- 积分
- 5784
- 明经币
- 个
- 注册时间
- 2022-4-6
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
安装CAD2018后安装不了2014求解!
2022/4/9:07:15:16 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:15:16 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:15:16 Administrator DESKTOP-8CPIRD4 Current Directory E:\BaiduNetdiskDownload\新建文件夹
2022/4/9:07:15:16 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:15:16 Administrator DESKTOP-8CPIRD4 CommandLine
2022/4/9:07:15:16 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIE669.tmp
2022/4/9:07:15:19 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:15:18 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:15:18 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:15:18 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIE669.tmp
2022/4/9:07:15:18 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:15:18 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIE669.tmp\Setup\AcSetup.dll
2022/4/9:07:15:18 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2022/4/9:07:15:18 Administrator DESKTOP-8CPIRD4 PageOpen LaunchDialog
2022/4/9:07:15:22 Administrator DESKTOP-8CPIRD4 PageOpen ProductInfoDialog
2022/4/9:07:15:42 Administrator DESKTOP-8CPIRD4 PageOpen ProductSelectionDialog2
2022/4/9:07:15:45 Administrator DESKTOP-8CPIRD4 PageOpen FullProgressDialog
2022/4/9:07:15:45 Administrator DESKTOP-8CPIRD4 Installing DirectX Runtime: "E:\BaiduNetdiskDownload\新建文件夹\3rdParty\DirectX\DXSETUP.exe" /silent
2022/4/9:07:15:53 Administrator DESKTOP-8CPIRD4 Install DirectX Runtime Failed Failure is ignored, Result=-9
2022/4/9:07:15:53 Administrator DESKTOP-8CPIRD4 Installing Autodesk® AutoCAD® 2014: TRANSFORMS="E:\BaiduNetdiskDownload\新建文件夹\x64\zh-cn\acad\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AIE669.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\BaiduNetdiskDownload\新建文件夹\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2022/4/9:07:15:54 Administrator DESKTOP-8CPIRD4 Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1625
2022/4/9:07:15:54 Administrator DESKTOP-8CPIRD4 PageOpen InstallCompleteDialog
2022/4/9:07:16:49 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:17:06 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:17:06 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:17:06 Administrator DESKTOP-8CPIRD4 Current Directory E:\BaiduNetdiskDownload\新建文件夹
2022/4/9:07:17:06 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:17:06 Administrator DESKTOP-8CPIRD4 CommandLine
2022/4/9:07:17:06 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI96C8.tmp
2022/4/9:07:17:08 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:17:07 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:17:07 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:17:07 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI96C8.tmp
2022/4/9:07:17:07 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:17:07 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI96C8.tmp\Setup\AcSetup.dll
2022/4/9:07:17:07 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2022/4/9:07:17:07 Administrator DESKTOP-8CPIRD4 PageOpen LaunchDialog
2022/4/9:07:17:09 Administrator DESKTOP-8CPIRD4 PageOpen ProductInfoDialog
2022/4/9:07:17:21 Administrator DESKTOP-8CPIRD4 PageOpen ProductSelectionDialog2
2022/4/9:07:17:26 Administrator DESKTOP-8CPIRD4 PageOpen FullProgressDialog
2022/4/9:07:17:26 Administrator DESKTOP-8CPIRD4 Installing DirectX Runtime: "E:\BaiduNetdiskDownload\新建文件夹\3rdParty\DirectX\DXSETUP.exe" /silent
2022/4/9:07:17:27 Administrator DESKTOP-8CPIRD4 Install DirectX Runtime Failed Failure is ignored, Result=-9
