查看: 1338|回复: 3
[提问] 修改清理垃圾词典程序为自动运行
发表于 2022-3-14 16:17:59 | 显示全部楼层 |阅读模式
请朋友们看一下,这个程序如果修改成数字大于1000时,怎么运行删除!
感谢
发表于 2022-3-15 07:45:50 | 显示全部楼层
(dictremove (namedobjdict) "ACAD_DGNLINESTYLECOMP")
 楼主| 发表于 2022-3-17 15:56:49 | 显示全部楼层
自己搞出来了!
        ;清理大数量的垃圾词典
        (defun dicts>n (n / mygetcount xc xdictlist xdicts xi xlst xn xname)
                (defun myGetCount (xdicts xname / errobj xitem)
                        (setq
                                xitem (vla-item xdicts xname)
                                errobj (vl-catch-all-apply 'vla-get-count (list xitem))
                        (if (vl-catch-all-error-p errobj) 000 errobj)
                (setq xdicts (vla-get-dictionaries(vla-get-ActiveDocument(vlax-get-Acad-Object))))
                (setq xdictlist (entget (namedobjdict)))
                (setq xc (length xdictlist) )
                (setq xi 0)
                (while (< xi xc)
                        (setq xlst (nth xi xdictlist))
                        (setq xn (car xlst))
                        (and
                                (= xn 3)
                                (setq xname (cdr xlst))
                                (< n (myGetCount xdicts xname));数字大于1000的都是垃圾
                                (setq xlst (nth (1- xi) xdictlist))
                                (= (car xlst) 350)
                                (entdel (cdr xlst))
                        (setq xi (1+ xi))
(dicts>n 100);清理特定数量的垃圾词典
        ;清理全部词典
        (defun dicts=all(/ xdictlist xi xlst)
                (setq xi 0)
                (while (< xi (length xdictlist))
                        (if (= (car xlst) 350)(entdel (cdr xlst)))
                        (setq xi (1+ xi))
发表于 2022-8-24 23:23:12 | 显示全部楼层
我改的增加两个参数比较大小,清理数字最大的。重新3次,基本上能清理干净了。
; 对当前图形里的常规词典进行列表
(defun C:dicts ( / xdoc xdicts xi xc xii xlst xname xnl xhl myGetCount )
        (defun myGetCount ( xd xn / xitem errobj)
                (setq xitem (vla-item xd xn)  errobj (vl-catch-all-apply 'vla-get-count (list xitem)))
                        "0"
                        (itoa errobj)
        )  ; end of myerr()
        (vl-load-com)
        (setq xdoc (vla-get-ActiveDocument (vlax-get-Acad-Object))
                xdicts (vla-get-dictionaries xdoc)
                xi 0  xc (length xdictlist)  xii 0  xnl nil  xhl nil nob 0 n 0
        (repeat 3
                (while (< xi xc)  ; 对于xdictlist中的每个元素,字典列表
                        (if (= (car (setq xlst (nth xi xdictlist))) 3)
                                        (setq xii (1+ xii)  xi (1+ xi))
                                        (princ (strcat (itoa xii) ". \"" (setq xname (cdr xlst)) "\"  "  (myGetCount xdicts xname) "\n"))
                                        (if (> (atoi (myGetCount xdicts xname)) n)
                                                (setq n (atoi (myGetCount xdicts xname))
                                                        nob  xii
                                        (setq xnl (cons xname xnl)  xhl (cons (cdr (nth xi xdictlist)) xhl))
                                )  ; end of progn(it's a dictionary item)
                        )  ; end of if(it's a dictionary item)
                        (setq  xi (1+ xi))
                )  ; end of while(each element in dictionary list)
                (princ (strcat "\nActiveDocument.Dictionaries.Count=" (itoa (vla-get-count xdicts)) "\n"))
                (initget 6)  ; no zero or negative value allowed
                (setq  xnl (reverse xnl)  xhl (reverse xhl))
                (if (and nob (<= nob xii)) (entdel (nth (1- nob) xhl)))
                (princ (strcat "刚才清理的行数为:" (itoa nob)))
        (vla-PurgeAll xdoc)
        (vla-Save xdoc)
        (princ "\nYou can type command of DICTS to go again.")
)  ; end of (C:dicts)
GMT+8, 2025-5-15 11:15 , Processed in 0.286093 second(s), 26 queries , Gzip On.
