查看: 4819|回复: 20
[讨论] 怎样不按回车直接使用默认值?
发表于 2022-6-17 00:25:57 | 显示全部楼层 |阅读模式
15明经币
下面是一个双向偏移的代码。
(defun c:11(/ ss x)
(if (not dist) (setq dist 240))
(setq newdist (getreal (strcat  "\n请输入偏移距离 <初始值:"(rtos dist)">")))
(if (null newdist)(setq newdist dist)(setq dist newdist))
(setq ss(ssget ":s"))
(vlax-for ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))
   (mapcar '(lambda (x)  (vla-offset ss x))(list newdist (- newdist)) )(vla-delete ss)  )
(princ))
操作过程:先输入命令,再输入偏移距离并回车,再选择对象偏移。如果不输入偏移距离,直接回车再选择对象偏移。这样,就多了个确定偏移距离的回车动作
现在,直接使用默认值偏移时,想省掉这个确定偏移距离的回车动作。也就是说,使用默认值直接偏移如果想改变偏移距离,按字母S设置。写出下面的代码,但不成功,望各位大神出点主意,帮我修改看看。
(defun c:11(/ ss x)
(initget 0 "S")
(if (/= (setq ss (ssget ":s"  ((strcat "\n当前偏移距离:" (rtos dist) " [设置新距离(S)]"))))  nil)
(= ss "S")
(setq newdist (strcat "\n 设置新距离:" "<" (rtos dist) ">"))
(initget 0 "S")
(setq newdist (getreal (strcat "\n当前偏移距离:" (rtos dist) " [设置新距离(S)]")))
(if newdist
(princ))
最佳答案
查看完整内容
(defun c:tt(/ ss) (if (not dist) (setq dist 240)) (setq newdist dist) (princ (strcat "\n当前偏移距离:" (rtos dist) " ")) (while (= ss nil) (setq ss (ssget ":s")) (if (= ss nil) (progn (setq newdist (getdist (strcat "\n设置新距离:" ""))) (if (= nil newdist)(setq newdist dist)(setq dist newdist)) ) ) ) (if (and newdist ss) (vlax-for ss (vla-get-activeselect ...
发表于 2022-6-17 00:25:58 | 显示全部楼层
(defun c:tt(/ ss)
        (setq newdist dist)
        (princ (strcat "\n当前偏移距离:" (rtos dist) " <空格或者回车设置新距离>"))
        (while (= ss nil)
                (if (= ss nil)
                                (setq newdist (getdist (strcat "\n设置新距离:" "<" (rtos dist) ">")))
                        (mapcar '(lambda (x)  (vla-offset ss x))(list newdist (- newdist)))(vla-delete ss))
 楼主| 发表于 2022-6-17 04:42:52 | 显示全部楼层
发表于 2022-6-17 07:55:25 | 显示全部楼层
不按回车,怎么知道你想用默认值,还是不想用默认值?
 楼主| 发表于 2022-6-17 09:15:34 来自手机 | 显示全部楼层
输入命令后,回车肯定不能省。我想输入命令后,回车,就可以直接使用默认值操作。
发表于 2022-6-17 10:33:58 来自手机 | 显示全部楼层
逻辑有问题吧,那样的话  要什么默认值? 那怎么 修改 默认值呢?
 楼主| 发表于 2022-6-17 10:47:46 | 显示全部楼层
你试试Bao_lai大神的代码,你就知道了。
 楼主| 发表于 2022-6-17 10:51:04 | 显示全部楼层
Bao_lai 发表于 2022-6-17 09:13
(defun c:tt(/ ss)
        (setq newdist dist)
办法可行,不错。
 楼主| 发表于 2022-6-20 22:18:56 | 显示全部楼层
(defun c:tt(/ ss)
        (setq newdist dist)
感觉还是通过按一个字母来修改偏移距离比较好一点,如果用空格或回车来设置新距离,有时候空选,也会进入设置新距离状态,而且也只能按ESC取消。
发表于 2022-6-21 09:27:52 | 显示全部楼层
他的意思应该是设置一个常用值例如20,使用命令后,直接按20进行偏移,同时有一个选项子命令C做为修改这个常用值20的。
例如:
命令:TT   回车
命令:默认偏移距离为20,按C修改偏移距离,请点击偏移对象:
这时如果点击对象则按20偏移;输入C则修改偏移距离的值。
应该是这个意思吧。
GMT+8, 2025-6-7 07:14 , Processed in 0.150488 second(s), 26 queries , Gzip On.