2022/4/9:07:17:27 Administrator DESKTOP-8CPIRD4 Installing Autodesk® AutoCAD® 2014: TRANSFORMS="E:\BaiduNetdiskDownload\新建文件夹\x64\zh-cn\acad\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI96C8.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\BaiduNetdiskDownload\新建文件夹\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2022/4/9:07:17:28 Administrator DESKTOP-8CPIRD4 Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1625
2022/4/9:07:17:28 Administrator DESKTOP-8CPIRD4 PageOpen InstallCompleteDialog
2022/4/9:07:17:55 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:18:01 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:18:01 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:18:01 Administrator DESKTOP-8CPIRD4 Current Directory E:\BaiduNetdiskDownload\新建文件夹
2022/4/9:07:18:01 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:18:01 Administrator DESKTOP-8CPIRD4 CommandLine
2022/4/9:07:18:01 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI6C68.tmp
2022/4/9:07:18:03 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:18:02 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:18:02 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:18:02 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI6C68.tmp
2022/4/9:07:18:02 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:18:02 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI6C68.tmp\Setup\AcSetup.dll
2022/4/9:07:18:02 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2022/4/9:07:18:02 Administrator DESKTOP-8CPIRD4 PageOpen LaunchDialog
2022/4/9:07:18:03 Administrator DESKTOP-8CPIRD4 PageOpen ProductInfoDialog
2022/4/9:07:18:10 Administrator DESKTOP-8CPIRD4 PageOpen ProductSelectionDialog2
2022/4/9:07:18:12 Administrator DESKTOP-8CPIRD4 PageOpen FullProgressDialog
2022/4/9:07:18:13 Administrator DESKTOP-8CPIRD4 Installing DirectX Runtime: "E:\BaiduNetdiskDownload\新建文件夹\3rdParty\DirectX\DXSETUP.exe" /silent
2022/4/9:07:18:14 Administrator DESKTOP-8CPIRD4 Install DirectX Runtime Failed Failure is ignored, Result=-9
2022/4/9:07:18:14 Administrator DESKTOP-8CPIRD4 Installing Autodesk® AutoCAD® 2014: TRANSFORMS="E:\BaiduNetdiskDownload\新建文件夹\x64\zh-cn\acad\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI6C68.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\BaiduNetdiskDownload\新建文件夹\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2022/4/9:07:18:14 Administrator DESKTOP-8CPIRD4 Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1625
2022/4/9:07:18:14 Administrator DESKTOP-8CPIRD4 PageOpen InstallCompleteDialog
2022/4/9:07:18:17 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:19:21 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:19:21 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:19:21 Administrator DESKTOP-8CPIRD4 Current Directory E:\BaiduNetdiskDownload\新建文件夹
2022/4/9:07:19:21 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:19:21 Administrator DESKTOP-8CPIRD4 CommandLine
2022/4/9:07:19:21 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIA4A9.tmp
2022/4/9:07:19:23 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:19:22 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AIA4A9.tmp\Setup\AcSetup.dll
2022/4/9:07:19:22 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2022/4/9:07:19:22 Administrator DESKTOP-8CPIRD4 PageOpen LaunchDialog
2022/4/9:07:19:23 Administrator DESKTOP-8CPIRD4 PageOpen ProductInfoDialog
2022/4/9:07:19:31 Administrator DESKTOP-8CPIRD4 PageOpen ProductSelectionDialog2
2022/4/9:07:19:44 Administrator DESKTOP-8CPIRD4 PageOpen FullProgressDialog
