx)) ent 0)
crv (ssname sel (1- (sslength sel)))
di1 (distance ins (vlax-curve-getclosestpointto crv ins))
(repeat (setq idx (1- (sslength sel)))
(setq tmp (ssname sel (setq idx (1- idx))))
(if (< (setq di2 (distance ins (vlax-curve-getclosestpointto tmp ins))) di1)
(setq di1 di2
crv tmp
(< di1 1e-4)
(setq par (vlax-curve-getparamatpoint crv (vlax-curve-getclosestpointto crv ins)))
(cond
( (equal par (vlax-curve-getendparam crv) 1e-8)
(setq par (vlax-curve-getparamatdist crv (- (vlax-curve-getdistatparam crv par) 1e-3)))
( (equal par (vlax-curve-getstartparam crv) 1e-8)
(setq par (vlax-curve-getparamatdist crv (+ (vlax-curve-getdistatparam crv par) 1e-3)))
( t )
(setq der (vlax-curve-getfirstderiv crv par))
(setq ang (angle '(0.0 0.0 0.0) (trans der 0 (cdr (assoc 210 (entget crv))))))
(or (<= ang (/ pi 2.0))
(< (/ (* 3.0 pi) 2.0) ang)
(setq ang (+ ang pi))
(vla-put-rotation (vlax-ename->vla-object ent) ang) ;; VL used to account for attributes
(if
(and
(setq sel
(ssget "_C"
(setq ply
(entmakex
(append
(list
'(000 . "LWPOLYLINE")
'(100 . "AcDbEntity")
'(100 . "AcDbPolyline")
'(090 . 4)
'(070 . 1)
(cons 38 (cadddr (assoc 10 enx)))
(mapcar '(lambda ( p ) (mapcar '+ (cons 10 (trans p 0 ent)) '(0 0 0))) bbx)
(list (assoc 210 enx))
(repeat (setq idx (sslength sel))
(setq ent (ssname sel (setq idx (1- idx))))
(if (setq int (LM:Intersections (vlax-ename->vla-object ent) ply acextendthisentity))
(setq lst (cons (cons ent int) lst))
(vla-delete ply)
(setq cmd (getvar 'cmdecho))
(setvar 'cmdecho 0)
(foreach int lst
(if (setq brk (_furthestapart (cdr int)))
(command
"_.break" (list (car int) (trans (car brk) 0 1)) "_F"
"_non" (trans (car brk) 0 1)
"_non" (trans (cadr brk) 0 1)
;; Intersections - Lee Mac
;; Returns a list of all points of intersection between two objects.
;; obj1,obj2 - [vla] VLA-Objects with intersectwith method applicable
;; mode - [int] acextendoption enum of intersectwith method
;; Returns: [lst] List of 3D WCS intersection points, else nil
(defun LM:intersections ( obj1 obj2 mode / l r )
(setq l (vlax-invoke obj1 'intersectwith obj2 mode))
(repeat (/ (length l) 3)
(setq r (cons (list (car l) (cadr l) (caddr l)) r)
l (cdddr l)
(reverse r)
(defun LM:blockboundingbox ( blk / bnm llp lst urp )
(setq bnm (strcase (vla-get-name blk)))
(cond
( (setq lst (cdr (assoc bnm LM:blockboundingbox:cache))))
( (progn
(vlax-for obj (vla-item (LM:acblk) bnm)
(cond
( (= "AcDbBlockReference" (vla-get-objectname obj))
(setq lst (append lst (LM:blockboundingbox obj)))
( (and
(= :vlax-true (vla-get-visible obj))
(not (wcmatch (vla-get-objectname obj) "AcDbAttributeDefinition,AcDb*Text"))
(vlax-method-applicable-p obj 'getboundingbox)
(= :vlax-false (vla-get-freeze (vla-item (LM:aclyr) (vla-get-layer obj))))
(not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list obj 'llp 'urp))))
(setq lst (vl-list* (vlax-safearray->list llp) (vlax-safearray->list urp) lst))
lst
(setq lst (mapcar '(lambda ( fun ) (apply 'mapcar (cons fun lst))) '(min max)))
(setq lst
(list
(car lst)
(list (caadr lst) (cadar lst))
(cadr lst)
(list (caar lst) (cadadr lst))
(setq LM:blockboundingbox:cache (cons (cons bnm lst) LM:blockboundingbox:cache))
(apply
(function
(lambda ( m v )
(mapcar (function (lambda ( p ) (mapcar '+ (mxv m p) v))) lst)
(refgeom (vlax-vla-object->ename blk))
;; RefGeom (gile)
;; Returns a list which first item is a 3x3 transformation matrix (rotation,
;; scales, normal) and second item the object insertion point in its parent
;; (xref, block or space)
;; Argument : an ename
(defun refgeom ( ent / ang ang mat ocs )
ang (cdr (assoc 050 enx))
ocs (cdr (assoc 210 enx))
(list
(setq mat
(mxm
(mapcar '(lambda ( v ) (trans v 0 ocs t))
(1.0 0.0 0.0)
(0.0 1.0 0.0)
(0.0 0.0 1.0)
(mxm
(list
(list (cos ang) (- (sin ang)) 0.0)
(list (sin ang) (cos ang) 0.0)
'(0.0 0.0 1.0)
(list
(list (cdr (assoc 41 enx)) 0.0 0.0)
(list 0.0 (cdr (assoc 42 enx)) 0.0)
(list 0.0 0.0 (cdr (assoc 43 enx)))
(mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
(mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; Matrix Transpose - Doug Wilson
(defun trp ( m )
(apply 'mapcar (cons 'list m))
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Block Name - Lee Mac
;; Returns the true (effective) name of a supplied block reference
(defun LM:blockname ( obj )
(if (vlax-property-available-p obj 'effectivename)
(defun LM:blockname ( obj ) (vla-get-effectivename obj))
(defun LM:blockname ( obj ) (vla-get-name obj))
(LM:blockname obj)
;; Start Undo - Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
(LM:endundo doc)
(vla-startundomark doc)
;; End Undo - Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
;; Block Collection - Lee Mac
;; Returns the VLA Block Collection Object
(defun LM:acblk nil
(eval (list 'defun 'LM:acblk 'nil (vla-get-blocks (LM:acdoc))))
(LM:acblk)
;; Layer Collection - Lee Mac
;; Returns the VLA Layer Collection Object
(defun LM:aclyr nil
(eval (list 'defun 'LM:aclyr 'nil (vla-get-layers (LM:acdoc))))
(LM:aclyr)
(if (null (getenv "LMac\\ABBRotation"))
(setenv "LMac\\ABBRotation" "ON")
附件: 您需要 登录 才可以下载或查看,没有账号?注册
