查看: 2093|回复: 14
[提问] (已解决)大神帮忙如何批量提取控制点名坐标高程至txt
发表于 2022-4-23 12:23:43 | 显示全部楼层 |阅读模式
谢谢,
 楼主| 发表于 2022-4-28 08:19:24 | 显示全部楼层
vitalgg 发表于 2022-4-25 18:31
写代码行不通的话,
直接用CAD的数据提取吧。 菜单- 工具- 数据提取。
(defun block:get-attributes (blk / lst)
  "获取块属性,返回属性名和值的点对列表。"
  (if (= (quote ename)
      (type blk))
    (if (safearray-value (setq lst (vlax-variant-value (vla-getattributes (vlax-ename->vla-object blk)))))
      (mapcar (quote (lambda (x)
            (cons (vla-get-tagstring x)
              (vla-get-textstring x))))
        (vlax-safearray->list lst)))
    nil))
(defun pickset:to-list (ss)
  "选择集->像素列表"
  "像素列表"
  (if ss (vl-remove-if-not (quote p:enamep)
      (mapcar (quote cadr)
        (ssnamex ss)))
    nil))
(defun c:j1()
    (defun export-pt (/ fp)
      (setq fp (open (strcat "D:/"
                             (car (string:to-list (@:timestamp) "."))
                             ".txt")
                     "w"))
      (mapcar
       '(lambda(x)
          (setq att% (block:get-attributes x))
          (write-line
           (strcat (cdr (assoc "CNTP" att%))"," ;;名称
                   (string:from-list (mapcar '@:to-string (entity:getdxf x 10))",")","  ;;坐标
                   (cdr (assoc "ELEV" att%))"," ;;标高
                   (cdr (assoc "DESC" att%))) ;; 描述
           fp))
       (pickset:to-list (ssget "x" '((0 . "insert")(2 . "cpoint")))) ;; 所有块像素
      (close fp)
      (@:cmd "notepad" filename) ;; 用 notepad 打开生成的文件
      (princ))
是这样吗
发表于 2022-4-24 07:04:49 | 显示全部楼层
txt文件保存至 D:\ 时间戳 .txt
代码中的我自定义函数定义在 @lisp 函数库中。
安装@lisp后,可以直接运行下面的代码。
  1. (defun export-pt (/ fp)
  2.   (setq fp (open (strcat "D:/"
  3.                          (car (string:to-list (@:timestamp) "."))
  4.                          ".txt")
  5.                  "w"))
  6.   (mapcar
  7.    '(lambda(x)
  8.       (setq att% (block:get-attributes x))
  9.       (write-line
  10.        (strcat (cdr (assoc "CNTP" att%))"," ;;名称
  11.                (string:from-list (mapcar '@:to-string (entity:getdxf x 10))",")","  ;;坐标
  12.                (cdr (assoc "ELEV" att%))"," ;;标高
  13.                (cdr (assoc "DESC" att%))) ;; 描述
  14.        fp))
  15.    (pickset:to-list (ssget "x" '((0 . "insert")(2 . "cpoint")))) ;; 所有块图元
  16.    )
  17.   (close fp)
  18.   (@:cmd "notepad" filename) ;; 用 notepad 打开生成的文件
  19.   (princ))
 楼主| 发表于 2022-4-24 11:22:36 | 显示全部楼层
(defun c:zhhua()
(princ "\n框选所需输出的点:")
(setq ss (ssget ))
(setq n (sslength ss))
(setq ff (open (getfiled "档保存为" "c:" "txt" 1) "w"))
(setq i 0)
(repeat n
  (setq spt (ssname ss i ))
  (setq ept (entget spt))
  (if (= (cdr (assoc 0 ept)) "POINT")
      (setq lxyz (cdr (assoc 10 ept)))
      (setq sy (rtos (nth 0 lxyz)))
      (setq sx (rtos (nth 1 lxyz)))
      (setq sz1 (rtos (nth 2 lxyz)))
      (setq sxyz (strcat sx " " sy " " sz1))
      (write-line sxyz ff)
  (setq i (+ i 1))
);repeat
(princ "\n转换完毕")
还需要优化
 楼主| 发表于 2022-4-24 08:24:32 | 显示全部楼层
安装@lisp后,可以直接运 ...
大神帮忙 把缺的函数加进去,能够执行 感恩
发表于 2022-4-24 08:29:03 | 显示全部楼层
http://atlisp.cn 安装  @lisp 就有了,
或者你自己到网站复制。网站上有源码。
http: //atlisp. cn/function/funname
用你需要的函数名代替 funname
http://atlisp.cn/function/block:get-attributes
http://atlisp.cn/function/pickset:to-list
 楼主| 发表于 2022-4-24 08:51:03 | 显示全部楼层
  大神帮忙 把缺的函数加进去,  执行命令是甚么,帮忙添加修改比较快,
发表于 2022-4-24 09:46:47 | 显示全部楼层
251 定制服务
 楼主| 发表于 2022-4-24 11:45:35 | 显示全部楼层
(defun c:pid()
(setq ff (open (getfiled "档保存为" "d:/" "txt" 1) "w"))
(setq pt "")
(while
(setq crname (getstring "\n 请输入点号名称 : "))
(setq pt (getpoint "\n 读取输出坐标的点:"))
           (setq s (strcat crname"  " (rtos (nth 1 pt) 2 3) "     " (rtos (nth 0 pt) 2 3) "     " (rtos (nth 2 pt) 2 3)))
           (write-line s ff)
        (princ "\n")
        (princ (strcat "\n 已输出的文字为''" s "'"))
  (setq pt "")
发表于 2022-4-25 18:31:34 | 显示全部楼层
写代码行不通的话,
 楼主| 发表于 2022-4-25 18:58:12 | 显示全部楼层
写代码行不通的话,
谢谢指点 数据提取没问题,我要的是点位编号
GMT+8, 2025-5-22 21:21 , Processed in 0.282594 second(s), 32 queries , Gzip On.
