查看: 1208|回复: 7
[提问] 麻烦帮去掉双引号
发表于 2022-5-6 10:02:41 | 显示全部楼层 |阅读模式
网上下载的多段线转txt程序,转出到txt会在序号那栏下面的数字显示双引号,麻烦大侠帮去掉,如“1”变成1、“2”变成2等
发表于 2022-5-6 22:27:37 | 显示全部楼层
(princ (strcat (rtos nn 2 0) "\t" x  "\t" y "\n") ff)
(write-line (strcat (rtos nn 2 0) "\t" x  "\t" y ) ff)
发表于 2022-5-6 10:38:09 | 显示全部楼层
(print (strcat (rtos nn 2 0) ) ff)
print 改成 princ
发表于 2022-5-6 14:21:44 | 显示全部楼层
TXT替换一下双引号到空白 不也可以吗
 楼主| 发表于 2022-5-6 21:46:29 | 显示全部楼层
@vitalgg大侠,改后好像不成列了,有点乱了
发表于 2022-5-6 22:50:42 | 显示全部楼层
  1. (defun c:tt ()
  2.   (vl-load-com)
  3.   (or path
  4.       (setq path "C:\\Documents and Settings\\whr\\桌面\\")
  5.   )
  6.   (setq        ffn  (getfiled "输出文件名" path "txt" 1)
  7.         path (strcat (vl-filename-directory ffn) "\\")
  8.   )
  9.   (princ "\n选择多段线: ")
  10.   (if (and (setq ss (ssget '((0 . "lw*")))) ffn)
  11.     (progn
  12.       (setq i 0)
  13.       (setvar "pdmode" 33)
  14.       (setq ff (open ffn "w"))
  15.       (write-line (strcat "序号\tX坐标\tY坐标") ff)
  16.       (repeat (sslength ss)
  17.         (setq s1 (ssname ss i)
  18.               nn 1
  19.         )
  20.         (foreach pp (entget s1)
  21.           (if (= (car pp) 10)
  22.             (progn
  23.               (setq p  (trans (cdr pp) 0 1)
  24.                     x  (rtos (car p) 2 3) ;x坐标
  25.                     y  (rtos (cadr p) 2 3) ;y坐标
  26.                     tx (strcat (itoa nn) "\t" x "\t" y)
  27.                     nn (1+ nn)
  28.               )
  29.               (write-line tx ff)
  30.             )
  31.           )
  32.         )
  33.         (setq i (1+ i))
  34.       )
  35.       (close ff)
  36.     )
  37.   )
  38.   (princ)
  39. )
 楼主| 发表于 2022-5-6 22:54:57 | 显示全部楼层
非常感谢vitalgg的热心帮助,但是好像也不行
 楼主| 发表于 2022-5-6 23:08:04 | 显示全部楼层
XYP1964大侠太厉害了,终于解决了,致以由衷的感谢及敬意!!!
GMT+8, 2025-5-16 00:10 , Processed in 0.163176 second(s), 26 queries , Gzip On.