2022/4/9:07:19:44 Administrator DESKTOP-8CPIRD4 Installing DirectX Runtime: "E:\BaiduNetdiskDownload\新建文件夹\3rdParty\DirectX\DXSETUP.exe" /silent
2022/4/9:07:19:46 Administrator DESKTOP-8CPIRD4 Install DirectX Runtime Failed Failure is ignored, Result=-9
2022/4/9:07:19:46 Administrator DESKTOP-8CPIRD4 Installing Autodesk® AutoCAD® 2014: TRANSFORMS="E:\BaiduNetdiskDownload\新建文件夹\x64\zh-cn\acad\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AIA4A9.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\BaiduNetdiskDownload\新建文件夹\" INSTALLDIR="C:\Program Files\Autodesk\2014\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2022/4/9:07:19:46 Administrator DESKTOP-8CPIRD4 Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1625
2022/4/9:07:19:46 Administrator DESKTOP-8CPIRD4 PageOpen InstallCompleteDialog
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 Current Directory E:\BaiduNetdiskDownload\新建文件夹
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 CommandLine
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4F12.tmp
2022/4/9:07:20:06 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINI~1\AppData\Local\Temp\_AI4F12.tmp\Setup\AcSetup.dll
2022/4/9:07:20:05 Administrator DESKTOP-8CPIRD4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2022/4/9:07:20:06 Administrator DESKTOP-8CPIRD4 PageOpen LaunchDialog
2022/4/9:07:20:08 Administrator DESKTOP-8CPIRD4 PageOpen ProductSelectionDialog2
2022/4/9:07:20:10 Administrator DESKTOP-8CPIRD4 PageOpen LaunchDialog
2022/4/9:07:20:11 Administrator DESKTOP-8CPIRD4 PageOpen BeginDeploymentDialog
2022/4/9:07:20:11 Administrator DESKTOP-8CPIRD4 CBeginDeploymentDialog::OnInitDialog reads PATH_LENGTH: 155
2022/4/9:07:26:10 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:26:10 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:26:10 Administrator DESKTOP-8CPIRD4 Current Directory E:\BaiduNetdiskDownload\新建文件夹
2022/4/9:07:26:10 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:26:10 Administrator DESKTOP-8CPIRD4 CommandLine
2022/4/9:07:26:10 Administrator DESKTOP-8CPIRD4 安装程序的一个实例已经在运行。一次仅能运行一个安装程序实例。2022/4/9:07:26:11 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:26:30 Administrator DESKTOP-8CPIRD4 === Setup started on DESKTOP-8CPIRD4 by Administrator ===
2022/4/9:07:26:30 Administrator DESKTOP-8CPIRD4 Path_Length: 155
2022/4/9:07:26:30 Administrator DESKTOP-8CPIRD4 Current Directory E:\BaiduNetdiskDownload\新建文件夹
2022/4/9:07:26:30 Administrator DESKTOP-8CPIRD4 Launch
2022/4/9:07:26:30 Administrator DESKTOP-8CPIRD4 CommandLine
2022/4/9:07:26:30 Administrator DESKTOP-8CPIRD4 安装程序的一个实例已经在运行。一次仅能运行一个安装程序实例。2022/4/9:07:26:31 Administrator DESKTOP-8CPIRD4 === Setup ended ===
2022/4/9:07:26:34 Administrator DESKTOP-8CPIRD4 PageOpen LaunchDialog
2022/4/9:07:26:35 Administrator DESKTOP-8CPIRD4 PageOpen ProductInfoDialog
2022/4/9:07:26:45 Administrator DESKTOP-8CPIRD4 PageOpen ProductSelectionDialog2
2022/4/9:07:26:48 Administrator DESKTOP-8CPIRD4 PageOpen FullProgressDialog
2022/4/9:07:26:48 Administrator DESKTOP-8CPIRD4 Installing DirectX Runtime: "E:\BaiduNetdiskDownload\新建文件夹\3rdParty\DirectX\DXSETUP.exe" /silent
2022/4/9:07:26:50 Administrator DESKTOP-8CPIRD4 Install DirectX Runtime Failed Failure is ignored, Result=-9
2022/4/9:07:26:50 Administrator DESKTOP-8CPIRD4 Installing Autodesk® AutoCAD® 2014: TRANSFORMS="E:\BaiduNetdiskDownload\新建文件夹\x64\zh-cn\acad\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AI4F12.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\BaiduNetdiskDownload\新建文件夹\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2022/4/9:07:26:50 Administrator DESKTOP-8CPIRD4 Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1625
