查看: 3432|回复: 5
[提问] 怎么关闭CAD所有已经打开的只读图档???
发表于 2022-5-30 22:40:07 | 显示全部楼层 |阅读模式
公司有一台电脑有很多人用,有的人为了方便查数,就会打开很多已经打开的CAD图档,关闭CAD时就很麻烦了
想做一个功能:
1.关闭所有已经打开的CAD只读图档
2.缩放图纸范围 (COMMAND "_ZOOM" "_e")
3.保存所有图档 (MJ:SaveAllDocs)
[功能] 保存所有文档
(defun MJ:SaveAllDocs(/ item)
(setq *DOCS* (vla-get-Documents (vlax-get-acad-object)))
(vlax-for item *DOCS*
(vla-save item)
 楼主| 发表于 2022-5-30 23:31:36 | 显示全部楼层
具体怎么操作,希望各路大神指导一下
发表于 2022-5-31 18:19:36 | 显示全部楼层
(startapp "taskkill /F /IM acad.EXE /T")一句搞定
 楼主| 发表于 2022-5-31 21:05:21 来自手机 | 显示全部楼层
大哥,打开的不是只读文件要保存的
发表于 2022-6-10 16:03:22 | 显示全部楼层
  • (defun c:tt (/ *docs* active file name readonly saved)
  •   (setq *docs* (vla-get-Documents (vlax-get-acad-object)))
  •   (vlax-for item *docs*
  •     ;(vlax-dump-object item)
  •     (setq readonly (vla-get-ReadOnly item));判断读写属性
  •     (setq active (vla-get-active item))
  •     (setq saved (vla-get-saved item))
  •     (princ "\n==================================")
  •     (setq name (vlax-get-property item 'name));判断文件名
  •     (setq file (vlax-get-property item 'fullname));判断含路径名
  •     (princ (strcat "\n名字:" name))
  •     (princ (strcat "\n路径:" (if (= file "") "新建文件" file)))
  •     (princ (strcat "\n只读:"))(princ readonly1)
  •     (princ (strcat "\n激活:"))(princ active)
  •     (princ (strcat "\n保存:"))(princ saved)
  •     (terpri)
  •     (if (= :vlax-false active);未激活文档
  •       (cond
  •         ((= file "") nil)
  •         ((= :vlax-True readonly)
  •           (vla-close item :vlax-false);不保存关闭
  •         ((= :vlax-True saved)
  •         (t
  •           ;(vla-ZoomExtents *acad*)
  •           (vla-close item :vlax-True);关闭并保存
  •       (cond
  •         ((= file "") nil)
  •           (command-s "close" "Y");不保存关闭
  •         (t
  •           (command-s "close" "n");n为保存后关闭
  •   (princ)
  • (c:tt)
 楼主| 发表于 2022-6-11 21:03:25 | 显示全部楼层
  •   (setq *docs* (vla-get-Documents (v ...
  • 学习了,大佬,感谢
    GMT+8, 2025-10-3 05:08 , Processed in 0.157158 second(s), 26 queries , Gzip On.
