查看: 833|回复: 3
[提问] 有没有大神帮忙看一下此程序是什么原因报错
发表于 2022-5-15 05:15:47 | 显示全部楼层 |阅读模式
选择线段时,按下空格键怎么会报错这种
程序内容如下:
(defun C:AC(/ en P1 P2 P3 P4 P5)
(COMMAND "UCS" "W")
(setvar "cmdecho" 0)
(setvar "cecolor" "1");改变当前颜色
(setvar "ORTHOMODE" 0);关闭正交
(if (null L)(setq L 2.0))
(if (null W)(setq W 2.0))
(if (null R)(setq R 0.5))
(while ;循环执行
(setq L11 L W11 W R11 R)
(setq T 0)
(while (/= T nil) ;循环设置参数
(princ "\n---绘制穿丝孔---")
(princ (strcat "\n当前设置[ 引线: " (rtos L 2 4) " MM "))
(princ (strcat "偏距: " (rtos W 2 4) " MM "))
(princ (strcat "半径: " (rtos R 2 4) " MM ] "))
(initget "LL WW RR")
(setq en(entsel "\n选择线段或[引线(LL) /偏距(WW) /半径(RR)]"))
(cond
((= en "LL");L
(setq L(getreal (strcat "\n引线:<" (rtos L 2 4) ">")))
(if (= nil L)(setq L L11))
((= en "WW");W
(setq W(getreal (strcat "\n偏距:<" (rtos W 2 4) ">")))
(if (= nil W)(setq W W11))
((= en "RR");R
(setq R(getreal (strcat "\n半径:<" (rtos R 2 4) ">")))
(if (= nil R)(setq R R11))
((/= en "LL")(/= en "WW")(/= en "RR")
(setq T nil)
);结束cond
);结束循环设置参数
(if (= en nil)(exit))
(setq e (car en))
(setq enn (entget (car en)))
(setq ol(cdr (assoc 0 enn)))
(if (= ol "LWPOLYLINE")
(setq n(fix (vlax-curve-getparamatpoint e
(vlax-curve-getclosestpointto e (cadr en)))));点选在多段线上的第几段
(setq n1(vlax-curve-getclosestpointto e (cadr en)));点选的点在多段线上的位置
(setq P1(vlax-curve-getpointatparam e n));第一个端点坐标
(setq P2(vlax-curve-getpointatparam e (1+ n)));第二个端点坐标
(if (= ol "LINE")
(setq P1(cdr (assoc 10 enn)));第一个端点坐标
(setq P2(cdr (assoc 11 enn)));第二个端点坐标
(setq MI(polar P1 (angle P1 P2) (* 0.5 (distance P1 P2))));线段中点坐标
(setq P3 (getpoint "\n指定一侧上的点:"))
(setq A2 (distance P1 N1));第一点到点选的点的距离
(setq A3 (distance P2 N1));第二点到点选的点的距离
(if (> A2 A3)
(setq P2P P2)
(setq P1P P1)
(setq P1 P2P)
(setq P2 P1P)
(setq ang1 (atof (angtos (angle P1 P2) 0 4)));获取点选线段的倾斜角度
(setq ang2(anga P1 P3 MI));获取点夹角角度为
;判断象限
(if (and (> ang2 90 ) (< ang2 180)) (SETQ XX 1));第一象限
(if (and (> ang2 0  ) (< ang2 90 )) (SETQ XX 2));第二象限
(if (and (> ang2 270) (< ang2 360)) (SETQ XX 3));第三象限
(if (and (> ang2 180) (< ang2 270)) (SETQ XX 4));第四象限
(cond
((= XX 1);第一象限
(setq P4(polar P2 (* pi (/ (angtof (rtos ang1) 0) (angtof (rtos 180) 0))) (* W -1)))
(setq P5(polar P4 (* pi (/ (angtof (rtos (+ 270 ang1)) 0) (angtof (rtos 180) 0))) (* L -1)))
((= XX 2);第二象限
(setq P4(polar P1 (* pi (/ (angtof (rtos ang1) 0) (angtof (rtos 180) 0))) W))
((= XX 3);第三象限
(setq P5(polar P4 (* pi (/ (angtof (rtos (+ 270 ang1)) 0) (angtof (rtos 180) 0))) L))
((= XX 4);第四象限
(entmakex (list '(0 . "CIRCLE") (cons 10 P5) (cons 40 R)))
(princ "\n")
(princ "绘制完毕!")
);结束循环绘制
(defun anga(PT1 PT2 PT3)  ;已知PT1 PT2 PT3 三点,求三点夹角A角度
(setq ang(- (angle PT1 PT3) (angle PT2 PT3)))
(if (> ang (* 2.0 pi)) (setq ang(- (* 2.0 pi) ang)))
(setq ang(atof (angtos ang 0 4)))
发表于 2022-5-15 05:32:19 | 显示全部楼层
(defun c:ac(/ *error* oldort os6 en P1 P2 P3 P4 P5)
(defun *error*(msg)    ;;==错误处理
(if oldort(setvar "orthomode" oldort))
(if os6(setvar "cecolor" os6))
(setvar "cmdecho" 1)
(princ "\n命令取消。"))
(command "UCS" "W")
(setq os6 (getvar "cecolor"))  ;保存当前图层的颜色值
(setq oldort (getvar "orthomode"))
(while ;循环执行
(setq T 0)
(cond
((= en "LL");L
((= en "WW");W
((= en "RR");R
(setq T nil)
);结束cond
);结束循环设置参数
(setq e (car en))
(if (= ol "LINE")
(if (> A2 A3)
(setq P2P P2)
(setq P1P P1)
(setq P1 P2P)
(setq P2 P1P)
;判断象限
(cond
((= XX 1);第一象限
((= XX 2);第二象限
((= XX 3);第三象限
((= XX 4);第四象限
(princ "\n")
(princ "绘制完毕!")
);结束循环绘制
bssurvey + 1 赞一个!
发表于 2022-5-15 05:25:10 | 显示全部楼层
这是因为按下空格,是非正常退出,但你没有定义非正常退出的错误处理。
 楼主| 发表于 2022-5-15 05:28:37 | 显示全部楼层
找到原因了 是CAD环境的原因 跟程序没关系
GMT+8, 2025-5-15 20:41 , Processed in 0.177005 second(s), 27 queries , Gzip On.
