查看: 1599|回复: 4
[提问] 按圆心重合
发表于 2022-5-14 09:47:00 | 显示全部楼层 |阅读模式
30明经币
如图片所示,要在圆心处重合。请高手帮忙!
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
(defun c:tt5 (/ en i pt ss) (setq ss (ssget '((0 . "arc,circle"))) en (entsel "\n选择基准对象:") pt (cdr (assoc 10 (entget (car en))))) (setq i -1) (while (setq en (ssname ss (setq i (1+ i)))) (command "move" en "" "non" (cdr (assoc 10 (entget en))) "non" pt) ) (princ) )
发表于 2022-5-14 09:47:01 | 显示全部楼层
        (setq i -1)
参与人数 2明经币 +2 收起 理由
xj6019 + 1 大佬 威武!!
xyp1964 + 1 赞一个!
发表于 2022-5-14 12:13:34 | 显示全部楼层
  1. (defun c:tt ()
  2.   (defun xyp-dxf (code e) (cdr (assoc code (entget e))))
  3.   (if (and (setq s0 (car (entsel "\n选择基准对象: ")))
  4.            (setq ss (ssget '((0 . "arc,circle"))))
  5.       )
  6.     (progn
  7.       (command "undo" "be")
  8.       (setq os (getvar "osmode"))
  9.       (setvar "osmode" 0)
  10.       (setq pt (xyp-dxf 10 s0))
  11.       (setq i -1)
  12.       (while (setq s1 (ssname ss (setq i (1+ i))))
  13.         (setq p1 (xyp-DXF 10 s1))
  14.         (command "move" s1 "" p1 pt)
  15.       )
  16.       (command "undo" "e")
  17.     )
  18.   )
  19.   (setvar "osmode" os)
  20.   (princ)
  21. )
发表于 2022-5-15 09:19:33 | 显示全部楼层
  1. (defun c:tt (/ e m s ne)
  2.   (setq os (getvar "osmode"))
  3.   (setvar "osmode" 0)
  4.   (if (and (setq e (entsel "\n选择基准对象:")
  5.                  s (ssget '((0 . "arc,circle")))
  6.            )
  7.       )
  8.     (progn
  9.       (setq m (cdr (assoc 10 (entget (car e)))))
  10.       (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  11.         (setq ne (subst (cons 10 m) (assoc 10 (entget x)) (entget x)))
  12.         (entmod ne)
  13.       )
  14.     )
  15.   )
  16.   (setvar "osmode" os)
  17.   (princ)
  18. )
新手来练习练习
发表于 2022-5-17 09:12:31 | 显示全部楼层
这个有什么用,介绍一下啊
GMT+8, 2025-11-24 16:37 , Processed in 0.189738 second(s), 28 queries , Gzip On.
