查看: 1190|回复: 2
[提问] 如果有图层就选择这个图层,如果没有就新建这个图层该如何操作
发表于 2022-7-16 16:13:58 | 显示全部楼层 |阅读模式
5明经币
(command "layer" "s" "3中心线层" "") ;这个是我想切换的图层
如果没有
(command "-layer" "n" "3中心线层" "c" "1" "3中心线层" "l" "center" "3中心线层" "lw" "0.15" "3中心线层" "");这个是我想新建的图层
最佳答案
查看完整内容
(if (not (tblsearch "layer" "3中心线层")) (command "-layer" "n" "3中心线层" "c" "1" "3中心线层" "l" "center" "3中心线层" "lw" "0.15" "3中心线层" ""); ) (setvar "clayer" "3中心线层") 上面是抄的你的,但是好像不行吧 然后你再试试下面的 (if (not (tblsearch "layer" "3中心线层")) (command "._layer" "m" "3中心线层" "c" "1" "" "lt" "center" "" "LW" "0.15" "" "") ) (setv ...
发表于 2022-7-16 16:13:59 | 显示全部楼层
发表于 2022-7-16 16:55:48 | 显示全部楼层
  1. (defun SETLAYER(Owner Lname propertys / la);;;propertys'(color LayerOn lock Freeze Plottable)
  2.         (or(listp propertys)(setq propertys(list propertys)))
  3.         (setq la(vlax-invoke-method (vlax-get-property Owner 'Layers)'add Lname))
  4.         (vl-some(function(lambda(x y)(vlax-put-property la x y)nil))
  5.                  '(color LayerOn lock Freeze Plottable)propertys))
(SETLAYER(vlax-get-property(vlax-get-acad-object)'activedocument)"3中心线层" nil)
世人皆醉 + 1
GMT+8, 2025-5-15 12:42 , Processed in 0.140659 second(s), 24 queries , Gzip On.
