查看: 1316|回复: 2
[提问] 代码回删去现有的文字,求保留
发表于 2022-5-29 08:45:14 | 显示全部楼层 |阅读模式
修改程序:修改文字内容,带记忆多选
http://bbs.mjtd.com/forum.php?mo ... amp;fromuid=7330080
(出处: 明经CAD社区)
感谢,重慶崽兒
  • (defun c:qm( / ent i newtext_1 newtxt newtxt_1 ss)
  •   (while T
  •     (if (and newtxt_1 (/= newtext_1 ""))
  •       (progn
  •         (setq newtxt (getstring (strcat "\n输入新的文字内容" "<" newtxt_1 ">" ":")))
  •         (if (= newtxt "")
  •           (setq newtxt newtxt_1)
  •       (setq newtxt (getstring "\n输入新的文字内容:"))
  •     (setq ss (ssget '((0 . "*TEXT"))))
  •     (setq i 0)
  •     (repeat (sslength ss)
  •       (setq ent (entget (ssname ss i)))
  •       (entmod (subst (cons 1 (strcat "(" newtxt ")")) (assoc 1 ent) ent))
  •       (setq i (1+ i))
  •     (setq newtxt_1 newtxt)
发表于 2022-5-29 14:16:06 | 显示全部楼层
  (while T
        (if (= newtxt "")
    (command "copy" ss ""  '(0 0 0) '(0 0 0))
    (setq i 0)
      (setq i (1+ i))
 楼主| 发表于 2022-5-31 22:31:43 | 显示全部楼层
  (while T
    (if (and newtxt_1 (/= newtext_ ...
大佬可能您误解我的意思了。例如原来是A,现在我想用这个代码变成A(2x)。增加后缀。
GMT+8, 2025-12-5 06:48 , Processed in 0.333089 second(s), 28 queries , Gzip On.
