查看: 1056|回复: 1
[提问] 批量匹配文本表格
发表于 2022-3-19 22:01:16 | 显示全部楼层 |阅读模式
 楼主| 发表于 2022-3-19 22:03:06 | 显示全部楼层
(defun c:NM (/ lst ss ss2 ssa ssl)
        (setq ss (ssget  (list '(0 . "TEXT,MTEXT"))))
        (setq  ssl(TableSort-H ss 4 0.1))
        (setq  ss2(XJ-Remove ssl nil))
        (setq lst
                (mapcar '(lambda(a)
                                                         (mapcar '(lambda(x)
        (xj-getdxf (car x) 1)
        a
                        ss2
        (setq ssa (ssget  (list '(0 . "TEXT,MTEXT"))))
        (mapcar '(lambda(a)
                                                 (setq txt(xj-getdxf a 1))
                                                 (setq pt(xj-5pt a 4) )
                                                 (setq box(BF-Mat-ScaleByMatrix(GetTextBox a) pt 1.5) )
                                                 (setq ent(xj-recs box))
                                                 (xj-copy ent (cadr box)(car box))
                                                 (xj-copy a (cadr box)(car box))
                                                 (if(setq aslst(assoc txt  lst ))
        (setq ztxt(cadr aslst))
        (xj-putdxf (entlast) 1 ztxt)
        (xj-putdxf (entlast) 1 "無效")
        (vla-put-color (vlax-ename->vla-object (entlast)) 1)
                (vl-remove-if-not '(lambda(x)(= 'ENAME (type x))) (mapcar 'cadr (ssnamex ssa)))
)        各路大神们,能否帮忙完善一下这个代码!!万分感激。
GMT+8, 2025-5-15 23:50 , Processed in 0.177813 second(s), 26 queries , Gzip On.
