查看: 1683|回复: 4
[提问] 求救:计算n条线段的交点
发表于 2022-5-15 21:09:44 | 显示全部楼层 |阅读模式
(vl-load-com)
;(setq ss (ssget "x" '(0 . "line")))
(defun c:tet()
  (setq segments (ssget "x" ))
  (setq i 0 n (sslength segments))
  (setq n (1- n))
   (while (< i n)
        (setq seg1 (ssname segments i))
        (setq seg11 (vlax-ename->vla-object seg1))
        (setq j (1+ i))
        (setq jj (1+ i))
        (setq k (- n j))
     (repeat k
       (setq seg2 (ssname segments jj))
       (setq seg22 (vlax-ename->vla-object seg2))
       (setq intpoints (vla-intersectwith seg11 seg22 acextendnone))
       (setq intpoints (vlax-variant-value intpoints))
       (vlax-safearray->list intpoints)
       ;(command "point" intpoints)
       ;(setq pts (cons intpoints pts))
;;;       (setq points (append points (list (list
;;;       (vlax-safearray-get-element intpoints 0)
;;;       (vlax-safearray-get-element intpoints 1)
;;;       (vlax-safearray-get-element intpoints 2)
       (setq jj (1+ jj))
    (setq i (1+ i))
  上面的代码想计算n条线段的交点的,但是没得到想要的结果,是怎么回事?谢谢!
发表于 2022-5-15 23:24:55 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (setq ss (ssget '((0 . "line"))))
  3.     (progn
  4.       (setq i        -1
  5.             tmp        '()
  6.       )
  7.       (while (setq s1 (ssname ss (setq i (1+ i))))
  8.         (setq o1 (vlax-ename->vla-object s1))
  9.         (setq j i)
  10.         (while (setq s2 (ssname ss (setq j (1+ j))))
  11.           (setq o2 (vlax-ename->vla-object s2))
  12.           (if (setq pt (vlax-invoke o1 'intersectwith o2 0))
  13.             (setq tmp (cons pt tmp))
  14.           )
  15.         )
  16.       )
  17.       (princ tmp)
  18.     )
  19.   )
  20.   (princ)
  21. )
lee50310 + 1 赞一个!
 楼主| 发表于 2022-5-16 10:24:52 | 显示全部楼层
昨晚调试一下也成功了,你的代码更简洁,优美!
发表于 2022-7-12 12:20:14 | 显示全部楼层
围观 一脸懵逼!!!!!!
发表于 2022-7-12 16:28:53 | 显示全部楼层
记得加一行:(vl-load-com)
GMT+8, 2025-10-3 06:18 , Processed in 0.156528 second(s), 25 queries , Gzip On.
