查看: 6019|回复: 16
[2023] 搬运,2023可以试试这个
发表于 2022-4-3 11:47:56 | 显示全部楼层 |阅读模式
可以试试,没有测试
发表于 2022-4-3 12:53:25 | 显示全部楼层
Autodesk License Patcher
Autodesk许可证修补程序
... Welcome To Autodesk License Patcher. . .
...欢迎来到Autodesk许可证修补程序. . .
This tool will permenantly license all Autodesk products via NLM Supports v2021 To v2023 with any ADSK Licensing.
此工具将通过NLM支持永久授权所有 Autodesk v2021到v2023产品,并授予任何ADSK许可。
Run with administrator privileges and UAC disabled.Check "ReadMe" before using.
以administrator管理员权限运行,UAC禁用。使用前阅读“ReadMe”自述文件。
发表于 2022-4-3 16:01:10 | 显示全部楼层
hszt 发表于 2022-4-3 13:58
已测试可用,傻瓜型全自动,不知道干了些啥?看不出痕迹。
已测试同时授权cad2022和2023,其他软件没安装 ...
想知道它干啥了?
  1. 停止并清理原版
复制代码
  1. 添加河蟹版
  2. xcopy "%SystemDrive%\AutodeskLicensePatcherInstaller\Files\NetworkLicenseManager\adskflex.exe" "%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager" /Y /K /R /S /H /i >Nul 2>&1
  3. xcopy "%SystemDrive%\AutodeskLicensePatcherInstaller\Files\NetworkLicenseManager\lmgrd.exe" "%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager" /Y /K /R /S /H /i >Nul 2>&1
  4. xcopy "%SystemDrive%\AutodeskLicensePatcherInstaller\Files\NetworkLicenseManager\License.lic" "%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager" /Y /K /R /S /H /i >Nul 2>&1
  5. xcopy "%SystemDrive%\AutodeskLicensePatcherInstaller\Files\Service\Service.vbs" "%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager" /Y /K /R /S /H /i >Nul 2>&1
  6. xcopy "%SystemDrive%\AutodeskLicensePatcherInstaller\Files\Service\Service.bat" "%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager" /Y /K /R /S /H /i >Nul 2>&1
  7. xcopy "%SystemDrive%\AutodeskLicensePatcherInstaller\Files\PatchedFiles\version.dll" "%CommonProgramFiles(x86)%\Autodesk Shared\AdskLicensing\Current\AdskLicensingAgent" /Y /K /R /S /H /i >Nul 2>&1
复制代码
  1. 设置计划任务
  2. schtasks.exe /Delete /tn "\Microsoft\Windows\Autodesk\Autodesk" /f >Nul 2>&1
  3. schtasks.exe /Create /XML %SystemDrive%\AutodeskLicensePatcherInstaller\Files\Task\Autodesk.xml /tn "\Microsoft\Windows\Autodesk\Autodesk" >Nul 2>&1
复制代码
  1. 添加防火墙规则
  2. netsh advfirewall firewall add rule name="AutodeskNLM" dir=in action=block profile=any program="%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager\adskflex.exe" >Nul 2>&1
  3. netsh advfirewall firewall add rule name="AutodeskNLM" dir=in action=block profile=any program="%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager\lmgrd.exe" >Nul 2>&1
  4. netsh advfirewall firewall add rule name="AutodeskNLM" dir=out action=block profile=any program="%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager\adskflex.exe" >Nul 2>&1
  5. netsh advfirewall firewall add rule name="AutodeskNLM" dir=out action=block profile=any program="%CommonProgramFiles(x86)%\Autodesk Shared\Network License Manager\lmgrd.exe" >Nul 2>&1
  6. cd "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing" >Nul 2>&1
  7. for /R %%a in (*.exe) do (
  8. netsh advfirewall firewall delete rule name="Allowed %%a" >Nul 2>&1
  9. netsh advfirewall firewall delete rule name="Blocked %%a" >Nul 2>&1
  10. netsh advfirewall firewall add rule name="Blocked %%a" dir=out action=block profile=any program="%%a" >Nul 2>&1
  11. netsh advfirewall firewall add rule name="Blocked %%a" dir=in action=block profile=any program="%%a" >Nul 2>&1
复制代码
好吧,清理的代码被论坛吃了
 楼主| 发表于 2022-4-3 11:50:41 | 显示全部楼层
搬来的:
由于MAGNiTUDE破解的网络许可管理器(NLM)激活方法,步骤繁琐,手动成功效率低。
因此,决定批处理整合下,简化处理步骤并优化激活流程,实现全程无人值守自动检测激活。
1、下载运行Autodesk2023激活补丁 Autodesk_License_Patcher_2021-2023.exe
2、启动Autodesk软件,选择网络许可证->单一服务器->输入127.0.0.1,激活完毕!
发表于 2022-4-3 13:50:01 | 显示全部楼层
wydhd 发表于 2022-4-3 11:50
搬来的:
因此,决定批 ...
这个咋样,不知道效果如何
2023一次性成功!已安装的2021/2022也不受影响,都没问题!  发表于 2022-4-4 13:28
发表于 2022-4-3 13:58:21 | 显示全部楼层
已测试同时授权cad2022和2023,其他软件没安装,所以不清楚。
已安装编程小子的批量授权的要卸载掉,不然可能会不成功。
请编程小子看到后研究一下,这个是不是X组做的类型,能否整合到你的小程序里面。你的小程序明明白白知道干了啥,这个不清楚。
发表于 2022-4-3 14:09:31 | 显示全部楼层
我看你尝试的挺多的,你是在用虚拟机试吗
发表于 2022-4-3 14:18:55 | 显示全部楼层
xpzzj 发表于 2022-4-3 14:09
我看你尝试的挺多的,你是在用虚拟机试吗
是的,实体机不敢折腾。
发表于 2022-4-3 14:25:07 | 显示全部楼层
hszt 发表于 2022-4-3 14:18
是的,实体机不敢折腾。
哪个虚拟软件比较好用
发表于 2022-4-3 14:42:37 | 显示全部楼层
仔细查找了一下PJ文件,发现还是M组的作品,只是添加了不少旧版的软件的许可证。
看来还是可以自由添加许可证的?
发表于 2022-4-3 14:45:31 | 显示全部楼层
xpzzj 发表于 2022-4-3 14:25
哪个虚拟软件比较好用
我用小巧的VBOX。软件不大。做测试足矣。
GMT+8, 2025-9-25 12:17 , Processed in 0.198869 second(s), 33 queries , Gzip On.
