查看: 1137|回复: 4
[提问] 返回值“输入斜边长度参数类型错误”,请问大神这个代码哪里出错了?
发表于 2022-5-27 23:27:31 | 显示全部楼层 |阅读模式
(defun c:443 ()
(setq pp1 (getpoint "输入左下角一点"))
(setq ww (getdist pp1 "\n 输入底边长度"))
(setq pp2 (polar pp1 0 ww))
(setq ww2 (getdist pp2 "\n 输入斜边长度"))
(setq ww3(sqrt (- (* ww2 ww2) (* ww1 ww1))))
(setq pp3 (polar pp1 (/ pi 2) ww3))
(command "line" pp1 pp2 pp3 "c")
(prin1)
发表于 2022-5-27 23:55:26 | 显示全部楼层
(defun c:443 ()
  (setq ww1 (getdist pp1 "\n 输入底边长度"))
  (setq ww3 (sqrt (- (* ww2 ww2) (* ww1 ww1))));注意不要是负数
  (prin1)
发表于 2022-5-28 10:05:24 来自手机 | 显示全部楼层
三角函数问题,要控制斜边ww2大于底边ww长度,加个判断语句
 楼主| 发表于 2022-5-28 12:51:27 | 显示全部楼层
tigcat 发表于 2022-5-27 23:55
(defun c:443 ()
  (setq ww1 (getdist pp1 "\n 输入底边长度 ...
谢谢    ,,,,,
发表于 2022-5-28 13:21:48 | 显示全部楼层
  1. (defun c:tt ()
  2. (defun Udist (bit kwd msg def bpt / inp)
  3.   (if def
  4.     (setq msg (strcat "\n" msg "<" (rtos def) ">: ")bit (* 2 (fix (/ bit 2))))
  5.     (setq msg (strcat "\n" msg ": "))
  6.   )
  7.   (initget bit kwd)
  8.   (setq inp (if bpt(getdist msg bpt)(getdist msg)))
  9.   (if inp inp def)
  10. )
  11.   (setq w1(Udist 7 "" "底边长度<输入或鼠标直接量取>" w1 nil))
  12.   (setq w2(Udist 7 "" "斜边长度<输入或鼠标直接量取>" w2 nil))
  13.    (while (setq p1 (getpoint "\n输入左下角<退出>: "))
  14.      (setq p2 (polar p1 0 ww))
  15.      (setq w3 (sqrt (- (* w2 w2) (* w1 w1))))
  16.      (setq p3 (polar p2 (/ pi 2) w3))
  17.      (command "pline" p1 p2 p3 "c")
  18.    )
  19.   (princ)
  20. )
GMT+8, 2025-5-15 21:35 , Processed in 0.157321 second(s), 25 queries , Gzip On.
