查看: 602|回复: 2
[提问] (已解决)请教一下各位大神,提取曲线首末端坐标
发表于 2022-4-4 00:13:03 | 显示全部楼层 |阅读模式
(defun c:tt()
(vl-load-com)
(setq en (car(entsel)))
(setq lst (list (vlax-curve-getStartPoint en)
(vlax-curve-getEndPoint en)))
提取曲线首末端坐标,
请教一下各位大神提取坐标出现 +E改为数值,能否改成提取至EXECL
谢谢
发表于 2022-4-4 12:42:06 | 显示全部楼层
(defun c:tt ()
  (setq en (car (entsel)))
  (setq        lst (list (mapcar '(lambda (x) (rtos x 2 3)) (vlax-curve-getStartPoint en))
                  (mapcar '(lambda (x) (rtos x 2 3)) (vlax-curve-getEndPoint en))
 楼主| 发表于 2022-4-4 14:25:18 | 显示全部楼层
xyp1964 发表于 2022-4-4 12:42
(defun c:tt ()
  (setq        lst (list (mapcar '(lambda (x) (rtos x 2 3)) (v ...
XYP1964
版主
谢谢
(defun c:tt ()
(vl-load-com)
  (setq en(car (entsel)))
  (setq lst(list (mapcar '(lambda (x) (rtos x 2 3)) (vlax-curve-getStartPoint en))
  (mapcar'(lambda (x) (rtos x 2 3)) (vlax-curve-getEndPoint en))
(setq ffn (getfiled "坐标写入文本文件" "D:/" "TXT" 1))
(setq opf (open ffn "w"))
(setq ss (ssget '((0 . "*LINE"))))
(setq kg " ")
(setq txt (strcat kg "X坐标"kg "Y坐标"))
(write-line txt opf)
;(princ (strcat kg "X坐标" kg "Y坐标") opf)
(setq i -1)
(setq key 10)
(repeat (sslength ss)
(setq ent (entget (ssname ss (setq i (1+ i)))))
(setq count 1)
(foreach xy ent
(if (eq (car xy) key)
(setq pe (cdr xy))
(setq x (rtos(cadr pe)2 3))
(setq y (rtos(car pe)2 3))
(write-line (strcat (itoa count) kg x kg y) opf)
;(princ "\n" opf)
;(princ (strcat (itoa count) kg x kg y) opf)
(setq count (1+ count))
GMT+8, 2025-5-15 23:29 , Processed in 0.167011 second(s), 25 queries , Gzip On.
